Question about Sony FD Trinitron WEGA KV-34XBR800 34" TV
Sony KV-34BR800 TV intermitent startup problem Have to try remote multible time,will finally turn on.
  • kennugent Oct 06, 2009
    Not a remote problem, also wont start with power button on tv
    Sergeant:
  • 244 Answers
Try cleaning small lens on end of remote and receiver window on t-v (usually a small plastic covered window- on the front). if still have problem- could be you need new batteries in remote, or button on remote needs cleaning. a q-tip and some rubbing alcohol (91% or better!) use very little alcohol- just damp! may have some crud around button.
good luck!
Posted on Oct 06, 2009
Canno turn the tv on.
You probably have a main or high voltage power supply problem; the latter produces the 20,000 plus volts for the CRT and gets its voltage from the main supply. It's difficult to say which is at fault without a few measurements.
Feb 14, 2010 | Sony FD Trinitron WEGA KV-32HS420 32" TV
SONY KV32FS12 WOULD NOT START WITH REMOTE NEITHER WITH TV START BOTTON. FRONT RED LIGHT FLASHES WITH INTERMITENT MODE SEQUENCE.
You should open the TV case, then look at horizontal Circuit, check for the voltages here on main transistor collector, if there's a voltages around 115 V - 135 V, possibly you should check this Transistor, replace it if necessary....
Oct 18, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony TV Trinitron is on standby
standby light flashes tv wont turn on
Apr 11, 2009 | Televison & Video
Video Labels stay on - Sony TV Model KV-32V16
Press Display / ' i ' button TV original remote and on-screen display will disappear.
I repeat, you need Sony TV original remote to do so, universal remotes do not have such button.
Jan 14, 2009 | Sony KV-32V16 TV
Sony KV-32XBR96S Wont power on,Just makes clicking sound
I have the same problem with the power button clicking on and off was there a solution? Is it worth fixing?
Nov 30, 2008 | Televison & Video
Sony FD Trinitron Wega model KV-34BR800
Sony Wega Triniton KV-32FS100 TV
For the last week my TV has been going to a black screen for 10 seconds or so then the picture returns. It has been continual. Last night it stopped going to black screen, but now the standby light flashes 5 consecutive times and the color went haywire. A lot of red and everything that is suppose to be black is green.
I did a soft and hard reset with no success. What's wrong and is it worth fixing? Bought new in November 2002.
Aug 01, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Standby blinks 7 times
The part # for the d board is A-1300-319-A pts corp can rebuild it for about $250 www.ptscorp.com
May 25, 2008 | Sony FD Trinitron WEGA KV-34XBR800 34" TV
Sony TV power and volume not working
Since remote does not work, try taking out batt and turning on by set. See if still turns up. It could be that the up button is jammed inside set. Does everything else works? See if you can go to menu and turn speakers off, this will allow you to work on set and not worry about noise.
Sep 04, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
PIP won't turn off
I pressed "Demo" on the front of my TV and it worked, I have an old Sony KP-53XBR35 VIDEOSCOPE XBR - no original remote and the Universal remote has PIP button but would not shut it off.
Finally it's off!!!!
Jan 23, 2007 | Sony KV-35V35 TV
KV-XJ29M50 29" TV-Loud thumping sound on startup
Symptoms are not related,what you hear is the high voltage turning on and that is normal if it only does it for less than a second,the grainy picture might be intermitant,dont turn it off,when the picture is grainy tap the side of the set to see if it racts and if it does you know you have a loose conection.This could be outside because of a loose ground on tha cable or inside in the tuner.
Sep 22, 2006 | Sony KV-XJ29M50 29" TV
Sony FD Trinitron WEGA KV-34XBR800 34" TV Logo
336 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
