Question about Fuji FinePix F40fd Digital Camera
My camera will not turn on ..i have charged the battery ...a red light flashes on the front of the camera under the action button. i look forward to hearing a response. kind regards kate x
  • 244 Answers
Can you play back pictures by just pressing the playback button without turning the camera on first? If you can then you may have a jammed lens ( camera will not turn on if the lens will not move).
If camera is completely dead then 1 of the fuses has blown on the board. these are small fuses soldered to the board. There are different ones for battery power or mains and a main fuse for the whole camera.
You may have to send for repair if you cannot find any one local with knowledge of how to repair
Posted on Oct 06, 2009
I just purchased a used Jet 3 ultra power wheelchair...after charging it up I turn it on and the red light is flashing and it makes like a clicking sound when i try to make it go forward..cand you please...
bobby
The batteries are not charged. The red light indicates low batteries and the clicking sound you hear is the electric brakes being energized. Now the problem could be bad batteries or a bad charger. If you have access to an off-board charger (maybe a friend or acquaintance might have one) plug it into the charger port located under the front of the joystick. Don't plug in the on-board charger at the same time. Charge the chair overnight with the off-board charger and you should see a red light(power) and a green light(if the chairgot fully charged) if the light is still yellow then the batteries are bad and need to be replaced. Your chair uses 2 U1 batteries and if there is a battery store near you get them there. Interstate makes a good battery if you have a dealer near you. Hope this helps Good Luck
Oct 22, 2010 | Jet 3 Ultra Power Chair
When i try to turn my camera on it flashes a small red light and then it won't turn on, how do i fix this?
The Red indicator flashing in the Camera may be the Access Lamp or the Power Lamp. The Access Lamp is located below the Control buttons and the Power Lamp near to the power button. If the Access Lamp is flashing, it indicates that the Camera is accessing the Memory. Do not remove the Memory Stick or Batter while the Access Lamp is lit.
If the Power Lamp is flashing, it indicates that the Camera is turned on. If the Lamp is lit in Red it shows that the Battery is not having enough charge. Insert new batteries or charged Nickel-Metal Hydride batteries to resolve the issue.
You may also try power resetting the Camera. To power reset the Camera, remove the batteries from the Camera and then press and hold the POWER BUTTON of the Camera for 15 seconds and then reinsert the batteries after 1 minute and check if the Camera works normally. If the issue persists, service may be required.
Thanks
Oct 21, 2010 | Sony Cyber-shot DSC-S730 Digital Camera
When turning power it makes a clicking sound but does not power up. battery charger has a red and green light on. When plugged in and turned on it flashes 8 times. I checked the power control connection,...
The chair will not move if the charger is plugged in. The flashes are normal with the charger plugged into the chair. The lights on the charger mean that the batteries have been fully charged. Red and yellow lights mean charging. After you unplug the charger from the chair (if off-baord charger, turn charger off or unplug from the wall) then unplug from joystick. after plug is removed from joystick press the on button and all the battery lights should be lit and when you move the joystick forward you will hear the electric bake release and the chair should move forward etc Hope this helps
Aug 10, 2010 | Pride Jazzy Select 6 Indoor Power...
Should the power light be green or red, when I turn camera on it shows a green light then turns red
Red light indicates that the camera is out of charged., Try to charged your battery for 3-4 hrs if you encounter flashing red on a fully charged battery you need to call kodak 1 800 235 6325 ext 12
You can charged you camera using 5V AC Adaptor or a USB cable taht attached into the computer
Nov 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
When connecting up to charge red light comes on 'power on' button on front and no charging happens - any ideas? thanks
What does indicator light mean?
  • Steady red light: Battery is charging.
  • Steady green light: Battery is fully charged.
  • Flashing red light: Battery needs charging.
  • Flashing green light: The music receiver is switched on.
  • Flashing red/green light: The music receiver is available to be added to your phone.
Aug 24, 2009 | Sony Ericsson T303 Mobile Phone (Shadow...
Truck won't start, new battery, lights keep flashing
Sometimes the new battery is not 100% charged. Put it on a charger or jump start the car, the alternator should then charge up the battery.
Oct 09, 2008 | 1993 Toyota Pickup
Battery wearing down when in camera
First do not leave the battery in your cam, it will affect the cam. Use prescribed battery. Charge the battery for at least 8hrs.
Jan 22, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Camera does not turn on
Hello, reset in this case is not a solution. Maybe your lens is stuck. For further info please contact me at LIVE session. Best regards, Arpi
Jun 21, 2007 | Sony Cyber-Shot DSC-P8 Digital Camera
Fuji FinePix F40fd Digital Camera Logo
179 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
