Question about KitchenAid Dishwashers
Dishwasher is 2 years old. Top shelf dishes not getting clean even on on heavy duty and sani rinse cycle. All arms move freely,tried the 2 cups white vinegar in an open container and run cycle. I thought that helped but a few days later we are back to the same thing. No debris around drains. Tried loading differently. I have called for a repair person,but is there anything else I could check on my own?
    Problem Solver:
  • 5 Answers
Sometimes the holes in the arms get blocked up,sweetcorn,rice etc, this then stops the arm spinning and water being sprayed onto plates etc, unscrew it and run water through the centre hole and see what happens.
Posted on Oct 06, 2009
The dishwasher runs through it's cycle but does not clean the dishes properly and leaves a cloudy film and smears on the inside of the machine and the dishes
    Common Problem
  1. Confirm the wash water is hot
    1. Try heated wash(sani wash) if available
    2. Run hot water in sink to warm up before starting
    3. At least 120 degree Fahrenheit water temperature
  2. Open door check wash arm position start washer for a minute
    1. Confirm wash arm has rotated
    2. Check for plugged spray tips at either end of wash arm.
    3. Use small tweezers to remove
    4. Check for rack and dishes interfering with arm rotation
  3. Place cup in upper rack with opening up cycle washer.
    1. Confirm that cup quickly fills with water
    2. Not washing check water level in tub mim 1 1/2 inch
  4. Discontinue use of rinse/dry liquid additive.
    1. Confirm rinse/dry additive not leaking from dispenser into tub
    2. Washer detergent contains sparkle additive and too much sparkle/rinses/dry additive will coat dishes
    3. Try alternative wash detergent that contains minimal rinse/dry additive and use without liquid rinse/dry additive.
  5. It will take several wash cycles after the elimination of rinse/dry to purge the oily film from dishes and machine..
  6. If success "joy" is achieved with no additives then cautiously add back wash detergent with additives. Additives are important to facilitate drying and protecting the glassware china from leaching. The leaching process permanently etches the surface of glassware leaving a cloudy appearance.
Jan 03, 2016 | Dishwashers
Please help! I just moved into a new house where the Frigidaire dishwasher worked great for 2 weeks. Now, it's leaving hard salt-like granules all over my dishes and not rinsing all the food off. ...
Your dishwasher has clogged water ports.
Start the dishwasher with NO dishes in it.
Once it starts the wash cycle,open the door and pour in 1 quart of WHITE vinegar and resume the wash cycle.
That should clear out the residue.
Change your dishwasher soap to the FINISH brand name for happy clean dishes.
Apr 28, 2011 | Frigidaire 24 in. FDB510LC Free-standing...
After a regular dishwashing cycle, our dishes and glasses are not getting clean. They are left with a white film. We have checked and all holes in the spray arms are open. We have tried a rinse agent,...
Hi
Please check if something is blocked near the top spray arm, also make sure that all holes are open. Use a sharp metal pin to clean the holes on the top spray arm. Make sure the water pressure is not low.
under the screen and you'll need a Torx screwdriver to get to it after you remove the spray arm and screen. Check to see that the path it travels is clear. I have seen these get blocked up by stuff.
Now check if the top arm spins freely and check the bearings for the arm, if they are producing extra friction while the spray arm spins. White film deposits are observed if water is hard or when you are using more detergent than needed, try filling detergent cup half way. Try using white vinegar after the wash cycle is complete, run a complete cycle. Also turn down the heat on the hot water fed to the dishwasher. Try using water softener for better results.
You can also add vinegar in the final rinse cycle. Make sure that your soap dispenser drawer is opening and closing fine.
Hope this helps... Please post back if you need more assistance.
Feb 09, 2011 | KitchenAid KUDR24SE Built-in Dishwasher
I have a heavy white film on dishes after the cycle. It is mostly on the dishes on the top rack. I've had this dw for 3 years and it just started happening. i use cascade powder and i don't even fill...
Hi
Hope this helps... Please post back if more information is required.
Daniel
Jan 26, 2011 | Kenmore 15639 Built-in Dishwasher
I have a Maytag MDB4709AWS dishwasher that's not doing a good job cleaning dishes. Even on heavy duty cycle I still have small particles stuck inside my cups and on top also. I wanted to remove the inside...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Dec 09, 2010 | Maytag MDB7100AWB Dishwasher
I have a hotpoint built in automatic dishwasher model HDA3740G02SA. When my dishwasher runs all the cups on the top shelf seem to have dishwashing soap powder left in the bottom of the cups. I do not...
make sure the arm on top isnt hitting something, each time you load it each in there and spin it to be sure it moves freely, also make sure your rinse agent container is full of rinse agent.
Oct 29, 2010 | Hotpoint 24 in. HDA3740G Built-in...
My 5-year old Bosch dishwasher leaves a somewhat fine grit on dishes? especially obvious on the inside of glasses. I use only Cascade detergent, use a rinse aid, don't overfill the machine, and always...
I have the same problem with mine!! It's 6 years old, and I'm running loads of dishes through twice. Even that doesn't help! And I rinse the dishes too, so I have no idea where all these "crumbs" are coming from. Will check back for updates. Hope to get this problem solved!
Oct 01, 2010 | Bosch 24 in. SHU6802UC / SHU6806UC...
Dishes on top shelf, usually cups and glasses, not washing correctly. Have tried rinsing cl eanser to no avail
Probably a blocked spray arm. Remove the top spray arm and check and clean all the holes as this is where the water sprays out from to clean the dishes and glasses. When they are blocked you get poor wash results. Might also be worth checking the other 2 spray arms at the same time.
Jan 25, 2010 | Belling 24 in. IDW602 Built-in Dishwasher
My dishwasher is 12 years old. We have hard water but we use a water softener. I have to rinse the dishes completely clean before I wash them. Is my dishwasher just getting old?
A couple things can be happening here.
1) Make sure the holes in you rotating arms are not clogged up with food particles. If they are clean them out so water will flow freely. Then run an empty dishwasher with a cup of white vinegar, this should clean it real good.
2) The water may not be getting hot enough. The water is heated with the element at the bottom of the dishwasher. A simple way to check this is by stopping the dishwasher at mid wash cycle and touch the water at the bottom of the tub. If it's not very hot, than the element is bad and needs replacing. Just weigh the cost of replacing the element to the cost of a new more efficient dishwasher.
Hope this helps.
Nov 10, 2009 | Maytag 24 in. MDB5600A Jetclean II...
LG dishwasher wont clean top rack dishes
Recommend you remove the approximately 10 screws to pull the entire filter and manually clean. Remove all debris you find and thoroughly rinse out the filter if you can separate the top from the bottom. If the sump area is greasy, use a de-greasing spray to cut through it. Resemble, checking that there are no blockages in the holes on the spray arms.
Fill a bowl or cup with white vinegar and place it on the lower rack of the empty dishwasher. Do not add detergent. Run the quick cycle. The inside of the dishwasher should now be clean and not greasy. If still greasy, use the de-greasing spray (avaiable at all stores in the cleaning section.)
For 30 days, use only Electrosol or Cascade powder. Do NOT use gel or tablets, ever. Please report back your results. Good Luck!
ianc435 , please ask your question in as a new problem and I will help you out. I understand your problem.
Jan 11, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
Dishwashers Logo
124 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
