Question about Zodiac Baracuda G3 Automatic In Ground Pool Cleaner
I installed this weekend, but the g3 does not move forward, instead it goes backward, how do i fix, or should I?
    Sergeant:
  • 244 Answers
I assume you mean 'on bottom' pool cleaner? let it run a full cycle, see if it reverses and goes forward. if not get the manual and re-check your programming set-up.
good luck!
Posted on Oct 06, 2009
My machine will not sew in the forward position...It keeps sewing backwards like it is in reverse.....Need help ASAP
All sewing machines have a gear lever. This is so you can sew a seam forwards and backwards. Consult your manual.
May 03, 2016 | Sewing Machines
Hoover Savvy Brush only runs when the vacuum is moved backwards
That is brobably a bad wiring, that lose contact when you move the hoover forward. The wirings should be checked, here is some schematic:
Wiring Schematic :
Oct 22, 2008 | Hoover U8185-900 Upright Vacuum
I just brought the hello kitty suv 12 volt power wheel and the forward goes backwards and the backwards goes forward and it only moves in high speed not low speed. What do I do?
somewhere in the wiring the connections got crossed make sure all wires are going to the same colors that they connect to.
Dec 25, 2014 | Cars & Trucks
While stitching the cloth goes backwards instead of moving forwards.the backwards stitching switch is constantly on. What should I do
check to see if your machine is in buttonhole mode, one of the legs of the buttonholer will always be a reverse zigzag.
Sep 19, 2014 | Sewing Machines
My machines stitches backward instead of forward.
There is a forward and reverse switch you are missing. If you have a pedal it is a matter of pushing the pedal the right direction.
Jul 26, 2014 | Singer Inspiration 4205 Mechanical Sewing...
Transmission not move forward backward
Probably. There may be a solenoid not working which is keeping the transmission from engaging the forward gear train but for it not to work at all is unusual.
May 12, 2013 | Plymouth Grand Voyager Cars & Trucks
I just installed my G3. It pulsates fine and actually goes backwards instead of forward. Is this correct. Also, it seems to keep on the same path and cleaning only the path it has already cleaned going...
It depends on what you call backwards. These do move in the direction of the hose, not opposite the hose. Try adjusting the hose weights per the installation manual and it should work fine for you.
Aug 27, 2011 | Zodiac BARRACUDA G3 IN-GRND CLEANER
I have a bobcat 773T with the Kubota engine. It is a 2001 model. All of a sudden when I move the machine forward or backward it continues going forward or backward slowly and sometimes it will either turn...
the screeching sound could be a belt slipping. there should be a neutral adjusment on the valves that the sticks are attached to. its just a matter of finding true neutral.
Jan 16, 2011 | Toys
Janome machine going backwards instead of forwards. Goes forward if I hold the reverse button down.
sounds like a screw may have become missing to keep the reverse knob in its proper position so it is backwards inside the machine
Dec 13, 2009 | New Home MX-3123 Computerized Sewing...
2001 Volvo V70 drivers power front seat will move forward only.
if you hear a clicking sound from under the seat when trying to move backward then its not the switch. check the motor instead
Jun 02, 2009 | 2001 Volvo V70
Zodiac Baracuda G3 Automatic In Ground Pool Cleaner Logo
315 people viewed this question
Top Zodiac Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Jay Finke
Jay Finke
Are you a Zodiac Pool and Spa Expert? Answer questions, earn points and help others
