Question about Packard Bell Speaker Computer Speakers
Speaker problems only one speaker working
    Habit-Forming:
  • 188 Answers
Hi there...
i would like suggest u to check u r audio settings...ballance..
if its ok then check u r speaker by attaching by another device like telivision or i pod or walkman..
if u r speakers r ok..then u have problem on u r computer audio setting..
if speaker is not working try a new speaker..
regard & best of luck..
Posted on Dec 24, 2007
    Prodigy:
    An expert who has answered 500 questions.
  • 620 Answers
Hello there
Happy Holidays!
well, I suggest 2 things here, you can replace the speakers for a new pair, or see if connector or inside of the failing speakers, to see if the positive cable is connected, or the negative, from that you also check the wire connector end, if is in good condition too.
2002 Cheverolet Suburban Z71 - Left front speaker stops working, and unexpectedly will start working again until I turn the vehicle off. Next time I start up the vehicle, the speaker will not be working....
There can be a lot of causes of the problem, and it is difficult to diagnose. Can be:
- a bad speaker coil
- a bad wire connection at the back of the speaker
- a bad connector connection or broken wire in the wiring between the speaker and the amplifier/radio
- an intermittent problem in the amplifier/radio.
To try to fix the problem, start at the speaker (check the connectors, try a different speaker) and work back.
Jan 21, 2018 | Chevrolet Cars & Trucks
I have a set of 5 mirage nanosat speakers. Two of them have no sound. The other 3 are fine. Moved from Condo to home. As far as I know they were working in the condo. Any Ideas?
First thing to do is diagnose where problem lies - speakers or receiver or maybe wires. Take a working speaker and hook it up to the same wire that a non-working speaker is currently connected to. If the speaker now works, the problem is in the speaker, if it doesn;t work the problem is either the wire itself or the receiver. If possibly the receiver, check speaker set up menu in the receiver to see that all the channels are turned on. Have you talked to the dealer you bought it from for help? I'd start there after diagnosing problem as described above.
Jan 19, 2011 | Mirage NANOSAT Speaker
It is an old speaker (DM601 S2) but well cared for. Have clear sound in one speaker and static in the other.
It sounds like a ground problem with the speaker crossover circuit or the amplifier. Turn the amp off and disconnect one speaker and interchange it with the other using the same speaker wires. If the static speaker is now working interchange the speaker wires and try it again. Or if the same speaker still has static it is the speaker. If the static is on the same channel then you have a bad wire or if both channels work it was a bad connection. If the problem remains on the same channel change the speaker wires. If the problem switched to the other channel then it is a bad speaker wire or connection. If the same speaker has the same problem it is most likely the crossover circuit in the speaker which is used to filter frequencies of the audio signal by using capacitors and coils. If the static speaker is now working and the other speaker is now not working it is the amplifier. If the static problem is on all input devices I would trouble shoot the preamp section of the amplifier.
Jun 23, 2010 | B&W DM602 S2 Speaker
Ringer is working but speaker is not working in Motorola c118
Ringer and speaker have a different way.In this case problem only on speaker.to solve your problem open up your phone casing then check your speaker the place are the midle up your screen.in some case problem are from connector speaker that not connect well with the PCB (engine).if still not work its mean you must change your speaker.I hope it help.
Jun 09, 2010 | Motorola Mobility C118 Cellular Phone
Speakers not working when reconnected to pc
How do I get hold of the necessary graphics driver?
Apr 18, 2010 | Logitech X-540 Computer Speakers
A215 speakers are not working....
Connect the speakers to a different computer.
If they still don't work, responsibly recycle them, and buy some new speakers. But, before you do, try the speakers from the different computer in your computer. If they don't work, then it's a problem with your computer, not with your speakers.
Apr 07, 2010 | Dell A215 Computer Speakers
Logitech x-230 2.1 Speakers: My speakers power on but do not work i guess because of loose wiring ...how do i open the speakers and check the problem??
If the speakers are still under warranty its best not to open them. You will lose your warranty. If the speakers are still under warranty, take them back to where you bought the speakers and ask them to replace the product.
But to make sure the speakers are working, plugg the green audio jack into another source to see if its the speakers or your pc. helps to narrow down the problem to a single source (pc or speakers), turn the volume up and down to test them completly.
If the speakers work with a ipod or a similar device, it could be your computer that is the problem.
Hope this helped :)
Dec 14, 2009 | Logitech X-230 Computer Speakers
Surround sound speaker outlets are not working
Before you its a real big problem replace the speaker wire
Jan 12, 2009 | Televison & Video
Might be a loose connection problem. A contact cleaner is handy in cleaning the terminals. Try to swap the speaker connections if you don't have a multi-tester to check the resistance of the speakers. If the right front speaker will sound after connecting it to the left front speaker output, then it is a speaker coil problem. If not, might be an amplifier channel problem.
Jan 12, 2009 | Durabrand 5.1 Surround Sound Computer...
Hi, My speakers won't work on my "Vista" laptop. I have made 3 trips to bestbuy. "it's 20 miles round trip." The geek guy got them working,when I play DVD movie. befor they worked on...
Your Majorgeek seems to have been a Minorgeek. When you purchase external speakers to use with your laptop, you must configure your laptop for them. Since your system appears to have worked before you tried to use external speakers, I doubt that you have a problem with your sound device driver. Still,
go to control panel,and check device manager to see if you have any problems. If you have a problem flagged, let me know. If not, click on Hardware and Sound, then on Sound, and see how your laptop speakers are configured. Majorgeek should have turned off your internal laptop speakers and configured them for your external speakers. If they didn't, that likely explains your problem. Configure them and test the sound there.
If you need to use your laptop speakers (say you take your laptop somewhere without your external speakers) you will need to reconfigure your sound to the laptop speakers whenever you need to use them. Let me know if this solved your problem.
Jul 12, 2008 | Logitech X-530 Computer Speakers
Packard Bell Speaker Computer Speakers Logo
161 people viewed this question
Top Packard Bell Audio Players & Recorders Experts
David
David
SHIVAJI YADAV
SHIVAJI YADAV
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Packard Bell Audio Player and Recorder Expert? Answer questions, earn points and help others
