Question about Panasonic Let's Note R4 (CFR4GW5AXR) PC Notebook
Panasoinc cf-r4 notebook wireless is turned off - how do I turn it back on? There is no manual switch that I can see...
  • drahn Oct 07, 2009
    This answer assumes the internal wireless device is turned on and broadcasting signal. It is not.
    However, I managed to find the answer myself after a few hours of tinkering and searching the internet for some information.
    Most laptops these days have an manual switch on the body of the computer that will turn off (and back on) the internal wireless circuitry. This can be used when you might be on an airplane and want to use your laptop but should not be brodcasing any signals that might interrupt the plane's controls. Other situations where you might not want to be broadcasting a wireless signals may come to mind as well.
    On this particula unit, there is no such manual switch.
    What I did find is an internal application that will do this. I found an icon on the RH part of the task bar that shows the device not broadcasting. To get to the commands to turn on/off the broadcasting, you have to right-click the icon. Then it displays options that allow you to do this. Once the wireless circuitry is broadcasting again, following the normal procedures to connect to a wireless access point worked just fine.
  • 557 Answers
Go to start and then to networks (or make connection) on the richt site from start tab select network connections and click with richt mouse on connection (wired card or wireles connection) and reconnect
Posted on Oct 07, 2009
Turn wireless lan
On page 75 and page 76 of the Reference Manual
for the Panasonic Toughbook CF51 is described
the procedure to turn "on" the wireless lan:
1 Double-click on the taskbar.
2 Select your wireless LAN adapter and select [General].
3 Select [On] for [Switch radio].
4 Select [Networks] and select [Add].
5 Enter the profile name and network name (SSID), and then make
other necessary changes, then select [Next].
6 Make necessary changes and select [Finish].
Please note that there is no Physical Wireless Switch
on the Panasonic Toughbook CF51.
You can find the manual here and double-check yourself:
https://panasonic.ca/PCS/OperatingInstructions/CF51MK1_X_E_Reference_Manual_A.pdf
Good Luck!
Regards,
Richard - Montreal Based
Panasonic Canada Toughbook Authorized Dealer since 1989
Jan 22, 2014 | Panasonic Toughbook CF-51 Notebook
Turn on wifi
If you have 'Flight Mode' on the computer, make sure it's switched OFF.
Oct 28, 2013 | Panasonic Toughbook 19 Notebook -...
Can not enable wireless on toughbook cf-52 "radio is off"
Most Panasonic Toughbooks have a Physical On-Off
Wireless Switch Built-In. I belive the one on the CF-52
is located on the front right-hand side hidden behind
the handle. It is a small switch and you must slide it
to the right side (On) as opposed to the left side (Off).
Most modern Toughbooks also have a Wireless Switch
Utility which may be required. If so, you can find the driver at:
http://pc-dl.panasonic.co.jp/dl/search?q=&button=&dc%5B%5D=002001&p1=&p2=&oc=&lang=
That is it. Good Luck.
Regards,
Panasonic Toughbook Authorized Dealer since 1989
Oct 07, 2012 | Panasonic Toughbook CF52 Notebook
Get wifi to work on Panasonic Toughbook CF-29 PC Notebook
if you don't have a card, you can always buy a pcmcia card if it has the appopriate slot. if not you can buy a usb adapter for it. make sure that you have the physical on/off switch set to on
May 05, 2012 | Panasonic Toughbook CF-29 Notebook
I dont have a manual, somehow ive turnedoff wireless. how do i turn back on
There is a wireless ON/OFF switch on the front edge of the notebook, left most button group. Here's the manual
http://support.acer.com/acerpanam/manuals/acer/0000/userguides/AS9500-ENG-OLM.pdf
Jan 05, 2012 | Acer Aspire 9500 Notebook
Where is button to turn on wireless internet connection
see the operating instruction manual here :
http://dl.owneriq.net/d/d94ab07b-788b-41ca-8def-00135155738c.pdf
or read below :
For instructions on settings for wireless LAN and cautions during use, select [start]-
[Reference Manual], and refer to "Wireless LAN".
Before using a wireless LAN, turn the wireless LAN on using the following method (at
the time of purchase, the wireless LAN is set to [Off]).
2 Select your wireless LAN adaptor and select [General].
4 Select [OK].
The icon will turn to or ��
Oct 04, 2009 | Panasonic Toughbook T2 Notebook
Wireless connectivity
possible reasons that it is "off"
Physical switch on outside of case that has a turn on and turn off function. Make sure this is turned on.
Go to network places and find the connection that says wireless (or something similiar), it should say Enabled, if not then enable it.
Jun 21, 2009 | Panasonic Toughbook CF-51 Notebook
Wireless connection :S CF 28
control panel network connections
right click if you see Enable click it
if you do not see it then click repair.
To help you better I need to know more about the problem
Jan 26, 2009 | Panasonic Toughbook 28 Notebook
Wireless radio switch
Page 13 will show you the radio switch. It is the 4th button.
Wireless switch Turns the wireless feature on or off, but
does not create a wireless connection.
✎ A wireless network must be set up in
order to establish a wireless
connection.
http://h10032.www1.hp.com/ctg/Manual/c01035586.pdf
Dec 25, 2007 | HP Pavilion dv9000z Notebook
Panasonic Let's Note R4 (CFR4GW5AXR) PC Notebook Logo
104 people viewed this question
Top Panasonic Computers & Internet Experts
micky dee
Computer Repairing
Computer Repairing
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
