Question about Canon PC-920 Black and White Copier
How do i replace the fuser fix film in my canon pc920
    Guru:
  • 389 Answers
How do you do. If you never changed the film, I you do not advise. This will occupy beside you much time and sooner whole, you her(its) damage. This repair is considered complex. You should apply to service Canon. If you interesting, call at on site - only fragments,regrettably, in russian language only. On put you are able to find much interesting, including on angliyskom.http://www.startcopy.ru/likbez/tp_ir1210.htm
Posted on Oct 08, 2009
Testimonial: "thanks for your advice!"
Canon iR3225 is giving error code E000007-0000
there is a problem with the fuser fixing film...
you may follow the following procedures;
1. clean and re-oil the fuser fixing film, and
2. if the error persists, consider replacing the fuser fixing film
thanks
Mar 10, 2015 | Canon Office Equipment & Supplies
Canon iR2318L XXE000007-0000
Basicly, a error code E00007-000 means that the fuser fixing film can not find the home position.. Odds are that you need to replace the fuser fixing film and or the upper fuser unit.....the fuser film ripes and the film start to bind up on one side and the sensor can not see the white patch on the film.... Good luck
Nov 05, 2011 | Canon imageRUNNER 2200
Canon copier ir 2016 system error E007
i have canon ir2016 photocopier machine and its given me system error, and the error code is E007. i now when its happen so, its the fuser film that is worn out. i change the fuser and fix a new one but still the error is there. what should i do next to clear the error?
May 12, 2011 | Canon iR 2016i Black and White Copier
Display shows "system Error E007"
This is a error on the fuser unit (E007 Fixing film rotation error).
The fixing film sensor is faulty. - Check the connector of the fixing film
sensor.
- Replace the fixing film sensor.
- Replace the DC controller PCB.
Normally you must change the fuser to resolve it.
Bye
Feb 18, 2011 | Canon iR 2016i Black and White Copier
Fuser film has split so looking for part number of fuser film or fuser assy of canon L100 fax machine
FM2-3967-000 FIXING ***'Y FOR 120V, and
FM2-3968-000 FIXING ***'Y FOR 230V.
Best way is to replace whole unit, because of pressure, bushings,...
Jun 04, 2010 | Canon Office Equipment & Supplies
Canon IR 2018 system error E007
E007 means that the fuser film inside the Fuser unit is damaged which needs to be replaced, or the white patch on the fuser film is dirty and it just needs to be cleaned. I recommend getting a canon technician to fix it,
May 24, 2010 | Canon iR 2016i Black and White Copier
Error 000007-0000 iR2318L
you need to replace the fuser film (upper roll)
May 06, 2010 | Canon imageRUNNER 2200
CANON PC920
POSSIBLE BAD EXPOSURE LAMP, SOUNDS FUNNY BUT THIS MODEL WILL SEND JAM CODE WITH BAD EXPOSURE LAMP. CHECK TO SEE IF LIGHT IS IN PREHEAT MODE. ALSO THE EXIT PAPER SWITCH GETS BROKEN OFF ON THIS MODEL...
Nov 29, 2007 | Office Equipment & Supplies
Canon Error Eoo7
This error code indicates to the copier that the upper fixing film on the fuser assy is not rotating. Paper wrapped around the fixing film or the film itself is damaged may cause this. Unless you are very mechanically inclined , it will take the removal of the fixing assy and possibly the replacing of the fixing film assy. A tech would need to be called in to correct the problem. The fixing film is a replaceable item. Good luck.
Sep 26, 2007 | Canon imageRUNNER 8500 Copier
Canon IR2800
e000007 is related to the fuser..you need to change the fixing film or clean the sensor
Sep 07, 2007 | Canon imageRUNNER 600 Printer
Canon PC-920 Black and White Copier Logo
261 people viewed this question
old marine
old marine
