My DTV stopped working giving a blank screen
My Digital TV stopped working giging a blank screen with a message No signal. Everything is connected. The non digital TV works meaning the signal is not Null... And in other rooms the digital tv works as well on other TVs.
Is the Digital tuner gone ?
I have a Pioneer 60'' plasma and with the price paid I dont expect this kind of issue !!
  • pierre_londo Oct 12, 2009
    Thanks dish Fitter, Unfortunatelly I retune it before and everything was fine (Everybody had to do it in UK ). I did it one week before it went wrong. It was perfect...
    Maybe the tuner in teh TV is broken....
  • 325 Answers
It may just need to be Re-tuned.
What I would suggest you do is make sure that you are on a DTV channel on your Tv. then with your Pioneer remote press the menu button and then set it away on a Auto tune.
You must have it on a DTV channel first before try to tune as if you mistakenly have it on TV (terrestrail channel) It will only Auto tune that and not your freeview.
Hope you get it sorted.
Cheers Little Dish Fitter
Posted on Oct 06, 2009
What causes DTV mode to not work.
why do you want to use dtv mode anyway . if everything else works .
Oct 30, 2015 | Vizio P50HDTV10A 50 in. Plasma HDTV
How do I connect my PS3 to my sanyo dp50747 in hdmi? I have everything hooked up correctly, but its not coming up on the TV. What do I do?????
If you see a no signal message, then it means that the signal output format of the PS3 does not match . It happens if you have previous used it on another tv and now connected it to a different tv. To resolve this, turn off the PS3 . Press and hold the power button on the PS3 till you hear three BEEPS. The PS3 should automatically detect the tv's resolution and the initial setup screen should appear. After that you should just follow on-screen instructions to set it up.
Sep 26, 2011 | Sanyo DP50747 50 in. Plasma TV
How do I connect my Sansui 6010B VCR with an analog TV and a DTV tuner?
two ways of connecting VCR with Analog TV with DTV tuner.
DTV tuner (RF) output to VCR (RF) input,VCR (RF) output to analog TV (RF) input.
turn DTV tuner on (VCR should have a TV\VCR switch that makes signal coming from tuner BYPASS VHS right into TV) note:: change channel FROM tuner.You should be able to record by placing a blank tape and pressing RECORD.
2ND. DTV tuner, VCR, should have a RCA in\out connections...Audio & video.You need a RF\RCA bypass switch. It has a INput with RCA connections to a RF signal out that goes to the RF Input of analog TV
Jun 21, 2011 | Sansui VHF6010 VHS VCR
How do i get 1080i, my tv shows im only in 480i. i think i might have it hooked up incorrect. my other tv of another brand is much newer so all i did was connect the hdmi cable from the tv to the cable box...
Hello
Your TV will display all High Definition signals as 1080i True HDTV™ and all standard definition signals will be displayed as 480p.
Component Inputs 1-2
YPbPr(480i/480p/1080i)
These inputs can be used for the connection of A/V equipment with component video outputs, such as a DVD player or external HDTV receiver. Please see Appendix B for signal compatibility.
Input DTV (480i/480p/1080i)
This input is used to connect an external DTV receiver, and can be configured for YPrPb and RGB plus H&V signal types.
As a special feature, you have the ability to adjust the red and blue light beams in reference to the fixed green light beam. This process is called convergence. There are two separate memories for convergence. One, for SD 480i/480p signals; the other for HD 1080i signals. SD convergence should be adjusted while watching an SD source and HD convergence should be adjusted while watching an HD source.
Wide Expand: Enlarges the picture, cropping some of the image on both sides. This Expand format is useful to remove or reduce black side bars on HD broadcasts of 4:3 images with black bars. Available for analog 1080i, digital SD 16:9 and digital HD signals.
InputDTV
This input is compatible with most standard DTV and satellite receivers with component video (YPbPr) outputs. Compatible DTV signals are SDTV 480i/480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Please check the DTV receiver specifications before connecting.
This input is compatible with some DTV receivers using RGB with "separate H and V sync". Compatible DTV signals are SDTV 480i, 480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Industry standards for DTV RGB signals (systems, synchronization, timing, and signal strengths) are not currently established. These inputs will not be compatible with all DTV receivers that offer RGB, HV outputs. RGB, HV signals with less than 5 cables are not compatible.
If your DTV receiver offers both DTV component video signals and DTV RGB, HV signals, we suggest you use the DTV component video signals. Check the DTV receiver specifications before connecting.
Ok.
Feb 05, 2011 | Mitsubishi WS-73909 73" Rear Projection...
STB won't work, TV works well without it
Blue screen means tv is not getting signal. Either stb is not working or you are not connected to it correctly; check the cabling.
Feb 05, 2018 | JVC AV-27S776 TV
Digital Signal on my Conia TV has gone. Cant access menu for DTV
I would guess that you are using either cable or satellite for reception. If that is the case, the signal is already a "digital" one. The digital reception you are attempting to receive is the over-air broadcast signal that was implemented recently. This change-over only effected those using external antenna connections. Cable and satelite systems have not changed.
Hope this helps,
Dan
Jun 18, 2009 | Televison & Video
Have a vizio lcd tv . can not get any channels today with the switch over to digital. i use an antenna
Your TV probably does not have a digital tuner connected to the DTV/ANT input. Mine didn't. I had to connect the digital antenna to a digital converter box THEN go to the DTV/ANT input. Only then would it activate the DTV menu and allow me to scan for channels. If your TV worked fine with Cable TV connected to the input, it was because your signal was coming from the digital tuner in your DVR, or your cable provider was sending you an unscrambled digital signal (not likely).
I used a digital converter box I had purchased with the government $40 coupon back in 2009 but the resolution is only 480 and looks like a Monet or Renoir. Now I am shopping for a high quality tuner.
Jun 13, 2009 | Vizio L32 32 in. LCD HDTV
No Signal
I give up trying to get this to work. This thing is a joke. We will just go purchase an American made Digital tv today. The "800" that came with the DTV converter was answered by someone who didn't give a **** about helping anyone. What a waste of time and money.
Jan 17, 2009 | Televison & Video
Not DTV ready?
it meens the tv set is in dtv and the dtv conection is not set up.
hd tv is a red blue a green cable.
and the antena conection needs to come from a converter box if signal is coming from antena if from sat or cable you should have a hd box that feeds your set.
hope this helps.
daniel.
Jan 13, 2009 | Panasonic CT-27SC13 27" TV
Parental Control Lock keeps blocking
I have the same tv and the only way to stop it going in to parent safe mode is to get a better signal or use a external source (Digital tuner, Cable box, etc.)
Dec 20, 2008 | Mintek DTV-173 17 in. TV/DVD Combo
Televison & Video Logo
382 people viewed this question
Top Televison & Video Experts
