Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Water is coming out of the bottom of the washer when the washer is filling. I believe it is the pump, as all the hoses look okay, what pump do I need to order to replace the pump and where can I get it?
    President:
  • 1,304 Answers
Part number 3363394
you can order it drom sears
it runs around 50 bucks
Posted on Oct 06, 2009
  • milten1
    milten1 Oct 06, 2009
    part number 3363394
WHY IS WATER IS LEAKING FROM WASHER?
you just have to pull it out and take back panel off start filling with water and watch and see where it coming from a few rubber hoses under there or water pump.
Jul 30, 2014 | LG WM2016CW Front Load Washer
Where would the water come from if it is draining from the bottom of the washer when trying to fill tub
more than likely the pump is cracked and as it fills its leaking out. If I had the model number off the machine I could give you a better answer
Jun 05, 2012 | Washing Machines
Water is leaking from the bottom of the machine and will not fill up
Your water leak can come from 3 areas:
1) drain hose on back of washer is coming off / splitting / getting loose
2) water pump is leaking (cracked?) or has a gasket that has deteriorated.
3) hose between tub and water pump has come off / split / became loose.
Since your washer isn't able to hold water, it makes it easy to remove the clothes, and lean the washer forward to see what is going on. Most washers' mechanicals can be acessed from either the bottom, or from the back via access panel. The water leaks are generally a pretty easy repair.
Sep 18, 2010 | Admiral Washing Machines
Older model washer, water coming out under the washer
hose could be leaking going to your pump there are two attached to it, also the pump has a seal where it connects to the motor could be leaking there, and there is a tub seal. but it does sound like a hose came loose
Feb 10, 2010 | Washing Machines
Leaking from bottom as soon as washer fills
I would request you to pull the washer out and tip it back so he can check the hose connections to the water drain pump in the bottom of the washer. That pump should have two hose connections. In older machines, it is entirely possible that a hose has either come loose or cracked. If the hoses appear fine, check the pump itself for possible cracks. If all looks well, check the hose clamps for tightness.
Thank You for contacting Fixya.com
Aug 03, 2009 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
Leaking wash machine
Depending on where exactly the leak is coming from, it could be a drain hose, drain pump, or tub seal. If this is a top-loader, here's how you can tell:
1. If the leak is coming from the BACK area under the washer, this can be caused by a leaking fill hose, dispenser hose, drain hose, or fill valve.
2. If the leak is coming from UNDER the center area of the washer, this could be your tub seal, a crack in the tub, or an air dome hose leak. NOTE: If the air dome hose is leaking, the washer will fill continuously and not turn off.
3. If the leak appears to be coming from the FRONT under the washer, this could be your drain pump, or drain hoses.
Posting a model number, could assist with determining how your washer is configured. I suspect you may have a drain pump leaking as this is the most common cause, but I want to be sure.
Apr 27, 2009 | Washing Machines
Water Coming out the bottom of the washer
lean washer back and ck pump for gray area on white pump back probably hole in pump
Jul 21, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing machine Whirlpool Lsn1000pq1
My washer is doing the same thing. I put it up on blocks so I could see where it was leaking from. On mine it was leaking from the pump which a big white piece of plastic in front of the motor. The pump has two hoses connected to it the **** the water out of the tub and pump it out the drain hose. Disconnect the two hose clamps, remove the hoses (use force). There are two spring clips on top and one bottom. I laid mine on it's side to remove them. There two slots one top, one bottom for you to use when prying the clips off. Place screwdriver under clip and between grove and push/pull until they come off. Carry pump to the sink, fill with water and see if it leaks from somewhere, should be obvious.
Jun 01, 2008 | Whirlpool LSN1000LW Top Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
62 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
