Question about HP TouchSmart IQ770 PC Desktop
Can not install vista on it,i have formated hdd and have recovery disk but it's freez when completing installation,checked ram-good,changed dvd-rom drive for different one. it would install xp but pc has vista key and i have recovery disk for vista?
    Problem Solver:
  • 7 Answers
Please change SATA native support setting in u r boot menu and then try for setup .........Ur setup will be successful this time .....It's sure
Posted on Oct 06, 2009
I have a mercury board kob p4266ndfsmx, with intel processor and 1 gb ram, dvd writer is working fine, problem is im not able to boot from cd rom even if i choose cdrom as 1st boot device, i have check...
sometime there are an option in the BIOS setting to boot directly on HDD when there are a OS installed try to invert primary and secondary controller (invert HDD and CD-ROM wire on the motherboard)
Nov 29, 2012 | Mercury P4VM800M7 Motherboard
RM Z91FR laptop I want to remove the windows "Vista Ultimate" operating system and go back to XP Vista has slowed the machine drastically and filled the HD. I also want to instal a larger HD...
try to format all your drive by deleting your partition..insert your xp cd room boot with cd room press enter, press f8 press esc, press d, press l, then press c and enter
May 06, 2011 | ASUS Computers & Internet
I am using HP Pavilion DV6767tx.i lost my recovery disks and my hp recovery also does't work my notebook does not start i want to change my os . plz help me
Try following steps.
Restart the PC, Press Delete for some time
It will lead you to BIOS setting
Go to the Boot Priority menu,
select DVD ROM as First Boot and HDD as Second Boot
Now Insert your Operating system CD
Restart the PC and when screen says " Press any key to continue"
hit "enter"
Let the CD load and then select New Installation
format whole HDD, craete a partition and then install the OS of your choice. ,
After complete OS loading, system will restart and again you will see " Press any key to continue"
DO NOT PRESS ANY KEY.
Let it complete the installation an dthen you are good to go.
Sep 05, 2010 | HP Pavilion N5415 Notebook
Spilled water on keyboard of Sony VIAO VGN-FW250j and crashed HDD. Get system not found at startup. Replace HDD and get error:333 when loading recovery media kit. All hardware checks OK by Bestbuy geeks...
unfortunately water has a way of finding it's way into the circuit board, when it does it causes immeasurable damage, as parts of the circuit, and components that were not meant to get voltage are exposed to it, this generally ruins the machine's motherboard, with little chance of recovery. The HD may be OK as may be the DVD however anything electronic will generally be ruined,sorry. A recovery DVD is only good for SOFTWARE, problems... you have a hardware issue.
Mar 01, 2010 | Sony VAIO (PCWA-A200)
Windows unable to complete format.
How did you format the computer, inside windows or outside?
Try this change the boot sequence from the BIOS instead of booting first to HD make your optical drive as first boot. After changing the boos sequence insert the windows vista disk to the drive then restart the computer. When it boots it will ask you to press any key to boot to CD/DVD. Keep tapping on space bar. If you notice it will say windows copying files. When copying files completed we isolated the problem dvd rom is fine and the vista installer is fine as well.
If the problem only started in or during attempting to format you HDD might causes the problem.
Nov 10, 2009 | Dell Computers & Internet
Replaced HD and CD Rom drive, PC will not boot to disk, Do I need to format HD 1st. before loading OS?
Hi Get to the bios screen using F8 or F9, change the first boot device to CD ROM/DVD, then insert a bootable disk into the CD drive and try installing the OS first by completely formatting the HD during installation Win XP and higher OS editions give you the option to partition the HDD Hope this resolves
Nov 05, 2009 | IBM ThinkCentre S50 8183 - P4 3 GHz...
Vista installation problem.
Make sure that your CD/DVD drive is set as the first boot device in BIOS, then insert the Vista setup cd and reboot. Installation should now be automatic.
Oct 06, 2009 | HP TouchSmart IQ770 PC Desktop
Computer wont boot properly
A POST diags card can help you resolve your problem/s, if not then.
1. remove all devices and insert the floppy drive, one RAM module and video card.
2. Go into the BIOS configuration and set it to the default configuration, check the installed RAM is it correct? .
3. Insert the remainder RAM module/s and check the POST info and BIOS again, has it detected all the RAM?
4. Does the computer Boot up using a floppy boot disk
5. Insert the CD and hard disk and check the POST info and BIOS configuration, does it detect the new drives?
6. Does the computer Boot up using a floppy boot disk, run FDISK, can you see the hard drive, if so delete all partitions (if any) and create a new primary DOS partition and then format the hard drive.
7. Boot up with the Windows CD (may have to change the boot order to the CD as the first boot device).
8. Delete the DOS partition, create a primary NTFS partition and the do a full NTFS format (not a quick format) and continue to install Windows Xp or Vista.
9. Install the other device eg modem, Lan etc. and the drivers.
If you have trouble with the first 5 steps, then you most likely have a faulty motherboard and/or a faulty hard disk.
Sep 11, 2009 | Computers & Internet
IBM NetVista M41 PC Desktop Os Install Impossible
You probably need an OEM version of XP...not that IBM version. If you buy an OEM version, you can use it many computers. A real XP disc will partition, format, and delete partitions on any functioning Hard drive. Don't buy a recovery disc, please. That just sounds WRONG.
A cheaper solution might be a new Hard Drive...but I don't trust your IBM version of XP.
Apr 07, 2009 | IBM NetVista PC Desktop
Hd on my satellite L305-S5891 blue screens after clean install
hello , friend its very easy to do that, steps are
1. insert bootable cd/dvd VISTA.home premium DVD.
2. Boot from tht cd and start the installation. 3. Format the whole HDD and create new partiotion as there is facility of doing this before installing. 4. Remember format whole disk. and then go for installations .
3. once it i completed install all video, audio e.tc. drivers.
4. if you dont have that drivers pls download it from toshiba site by entering the toshiba serial no
Mar 25, 2009 | Toshiba Satellite L305-S5894 Notebook
HP TouchSmart IQ770 PC Desktop Logo
78 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
