Question about Garmin Gpsmap 4208
Garmin 4208 installation with accessories
I am about to install my Garmin 4208 unit with the following accessories; depth sounder with transducer, gps antenna, and XM weather antenna. The directions are not exactly clear on how to hook all these items up in the network and hook up the 12 volt power supply to the 4208 and possibly the antenna's. Can I get a schematic showing how to do this including each of the accessories listed?
SOURCE: Depth Sounder does not display depth
I will see if I can get mine off the hull for testing. Still have found no procedure. Thinking about just replacing the sounder with another unit.
Posted on Aug 03, 2008
SOURCE: Sounder transducer?
I believe like my own Garmin I have a 178 which is the mono version, same transducer though, you alter the frequencey setting in your main reciever set up program.
Posted on Sep 26, 2008
SOURCE: a65 Raymarine combo gps plotter fishfinder
changes.
Posted on Jan 09, 2009
adam_baker27
  • 9 Answers
SOURCE: troble2
Hi, my name is adam and i would love to graciously help you. In your description you stated you need a wiring kit. I have a link included from ebay and you can go on there and hopefully find what you need. http://shop.ebay.com/items/?_nkw=A65+Raymarine+&_sacat=0&_fromfsb=&_trksid=m270.l1313&_odkw=A65+Raymarine+fish+finder+wiring&_osacat=0
SOURCE: SISTEM SOFTWARE MISSING on my Garmin NUVI200 GPS
All Garmin users,
There is no easy solution for this except to return your unit to the nearest Garmin outlet. You need to have very special equipment called an E-Prom burner or writer which only Garmin have. With this equipment they re-programmed (restore) the operating system back on your specific Garmin unit and model.
The problem why anybody can't do it is because there is no way you can access your Garmin unit from a pc or mac if the operating system is lost or damage on your Garmin, for the simple reason your pc or mac can't reconize the device that is pluged in, because there are no communication platform between the two devices.
As simple as that, life with it or send your Garmin gps to an autherized professional Garmin dealer.
Marius Oosthuizen
Garmin dealer
South Africa
Posted on Mar 23, 2009
Garmin 4208 Marine Transducer Problem
You either have a faulty head unit, bad connection between the transducer and head unit, or a faulty transducer or transduced cable.
Jul 19, 2013 | Garmin GPS
..no depth reading. Old transducer cable was
Hi, Check for debree on depth sensor under boat. As you said check for fuse(s) Good luck.
Jun 20, 2011 | Garmin 185 Sounder GPS Receiver
I have a Garmin 182c with a garmin GSD20 sounder unit ,if my transducer wire is cut or nicked would it cause the unit to unit to read " sonar turned off" ?
If you nicked it good enough yes it can. If the receiver doesn't detect the transducer, a digital message on the display will indicate this.
Mar 18, 2011 | Garmin GPS
My Garmin 498C will not show the contore of the bottom or give me a depth reading. The GPS works and will show me charts but, not the sounder option though.
You need to check to see if the depth sounder transducer is connected or functioning. It might be turned off, the connectors may be bad or the transducer is bad. I don't have the 498 manual in front of me but I think there is a test function under the setup menu. I'd check my connections (the usual suspect) then run that.
Garmin tech support is pretty good/quick. So don;t be afraid to give them a call.
Aug 29, 2010 | Garmin GPSMAP 498C Sounder GPS Receiver
I have a gps Map 498-depth sounder not working? Have new transducer from Garmin-it flashes "00"-it is not connected to boat yet (transducer)-need it be or can I put in a bucket of water (need it be in...
If the transducer is out of the water, you will not get a reading and see the flashing depth. You should hear and feel the clicking in the transducer when out of the water and working properly. Are you getting a temp reading when out of the water?
May 16, 2010 | Boating
Unable to track the bottom
I think you need to level the transducer. You have it pointed way out in front of you so that when you're going fast it is able to bounce the signal off the bottom and it comes back to where the boat has traveled to. When you're going slow you're bouncing it out in front of you but it comes back up in front of you. Sorry but I can't find a picture of a Garmin transducer. Hope this helps.
Jun 02, 2009 | Garmin Gsd 21 Sounder Blackbox Fishfinder...
Sounder transducer?
Sep 11, 2008 | Garmin 200/50khz, 10/40deg, Plastic,...
Garmen 240 fishfinder
A test bucket wont work, A 200 khz transducer will generally not work in anything less than 2' of water, due to surface clutter. If the transducer is working, you should hear it make a ticking sound.
When you got the 17000 foot reading was your range set to auto?
How is the transducer situated on the boat? Sometimes turbulence and bubbles from the hull can cause erroneous readings, including unrealistic depths, or no depth at all. Stop the boat and turn off the engin e and anything electrical to see if problem repeats itself. If it only crops up when the boat is moving then it is most likely the transducer location.
Jul 26, 2008 | Garmin GPSMAP 235 Sounder GPS Receiver
Jul 05, 2008 | Garmin 185 Sounder GPS Receiver
Navman 4150 fishfinder
Depth: Could be for a number of reasons, too deep for the sounder - check the manual for it's max depth. Dirty water, sounder unable to penetrate through to the bottom. Weed or other debris covering the transducer. Transducer on a swing mount & being pushed out of alignment then dropping back in once stopped.
Speed: Is the speed readout controlled by a GPS or paddlewheel? If it's GPS, check the power connection of the sounder, may be loose which would also cause the depth to 'drop out'. If it's paddlewheel, you're down to bad connections or faulty unit.
Oct 16, 2007 | Navman Fish 4150sx GPS Receiver
Garmin Gpsmap 4208 Logo
117 people viewed this question
Top Garmin Boating Experts
Mohamed Ismail
Mohamed Ismail
charles
Are you a Garmin Boating Expert? Answer questions, earn points and help others
