Question about Cameras
Olympus camera m760, can I change the shutter speed and aperture on it and how?
dlundmark
  • 797 Answers
SOURCE: Canon Rebel XT I can't change aperture or shutter speed in manual mode
You may try this. Reset all in the menu setup.
What you will be doing to to reset all the settings back to factory settings. Then you will want to go through the settings and reset them the way you prefer.
Posted on Aug 24, 2008
  • 9 Answers
SOURCE: Manually setting shutter speed and aperture..
http://web.canon.jp/imaging/eosd/eosdigital4/specifications.html
First off, welcome to the world of photography! Good luck and have fun!!!
Like any slr, you have the option of Manual exposure. I'm not familiar w/ modern Canons (I use Nikon). According to this page, however, you also have aperture priority and shutter priority. I'm pretty sure ALL modern Canons have bracketing modes as well (Use this for HDR).
I couldn't find the 450 manual (I'm assuming Canon's web devs are behind), but I did find the instruction manual for the 400 :
http://gdlp01.c-wss.com/gds/0900000357/EOSDRXTi400DIM-EN.pdf
Should be similar, probably w/o some of the functions. Although you SHOULD have a book w/ your camera ;). Read it thoroughly.
Ok, according to the 400 manual, put your camera into Manual mode, then adjust the regular dial to adjust shutter speed. Then, to adjust aperture, hold in the A/V button while you adjust the same dial.
Like I said, may be a bit different. I think the dial may even be digital buttons rather than analog...
hope this helps!!!
Posted on Nov 22, 2008
SOURCE: Aperture and Shutter Speed for the Nikon Coolpix s550
Go to the shooting menu and then press the ISO sensitivity option
Posted on Feb 22, 2009
  • 919 Answers
SOURCE: adjust shutter speed
On most indoor shots the shutter speed will normally be 1/30 if you need or want it to be faster than that the only way to do that with this camera is to set the ISO to a higher value. Page 29 of your user manual explains how to set the ISO value for the camera to allow for faster shutter speeds.
Posted on May 04, 2009
SOURCE: Apperture and shutter speed settings
First select AV (Aperture Mode) to select the required aperture then switch to M (Manual Mode) and spin the wheel until you get the right speed.
Spurs34
Posted on Jan 22, 2010
How doI set up f11 on this camera
Do you mean set the aperture at f/11?
If you want the camera to set the shutter speed for proper exposure, turn the mode dial to the A position for Aperture Priority. Press the +/- button to display the shutter speed and aperture. Press cursor-up/down to change the aperture and the camera will change the shutter speed to give the proper exposure.
If you want to set the shutter speed and aperture yourself, turn the mode dial to M for Manual. Press the +/- button. Press cursor-up/down to set the shutter speed, cursor-left/right to set the aperture.
Full details are in the Shooting Mode section of the manual.
Nov 17, 2013 | Fujifilm FinePix S4250 Black 16MP Digital...
Can i change shutter speed on my camera?
Not much. The D-540 is designed as a point-and-shoot camera, which means you're supposed to just point and shoot, without bothering about such minor details as the shutter speed and the aperture.
You have some control. For example, the Portrait mode will attempt to use a wide aperture to reduce the depth of field, which will result in a faster shutter speed, while the Landscape mode will attempt to use a smaller aperture to increase the depth of field, which will result in a slower shutter speed.
More sophisticated (and heavier, and more expensive) cameras will give you more control, but this is about all you're going to get with most point-and-shoot cameras.
Sep 13, 2013 | Olympus Camedia D-540 Zoom Digital Camera
Olympus d 540 digital camera
Sep 13, 2013 | Cameras
How do you set the aperture and shutter speed independently
First, make sure you're in the manual exposure mode, not manual focus mode, as set by turning the mode dial to the "M" position.
In manual exposure mode, turning the main command dial should change the aperture, while turning the subcommand dial should change the shutter speed.
If the two command dials don't have the expected effect, reply to this post and we can troubleshoot further.
Feb 20, 2012 | Olympus E-1 Digital Camera
I have my Olympus FE-160,the problem is whan I take pics,it came out all blurry and the color changes...am not sure whats going on?is there any way that can be fix?
HERE'S THE ANSWER TO YOUR PROBLEM:
The three possible culprits of your camera are the following:
1. Long Focal Length
2. Slow Shutter Speed
3. Wide Apertures
Here's what you've got to do:
1. Increase your shutter speed so that it is greater or equal to 1 over the focal length.
2. Attach the camera to a tripod to avoid camera shakes.
3. Keep your shutter speed to 1 / 60 - 1 / 125 when holding the camera in your hands.
4. Keep your aperture around f8.0, especially with along focal length.
5. In case, you buy another camera model, see to it that the camera is featured with image stabilization (IS) technology.
Thank you. Your problem is solved...
Jul 10, 2011 | Olympus FE-160 Digital Camera
Where do I adjust the aperture on my Olympus 725Sw?
I've gone through the manual, and i don't think you can. Many simple point and shoot cameras have just one fixed aperture. In the manual, the only thing i found was on page "10. P (Program auto) The camera automatically sets the optimum aperture value and shutter speed for the brightness of the subject."
Apr 08, 2011 | Olympus Mju 725 SW Digital Camera
How do I change the shutter speed on the Fuji S8000fd
Set the camera to Shutter Priority AE by turning the mode dial to S. Press the +/- button to open the setting screen, then press up/down to select the shutter speed.
You control the shutter speed the same way in Manual mode. You also select different shutter speed/aperture combinations the same way in Program mode.
You can indirectly control the shutter speed in Aperture Priority AE by changing the aperture and letting the camera set the appropriate shutter speed.
May 27, 2010 | Fuji FinePix S8000fd Digital Camera
How do you change the shutter speed on the finepix s5500?
That depends on the selected shooting mode.
In Program AE, press the exposure compensation button and then up/down on the 4-way button to change the shutter speed/aperture combination.
In Aperture Priority AE you can control the shutter speed indirectly. Press the exposure compensation button and then up/down on the 4-way button to change the aperture, and the camera will adjust the shutter speed to suit.
In Shutter Priority AE press the exposure compensation button and then up/down on the 4-way button to change the shutter speed. The camera will adjust the aperture to suit.
In Manual press the exposure compensation button and then up/down on the 4-way button to change the shutter speed. You'll have to press left/right on the 4-way button to select the appropriate aperture.
Mar 08, 2010 | Fuji FinePix S5500 Digital Camera
How to KNOW the light is right 4 an Olympus OM20 Manual camera?
OM-20 was basically a upgraded OM-10 with the manual adapter built in and a number of other refinements.
The viewfinder has LED's to show the shutter speed recommended by the camera's lightmeter for the ISO and aperture selected. It also has an exposure compensation indicator (the +/- symbol) and an indicator for flash ready which doubles up as a post-exposure flash confirmation. There is also the indicator lamp to show manual mode has been selected. OM-10 lacks the manual mode lamp and the +/- indicator.
Like the OM-10, the OM-20 is primarily an aperture priority automatic camera. In this mode you set the ISO film speed, choose which aperture you wish to use (with the ability to use the lens depth of field preview button) and then the camera selects the correct shutter speed. The +/- exposure compensation control allows the user to tell the camera to modify the recommended shutter speed by up to two stops either way.
In manual mode, there is no manual metering. The light meter behaves exactly as it does in aperture priority mode and the viewfinder shows the recommended shutter speed and not the manually selected one. Correct metering is therefore a case of adjusting the aperture first, and then choosing the correct shutter speed indicated in the viewfinder. If the user then decides to select a different shutter speed, then the aperture ring must be adjusted to maintain the correct exposure. For example the aperture is set to f8 and the camera recommends 1/60th of a second. The user decides that a faster shutter speed is required and chooses 1/250th, but the viewfinder remains showing 1/60th. In order to keep the same exposure value the user must open the aperture by two full stops to f4. The camera's light meter will detect the new aperture setting and providing the light on the object is unchanged the viewfinder shutter speed display should now show 1/250th as well to confirm the correct adjustment. Alternatively, the user can choose the shutter speed first by looking at what has been set on the control ring (or by turning the ring to the end of its travel and then counting the clicks from there as all experienced OM users do) and then turning the aperture ring until the shutter speed shown in the viewfinder matches what's been manually set.
It all sounds clumsy and complex but is done far more quickly than I've taken to type this and becomes second nature.
Aperture priority metering is selected on the camera by choosing AUTO on the mode selecter. In this mode the shutter speed ring has no effect and the viewfinder always displays the automatically selected shutter speed.
May 09, 2009 | Olympus OM-2000 35mm SLR Camera
I have an olympus stylus 850 sw, and i want to know how to adjust the aperture on the camera
This camera has a fixed lens and there is no way to change the aperture for the camera. It is a simple point and shoot model camera. The camera whether in Auto or Program mode will determine the best aperture and shutter speed to use based on the lighting conditions you are shooting in.
Sep 25, 2008 | Olympus Cameras
Cameras Logo
99 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
