Question about Olympus FE-280 Digital Camera
When I try to open olympus master, there is a message that flashs on the screen "checking for updates" ...........and then it closes down
4 Suggested Answers
  • 479 Answers
SOURCE: Software (in use since 12/07) won't open
the software default location is in my pictures/olympus master 2/year/month/day
you will need to call olympus support for them to help correct your problem... could be due to virus protection program changing your program around
Posted on Sep 03, 2008
SOURCE: OLYMPUS Master.exe has encountered a problem and needs to close
1. identify wich copy of mfc80u.dll in the WinSxS your Oly Master is using. I did this renaming one by one and running the Master 2 to see if it continue to run or not.
2. Once identified the folde (mine was C:\WINDOWS\WinSxS\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.922_x-ww_3cf1180b), copy the mfc80u.dll from the OLYMPUS Master 2 folder to the corresponding WinSxS folder
3. The Master 2 should run fine now
Posted on Apr 09, 2009
  • 919 Answers
SOURCE: Olympus Master has stopped working
A call to Olympus tech support may be needed if this is still an issue for you. The phone number is 888-553-4448. Our technicians will be glad to assist you. Our hours here are 8am to 10pm eastern time.
Posted on Jul 28, 2009
Olympus Master 2 Software gets Microsoft Error Message
This is solution for you:
http://www.fixwindowserror.org/Olympus_Master_2_Error_Message.html
Apr 19, 2009 | Computers & Internet
I am running Olympus master 2 on Windows Vista. When I try to "launch mailer" after selecting 6 photos to send via email, I get the error "failed to send e-mail".
By the way can you send regular picture/image attachment using that same email that failed to send the image created from Olympus master 2? Did you also check the file of the image maybe its too ;arge and try also to close the Olympus master 2 then open it back up and send the email again..
Aug 12, 2008 | Computers & Internet
Jan 29, 2009 | Olympus Stylus 710 Digital Camera
Jan 12, 2009 | Olympus FE-280 Digital Camera
I have an Olympus MJU 700 but the flash is not working
I want you to check these,
Check that batteries are fresh.
Check that camera hasn't been set for no-flash mode.
Give the flash time to charge before pressing shutter.
Try to reset your phone by MASTER RESET(Factory reset) by referring to your manual.
If you updated the firmware for your camera, then that update can also be a reason for your flash not working. so try installing the firmware which was present when the camera was working good.
check there is any debris in the hot shoe, there is a switch on the left that stops the pop up working when you put a external flash on.
If you have been using a speedlite or another flash on the hotshoe lately, there is a little metal strip in the hotshoe (rail) that disables the pop-up built-in flash. So, this little metal strip goes down when you slide in an external flash and disable the built-in flash by breaking an electrical contact. This little metal strip has the occasional tendency to get stucked down after unmounting your speedlite, which results in the behavior you are seeing. Just turn OFF your camera and use a toohpick in the hotshoe and force very gently the metal strip up to make the metal strip goes back to its original position when there is no speedlite mounted on your camera. Compare both sides in the hotshoe (rail). Turn it ON and there you go!
Hope my info solves your problem,
Thanx for using fixya,
Cheers.
Sep 28, 2008 | Olympus Cameras
Sep 03, 2008 | Olympus FE-280 Digital Camera
Can't transfer photos
Remove the Camera software'
Windows does not need it- it can do it all by its self.
Jul 17, 2008 | Olympus Stylus 710 Digital Camera
Olympus E-300 Evolt - LCD Screen doesn't come & SSWF light stays on
My camera is working again, but the problem is not completely solved. What I did was to put on the old lens, take out the battery then turn on the camera and finally put on the battery again. And now it works. But the problem with the new lens (Zuiko digital 40-150) continues.
Jun 30, 2008 | Olympus EVOLT E-300 Digital Camera
Master Software 2 help!
Ditto. Installing on XP w/SP1. Plenty of hard drive space. Pentium 4 w/2GB RAM. Tried different drives. Tried copying CD-ROM to hard drive to verify it was reading of the CD ok. No problem copying but still failing on installation. I also tried by-passing the initial Olympus menu and launching the .msi directly, but that fails in the same way. I haven't found anything on the Olympus website about this, but note their website generates tons of Javascript errors which is not encouraging with respect to Olympus's attention to quality. (This is my first and probably last Olympus.)
Tried pulling the XD media and reading it on the computer but my computer wanted to format the thing (never seen that with SD or Compact Flash, what gives?) so that was a no for the moment.
Finally, I went to the files that I had copied from the CD to my hard drive and double-clicked the OM2_Pack_Framework_2_0_4.cab file found in the OLYMPUS\OLYMPUS Master 2 directory. That contains a bunch of .cab files, that I extracted to another directory. In there, I found a application.cab, which I then extracted to yet another directory. In there, I found OLYMPUS Master.exe. That ran fine when I double clicked on it, but I still had the problem of not being able to read the XD directly, so I hooked the USB up to the camera with the XD back in the camera and was able to transfer the images in that manner.
Apr 25, 2008 | Cameras
Blue screen error code
the lens open halfway, the picture on the LCD is blurry and one second after the lens close and an error appears of the screen saying "D: 5f08 5e02". what does this mean??? can you help me fixed this one??
Oct 13, 2007 | Olympus Stylus 700 / 700 Digital Camera
Olympus FE-280 Digital Camera Logo
23 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
