Question about Bunn VP17-3 Coffee Maker
Hi: My church has a Bunn coffee maker. Judging from the pictures on line, it looks like the VP17-3. We used to have the problem that when it was filling, it would not stop and would overflow the coffee pot. Now when we open the valve on the water line, it fills up VERY fast, and overflows through the top of the coffee maker housing. Is it a simple fix?
    President:
  • 1,304 Answers
Very simple
it a water level switch
common part to all the models and readily available
online from bunn
Posted on Oct 06, 2009
Need the back switch that turns the pot on to brew(carlingswitch) for model NHB
For Service Contact:
Bunn-O-Matic (800) 352-2866
They call it "Vacation Switch"
I work on commercial equipment (including BUNN), and they don't use any names like this one in the commercial line.
Jan 14, 2011 | Bunn NHB Coffee Maker
Coffee starts dripping down before I can get the water all poured in and the pot on the warmer, causing a mess.
This is common with bunn coffee makers, if you are not fast enough, coffee starts dripping. The only solution I found is to use a water pitcher, first fill coffee pot to cup mark you are using, then pour into pitcher, put pot back on machine, then pour in water. You can mark a line on picture, so you know where to fill to each time.
Jul 15, 2010 | Bunn NHB Coffee Maker
BT10B Coffee Maker: When I use Dunkin Donuts coffee in my Bunn coffee ...
Dunkin Donuts is a finer ground coffee and the water comes through so quickly that it isn't absorbed quick enough so you don't get the full flavor and it causes an overflow. If you will call Bunn Customer Service, a new flow restrictor can be sent to you to resolve this problem.
May 17, 2010 | Bunn BT10B Coffee Maker
Cleaning
To clean the pump pot, use purocaff, add a teaspoon of the soap to the pump pot then fill with warm water, let sit for about 1 hour, then use a brush to clean.
Apr 25, 2010 | Bunn CDBCF 15 APS Coffee Maker
Resevoir tank not filling
If you will get the model and date code located on the bottom of the unit and contact customer service, we will be able to help troubleshoot and resolve your issue.
May 11, 2009 | Bunn NHB Coffee Maker
Bunn ST15
Bunn's official position is that this brewer must be hooked up to a water line. The problem with using these as a pourover is the evaporation of the water. it doesn't take much of a loss of water to burn out the element in those models.
Feb 14, 2009 | Bunn NHB Coffee Maker
Dont know how to use coffee maker
Hi this is tech crazy
The above link u will get the whereabouts of a coffeemaker and its usage
http://home.howstuffworks.com/coffee-maker3.htm
Kindly do rate me on the above said solution
Feb 03, 2009 | Bunn NHB Coffee Maker
Bunn Cooffee Maker is not making full pots of coffee
I would ask if this machine has been moved lately- for cleaning or has anyone put anything new around the brewer? If someone has moved this brewer, they might have caused a kink in the line coming to the back of the brewer. this will restrict the water flow to the brewer. this will cause the brewer to brew only part pots of coffee.
Nov 13, 2008 | Bunn NHB Coffee Maker
Instructions for bloomfield 8752 same as 8571?
I have a 8571. Bought it used. No instruction Manual. Plug it in, turn on the left burner, poor in water water immediately drains through. I that a valve problem?
Oct 23, 2008 | Bloomfield 8571 Coffee Maker
Bunn VP17-3 Coffee Maker Logo
180 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Jim Y
Jim Y
pawnpower
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
