Question about Elite Manual Series Pulldown Projection Screen Projector Screen
The pull-down screen in stuck at the furthest down point. Please help
Be harsh on it. Yank it down and try to get it unstuck.
Posted on Sep 29, 2012
I have. 93 Fatboy I put on Avon grips for some reason the throttle gets extremely tight even with the cables completely loose as soon as I tighten down the housing...I can't figure it out and it&#
you havent mixed the return cable with the pull cable, if you have would explain as throttle is already near furthest open point and will be trying to push case open
Feb 14, 2013 | 1993 Harley Davidson FLSTF Fat boy
Blade reciprocates then constantly stops.When it stops is just revs and doesn't move. If I pull the blade to it's furthest extension point it works for a moment and then stops again.
you have a problem with the gear/pinion stripped or missing teeth and when you pull it out temporarily it engages in a spot where there is little damage. You didn't specify what brand or model it is but usually the parts are close to the price of replacing the tool.
Sep 19, 2011 | Craftsman 85 reciprocating saw 926770
Does it matter what wheel you bleed first on a kia sedona 2002. I have told by a friend to bleed the passenger rear 1st the driver rear then passenger front then driver front is that right.
When bleeding brakes always start at the furthest point from the master cylinder. So start at the passenger's rear and then the next furthest point, the driver's rear, then passenger front and last driver's front. Hope this helps.
Sep 19, 2010 | 2002 Kia Sportage
Lens error
Hi, the chances are the motor that operates the lense has quit working or it could just be stuck with some grit, what you can try is this.
if you get hold of the biggest part of the lense and try turning it slightly now not the furthest part out as this just moves in and out but if you try turning the piece that is closest to the camera it may just free it up, try turning it whilst turning the camera on and off you only need to get it to turn slightly and this should free it up. or you could try pushing the furthest part of the lense in or pull it out slightly doing this may free it up also.
you may need to use slight force when trying to turn the part nearest the camera, but if after trying both of these methods it still dont work then this would point towards the motor failing and the only option would be to have the motor replaced, how ever the cost of repair would more than likely cost as much as the camera so you would need to shop around and check if the part was worth getting repaired or not.
Jul 06, 2010 | Nikon Coolpix S210 Digital Camera
I need the firing order & diagram on the distributer cap to the spak plugs
If your engine is a V6 I need to know the size to help you.
If its the V8 engine the firing order should be 1 8 4 3 6 5 7 2 in the order of rotation on the distributor (clockwise) Your model should have the # 1 marked on the cap and as long as no one has had the distributor out and put it back in a little off, It should be where its marked. If its not marked by the hold down for the wires to the cap, then (all things being correct) you should have the number 1 pointing towards the front. Number 1 normally points to the number 1 cylinder. On GM cars the furthest forward head is the Odd bank and the other head the Even bank. So the furthest forward bank would be 1 3 5 7 and the other side of the engine is 2 4 6 8.
I dont have a picture but this explination should help.
Hope this helps you get going again.
Sep 24, 2009 | 1984 Pontiac Grand Prix
My Dell laptop is stuck on Windows Vista Home Basic
Press F8 to go to Safe mode, open SYSTEM RESTORE to go back to checkpoint where not yet updated the system.
And next time to open back your system normally finished all updates before you shut down.
Sep 16, 2009 | Dell Inspiron 1525 Notebook
JANDY RAY VAC won't back up
If you have a back up valve it will be about 18" from wall a small football looking thing this should cycle through about every munite or two and shoot a jet of water out the side of it for about 5-10 seconds if it dosen't do this pull it out of line and get a new gut for it. If this seems to be working ok you should be sure it has enough hose to reach the whole pool but be sure it just reaches the furthest point in the pool so it can strech the hose and remove any curls each time it does.
Jun 14, 2009 | Jandy Ray Vac Pool Cleaner for Inground...
Ethernet cable end repair
Unless you have a RJ45 crimping tool you are stuck with having to ask someone who does have one to borrow it, honestly if you know someone with a crimping tool then ask them to perform the repair.
If however you have the tool for a straight through cable (most common)
Holding the plug upside down (catch towards the floor) and the pins furthest away from you I use the following layout;
orange white (furthest left hand side)
orange
green white
blue
blue white
green
brown brown white (furthest right hand side)
slide the cables into the plug held in the position describe above, then check the order of each wire once more using the crimping tool to "crimp the new RJ45 connection in place.
Basically as long as you hold the rj45 connector in the same position the wires should go into the same corresponding position at each end.
Nov 08, 2008 | Belden 1000 ft. UTP Network Cable
Button stuck
my acer maus it is stok pleasehell me
Mar 20, 2008 | IBM ThinkPad T20 2647 Notebook
Elite Manual Series Pulldown Projection Screen Projector Screen Logo
871 people viewed this question
Top Elite Televison & Video Experts
David Tickner
donshafer
Are you an Elite Televison and Video Expert? Answer questions, earn points and help others
