Question about Cell Phones
My Touch HTC HD keeps shutting down if A) I place it on the table a bit hard B) After putting it in my pocket and going somewhere (and probably after I have sat down) it shuts down... any idea...
  • 10,515 Answers
It seems that there is a loose connection or connectors issue. Remove the battery and again insert it. I have seen if there is an issue with connector, sometimes you when hit it hard or sat on it, it might forces those connections hard and would make cellphone shut off.
There might be an issue with circuit. Again the same basic logic, when yo hit hard, it might make an IC to prevent an electrical circuit to be completed and might make a cellphone shut off.
User Fixable Option - Remove the battery and clean the points. Unless you might need to open the cell to check circuit or look for a local tech to fix it for you.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 06, 2009
I want to unlock htc touch hd
You can Unlock it simple by using the Unlock code,You can get the Unlock code and instructions at here
moz-screenshot-1.pngTheunlockarena and Unlock it...You can follow the instructions below and Enter the code
HTC Touch HD Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your HTC Touch HD mobile phones. If you enter over a certain amount of wrong unlock codes on your HTC Touch HD mobile phone, your phone may get hard locked and sometimes become unusable.
1. Switch ON your HTC Touch HD with a Not ACCEPTED SIM Card.
2. If your HTC Touch HD asks for a PIN code, then enter your SIM card PIN and press OK.
3. HTC Touch HD will ask to enter an "unlock code".
4. Enter Unlock Code we send to you.
5. Your HTC Touch HD is now unlocked.
*NOT ACCEPTED : We mean, to use a Sim card from a network other than the network your HTC Touch HD is locked to.
Jul 29, 2011 | HTC Touch HD Smartphone
Hi, My HTC Youch HD is very slow. Not sure why. how can I solve this issue? Thanks, ash
Use maintenance softwares like DinarSoft MemMaid, Pocket mechanic professional or SK Tools or freeing ram, cleaning invalid registry entries etc..it helps quite a bit...
May 11, 2011 | HTC Touch HD Smartphone
Why my htc hd phone keeps shutting down
There must be some kind of virus in your mobile and need to reinstall the software of the mobile which you can get from local mobile repair show or you can also contact HTC for it as there is no other way
May 05, 2010 | HTC Touch HD Smartphone
Hay,i have htc touch hd t8282.my problem it with
i have htc t8282 now it is stucked on align screen
Apr 20, 2010 | HTC Touch HD Smartphone
I received mail ... but dont send ... Because smtp problem
go to your settings to change what your phone is doing
Jan 28, 2010 | HTC Touch HD Smartphone
If I put my HTC Touch on the table a bit hard it shuts down... If I put it in my pocket "and most times after I have sat down" it has shut down... Any Ideas... my guess is that the battery in disengaging...
Yes i agree with you the bat could be disengaging from the Bat contacts but I want you to get a new housing for the phone sometimes the back cover can be loose as in when u place it hard on the table or pocket it loosens .
good luck
Oct 06, 2009 | HTC Touch HD Smartphone
HTC TOUCH PHONE GETS SWITCH OFF WHEN PUT IN THE JEANS POCKET
it is very simple i hope you select the two option in battery menu option.
in battery menu option following two line are avialable uncheck them.
"shut down if cell not work on internal power"
"shut down if cell not work on external power"
Sep 11, 2009 | HTC Touch P3450 Smartphone
My htc hd is frozing
First take the battery off
Put it back on
Press on the volume button both up and down at the same time
Keep pressing on the volume buttons at the same time press on the power button
Follow instructions on the screen
Jun 20, 2009 | HTC Touch HD Smartphone
Does HTC Touch HD have same issue as my TyTN II?
it's right, during a phone call in HTC HD, the screen may shut down but you can easely turt it on again by presseing the on/ off botton once.
for touch pro, am not sure but it seems to be the version came after HTC HD, so all the problems in HTC HD should be solven in Touch pro.
Mar 17, 2009 | HTC Touch HD Smartphone
HTC Touch HD restart problem
Check the battery connection, if the battery is loose/moves around when you touch it with your finger, try putting a piece of paper on top, or the side, or which ever way it moves. So the battery will still touch the battery contacts. If this isn't the case, try doing a hard reset. Go to start>settings>system>clear storage. (It's like this in my htc diamond, not sure about the touch HD, but should be same) which will erase all data/contacts. Make sure you sync your contacts to your pc to save them!
Feb 26, 2009 | HTC Touch HD Smartphone
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
