Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
Usb is not responding when inserted into laptop (have tried another computer so fault must be in the flash drive)
  • SanDisk Master
  • 32,281 Answers
Files on a flash drive can be corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon and then click on the flash drive you want to remove and then remove the flash drive when the computer message says it is Safe to remove.
To restore the flash drive you may need to format the flash drive, but you will lose the data stored on the flash drive.
If you need the data on the flash drive this program may help: -
Digital Photo Recovery
www.artplus.hr/adapps/eng/dpr.htm
When the flash memory device appears to malfunction it maybe possible to restore it by reformatting it. Insert the flash drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that it is Healthy.
You need to format the external drive. Format the drive as primary drive and in FAT32.
Insert the external hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Posted on Oct 06, 2009
  • 149 Answers
To repair SanDisk flash drive, you can use software from SanDisk service center. This software can use to repair flash drive (RAW format, used space 0 bytes, free space 0 bytes, damage firmware) and can use for backup data.
U3 Launchpad (Win XP, Vista, Seven)
U3 Launchpad Update (Win Seven)
Posted on Sep 22, 2011
What's your problem?I have lost my password for my Samsung R519 laptop and can not log on has anyone got any ideas as can not use laptop
The following is a guide on how to unlock computer with a USB flash drive when forgot Windows password. It is very easy to use and just takes less than 5 minutes.
Note: Things you need to prepare in advance:
A bootable USB flash drive
A good mood for password reset
A few minutes to wait for password recovery
Step 1: Download Windows Password Unlocker Professional and Install your computer in any computer.(an bootable CD/DVD is also available)Step 2: Start the application and insert the USB flash drive in computer and select your target USB flash drive, and then click the Burn button to start burning.
Step 3: Click OK when burning process is completed, and take the USB flash drive out of computer.
Step 4: Insert the burned USB flash drive to your locked computer and set the computer to boot from USB.
Step 5: Select the specified Windows account you want to recover, and then click Reset button.
Step 6: Click Yes to continue, and click OK when password has been successfully reset.
Not clear? Get more details here to Reset Windows password with Windows Password Unlocker Professional.
Apr 11, 2012 | Toshiba Satellite L305D-S5881 Notebook
I got a new transcend USB jetflash drive 16GB, but my system not showing any response towards it, what shall i do..??? is to download a software for it...??
Flash drives do not need a drivers (plug and play). There are several possibilities:
1. Assumptions: USB port error, computer drivers normal, normal flash drive.
Solution: insert a flash drive into another USB port. If the USB port 1 is not detected, insert flash drive into a USB 2, USB 3 or USB 4.
2. Assumption: normal USB ports, computer driver error, a normal flash drive
Solution: reinstall the chipset drivers, or USB.
3. Assumption: normal USB port,
computer driver normal, flash drive is broken
Solution: try to insert the flash drive into another computer. If the flash drive is not detected, it means your flash drive is damaged.
Solution to determine the cause of damage:
1. If you have a USB mouse, use the mouse to check the damage to the USB port. Example: connect the mouse to the USB 1, USB 2, USB 3 or USB 4. If every USB port, mouse is detected, the conclusion normal USB port
2. To check your computer's drivers, right-click My Computer - Properties - Hardware - Device Manager
3. If points 1 and 2 are normal, the possibility of flash drive damaged.
Because the new flash drive, flash drive is most likely normal. Based on experience, cause damage to the flash drive is a USB port is dirty. The USB port is dirty, can cause short-circuit flash drive. The characteristics of short-circuit flash drive. When inserted into a USB flash drive (about 5 seconds), the temperature of the flash drive become extremely hot. If there are problems like this, immediately unplug the flash drive, to prevent permanent damage.
I hope this information helps.
Oct 11, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I forgot my password and i have tried to format my cruzer flash drive but it still has failed to respond,what should i do?
Hi , i hope in a certain way we can help you''' please insert your flash drive into your PC USB port then go to my computer and click to open then you will see the administrative tools click to open , then click computer management ,when it opened you can see disk management and click to open you will see your flash drive on an assigned drive letter, then on the drive where you can see your flash drive click right to follow what command do you wish to do , so click right and then click format to finish, just follow commands . . . . .
thanks,
gilbert
Aug 07, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Just purchased a pny 4gb fashdrive for a MacBook. It is noy recognized on either USB port
is it compatible to the USB technology ? as in USB 2.0 vs. USB 1.0
try the flash drive on another computer , sometimes if you format the flash drive (Insert into USB connection, right click and press format) -- that may work
let me know please.
Nov 03, 2010 | Apple MacBook Pro Notebook
MY PENDRIVE 4GB IS NOT RESPONDING IN MY COMPUTER.BUT THE LIGHT OF MY PENDRIVE IS BLINKING.
INSERT THE DRIVE GO  TO MY COMPUTER RIGHT CLICK ON IT SCROLL DOWN TO FORMAT AND CHOOSE QUICK FORMAT.
Apr 15, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
My flash drive is inserted in a USB port. It says
Try to format the mp3 player.
Go through: Setting>Control Panel>Administrative Tools>Computer Management>Disk management>
Try to format it with fat files system.
hope this help you
Regards
uttam
Jan 13, 2010 | SanDisk 1GB Cruzer Titanium USB Flash...
USB drive is inserted but reports that disk is not inserted
With the thumb drive inserted in the computer you might try right clicking on “My computer” go to manage and under storage go to disk management. See if your computer reports information on you drive. If not the drive may be damaged or the driver may need to be reloaded
Jun 20, 2009 | Electronics - Others
Usb device not recognize
You mentioned that you uninstalled the unknown device from the Device manager. If you uninstall it then connected your usb flash drive you will see an error again on your device manager. This means that the driver for your usb port is not properly installed.
To install it, visit dell website, look for the model of your machine and locate the driver, download it then install from your machine.
Jun 02, 2009 | Dell Inspiron 6400 Notebook
Flash drive is not showing or responding when plugged into the UBS port
how many drive letter you have on your system?
make sure your drive is inside the usb port. I assume you are running windows system. Right click on my computer, click manage, then click disk management. Can you see your flash drive there, right click over it and assign a drive letter and thats it, you should see it.
Or
disconnect any f drives which you have by simply right clicking and disconnect, your flash drive should show you right away.
Or
Install any drivers which came with the drive and you should see it.
Hope that helped!
Dec 07, 2007 | Lexar FireFly 2GB USB 2.0 JumpDrive
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
568 people viewed this question
Top SanDisk Computers & Internet Experts
Sandy Moore
Sandy Moore
Cleverer2
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
