Question about Casio Exilim Pro EX-P505 Digital Camera
Ihave ex-p505 when i open the lcd nothing works
Ihave ex-p505 when i open the lcd nothing works just the green lamp on the fash between 10 senconds there is posible that need a new battery ?
2 Suggested Answers
lock123
  • 6831 Answers
SOURCE: possible deleted pictures on my casio ex-p505.
Hello
Please download Disc Digger HERE. This is a free tool you can use that works very well and there is no installation required, just run the program once you downloaded it.
Once you have connected the memory card to the computer via either the camera or preferably with a usb card reader , run the program.
On the program , select the dig deep option for accidentaly deleted files or dig deeper for a formatted card. Then select the card you want to do the recovery on and run the program.
The data will be displayed and you can recover it from there. This will only work if the card has not been used since the pictures were lost. Save the files to a location on the computer hard drive and not back to the memory card as this will overwrite the other pictures that still needs to be recovered.
Some of the properties of the files may become lost in the recovery but the pictures should be fine.
Feel free to ask if you need more assistance.
Kind Regards
Andrea
Posted on Sep 29, 2010
Help me, problem epson ex 7210. on start 15 second flashing power, lamp, tempurature red.
There could be two reasons.1.the lamp life has come to an end.
2.The ballast that powers the lamp could be defective.
for solution to first possibility open the lamp and check the lamp burner in the centre of the reflector for breakage. also check if the lamp has a small pcb on the side.if the lamp lamp has exhausted then this pcb is at fault. You need to procure new lamp.
if 2nd possibility then u need to replace with a new ballast.
Dec 04, 2014 | Epson EX 7210 LCD projector
When I plug in the monitor the green power LED comes on for approx 2 seconds then goes out. If I unplug the monitor for at least 10 seconds it will repeat the light on for 2 sec. If I unplug it for less...
It can be power supply, backlight inverter, or bad lamp assembly. You need to open it up and do in-depthtroubleshooting. Please read below and look at pictures, learn ablut bad caps, how LCD monitor works.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://en.wikipedia.org/wiki/Capacitor_plague
Learn about bad caps: Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Nov 25, 2010 | BenQ T701 TFT 17" LCD Monitor
My HP Monitor Model No: L1706 problem
I sure sounds like you have backlight problem, since when the VGA cable is connected the power LED turns GREEN and blinks when VGA cable is disconnected, it means the video signal is getting to the monitor OK, so more likely the problem will be in the monitor, but just to be sure, you should also try this monitor with another PC first.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed HP and other monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Apr 01, 2010 | HP L1706 17" LCD Monitor
Ihave a Philips 50PL9126D tv and I just replaced the lamp because the picture was very dark. I can see the picture but it is still somewhat dark, bright in the middle,dark at the edges. I tried to adjust...
Sounds like you may have the wrong lamp. Make sure you purchased a Philips lamp that's 100% compatible with your television model. Philips pioneered that lamp, so naturally they make 100 different types for DLPs and LCD projections.
You may have an elliptical lamp instead of parabolic. The lamp for your TV should read P22h.
Feb 04, 2010 | Philips Televison & Video
Image start for few senconds
In LCD case, the invertor lamp does not want to start.
Jan 14, 2010 | Computers & Internet
When i press the power on button the green light fashes
You should press the button for about three seconds. This is to ensure that you don't turn on the camera by accident (f. ex. in your bag or pocket)
Oct 25, 2009 | Hitachi Cameras
LG L1717S has no light
Hi, this is a common problem. One thing you want to observe is that the screen works, what's going on is that the screen LCD illumination doesn't work while the screen display is active. LCD's have screen lamps behind the screen, they are often called CCFL, (Cold Cathode Flouroscent Lamps). The inverter board in the monitor supplies High Voltage power to the lampls, so the colored wires should lead you to the lamps. This is the problem causing the screen to dark. You can research the model lamp type for an accurate replacement. Usually there are 4 or 6 lamps in LCD Monitors.
Apr 23, 2009 | LG L1717S-BN 17" LCD Monitor
Green Timer lights blinks for about 10 sec. Then Lamp light, then nothing
Definitely sounds like a power supply problem. Check with your local TV repair/service center about getting it repaired or replaced.
Dec 19, 2007 | Mitsubishi WD62627 62" HDTV
Camera won't work if the memory card is inserted
Don't know if that works for you.
I just use another memory card.
I have 1 card my P505 doesn't work with.
Others are fine.
Hope this helps.
Rosi
Oct 16, 2007 | Casio Exilim Pro EX-P505 Digital Camera
Casio Exilim Pro EX-P505 Digital Camera Logo
20 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
mohamed salim shaikh
Are you a Casio Camera Expert? Answer questions, earn points and help others
