Question about StarTech.com StarView SV211K 2-port KVM Switch
How do u update firmware for thebox?
How do you update a firmware for thebox? i need to do this for my box please if you can give me step by step insturction would rely appreciate thanks again.
    President:
  • 159 Answers
Try this step by step, hope this is what you are after.
http://www.freewebs.com/starview-update/
Posted on Oct 07, 2009
Hi can any bady help me toget work on way but how?
Posted on Dec 05, 2009
Need a the latest code for TheBox USB II As only freeview channels are left.
There are no latest codes, if you rescan and you dont get any channels, nagravision 3 must have been activated in your area. Virgin is changing area by area.
You could try re flash your box with the last available firmware, afterdawn has what you need.
http://forums.afterdawn.com/thread_view.cfm/722659
Aug 19, 2010 | Computers & Internet
Thebox usb2 not working anymore. How and where to update with a memory stick. On with virgin was ntl.
Go to 4 4 shared.com to get the download 1.12 bin on to your usb stick then put it in the back of the box and transfer the files from it in the menu.
May 14, 2010 | StarTech.com StarView SV211K 2-port KVM...
Why when i go into my Coby mp610 music flies it shuts off
There is a firmware upgrade for the Coby 610, which will fix your players problems. You can find it at the cobyusa.com website by choosing 'Mp3 & Portable', then 'Mp3 & Mp4 Players', then your model 'MP610', from the support page. Or, here is the direct link to the file from Coby's servers.
Unpacking the zipfile from the Coby Website will give you a .PDF file with instructions and a program file to run.
Your music will be erased when you run this firmware update. The instructions suggest that even though your mp3 player won't startup properly, if you plug it into your computer you should be able to access it as a removable disk, and copy all your music to a temporary folder on your computer.
Here are the steps:
  1. Plug your MP610 into your computer.
  2. Copy all your music to a temporary folder.
  3. Disconnect your MP610 from your computer.
  4. Disconnect as many USB devices as possible from your computer (to simplify identifying the MP610 at a later step, and avoid damaging other devices by trying to load the MP610 firmware into them by mistake.)
  5. Run the Firmware Update program 'MP610 T LCD Firmware Update for file sys err.exe'
  6. You will see a screen with up to 24 numbered, empty boxes.
  7. Connect the MP610 to your computer. It will show up in one of the boxes.
  8. Once the MP3 player shows up, click on the Firmware Feature icon to start the firmware upgrade.
  9. After the firmware update is complete, you will receive a checkmark in the Firmware box.
  10. Disconnect the MP610.
  11. Close the firmware update software.
  12. Turn on the 610 to confirm it starts up and the display reads 'COBY'.
  13. Plug it back into your computer and copy your music back on to it.
There, I hope that helps.
Dec 30, 2009 | Coby MP-610 MP3 Player
Always restart and blank..
Hmm, Firmware problem probably.
Have you tried to upgrade the firmware,if not do try it, all you need is the USB cable, which comes with thebox.
Goto this link , download the Update Service and then follow theon screen instructions.
And just a hint for you, when the phonerestarts IF it gives you just a slight pulse of VIBRATION, then thephone is curable at your end, otherwise Service center.
I hope you havea clear picture now.
If having troubles, I'm here to help.
And IF I washelpful, kindly do Rate me.
Regards, WAQAR.
Dec 19, 2009 | Sony Ericsson W910i Cellular Phone
Need to reset my receiver
Your question is listed under Sagem PVR6280 so I'll assume that's whatyou have. What follows also applies to the 6240, 6200 and 6200t.
Thereis another default code of 1111, if this does not work then there is ajumper switch inside the box on the main circuit board which will clearwhatever code has been previously set back to the default code. Note that later revisions to these units do not have the reset switch and can only have a manufacturer firmware flash: getting this done may cost more than the box is worth as it has to go back to Sagem.
Openthe box at your own risk and ensure that you physically disconnect thebox from the mains and use an anti-static mat or an anti-static wriststrap. From memory, I think that when the jumper has been altered thebox needs to be briefly re-powered and then turned off to allow thejumper to be reset back as it was.
If your box is a Sagem6240/6260 then DO NOT update it yet as these models are known to beincompatible with the update and will lose some functionalityafterwards. The official advice is to contact Sagem directly on 08450900 316 to see if they have a fix yet, but the number is clearly goingto be ridiculously busy this week at least as thousands of their boxesare affected.
Cut and paste the web address below into your browser for the official line:-
http://news.bbc.co.uk/1/shared/bsp/hi/pdfs/01_10_09_freeview2.pdf
I hope that you have found my answer to be useful and ask in return only that you take a moment to rate my answer.
Sep 18, 2009 | Sagem PVR 6280 Freeview DTV Receiver /...
Eurovox max v codes
TRY HERE
, TheBOX Starview MK2, TheBOX Super Starview MK3, TheBOX Super USB Starview MK4, Digivox (Silver) & Digivox XL (Black).
THE SOFTWARE UPDATES FOR THESE CAN BE DOWNLOADED FROM THE WEBSITE BELOW:
http://www.freewebs.com/eurovoxex5000pvr
Software Updates For The Following Receivers Will Follow Soon
TheBOX-T MMDS, Eurovox TX MMDS & Digivox-T MMDS.
Best Regards
DVB Junkie UK
Dec 18, 2008 | StarTech.com StarView SV211K 2-port KVM...
Star box (virgin media )
depends which area try this i just recieved an email
[ANNOUNCEMENT FOR EIRE/REP OF IRELAND USERS ONLY]
Hi Folks.
All Cable Receiver Are Currently Down In Ireland Including Piped & MMDS.
New UK Software Releases For The Cable Receivers Listed Below Are Working Fine In Ireland.
This Includes:
Eurovox Max (Blue), Eurovox Max (Red), Eurovox Max V (Black & White), Eurovox EX5000 PVR & Eurovox EX1000SL, TheBOX Starview MK2, TheBOX Super Starview MK3, TheBOX Super USB Starview MK4, Digivox (Silver) & Digivox XL (Black).
Best Regards
DVB Junkie UK
Starview 4 thebox super usb
hope this is of help to you if not let me know .
press menu.
press 1570.
look down list to make sure EMU is set to ON . press ok.
code screen service provider tab should be 5A01.
00. go to the bottom of screen and change the codes saving each code entered.
go to the 00 tab and press right to 01. go to the code tab and change codes saving each code as entered.
0.C0 F6 61 87 91 F9 67 57
1.F0 83 35 E5 28 40 49 B2
Dec 11, 2008 | StarTech.com StarView SV211K 2-port KVM...
Inputting codes for sview 3 thebox
Press menu on the remote
Ignore the menu, press the numbers 2007
Press OK on Nagravision
Choose your provider
Enter both keys 00 and 01, saving each key individually
Finished
It's important to have the latest update on your box as it will auto-update any key changes.
Jul 17, 2008 | StarTech.com StarView SV211K 2-port KVM...
StarTech.com StarView SV211K 2-port KVM Switch Logo
147 people viewed this question
Top StarTech.com Computers & Internet Experts
Alun Cox
mbowen171
mbowen171
Are you a StarTech.com Computer and Internet Expert? Answer questions, earn points and help others
