Question about Canon imageRUNNER 3300 All-In-One Laser Printer
Fuser jam.code E00070000
Fuserfilm torn off code showing E0007000
  • 56 Answers
You have to change the fixing film or the fuser unit which ever is the cheapest but before you do check the counters to see the the fuser has done its copy life.
When you do change the fuser dont forget to reset the error code in service mode of else the code will appear even when you replaced the unit.
You do this by entering in service mode and select
Press the key face key, ‘2’ and ‘8’ at the
same time, and the face key once again. then
COPIER>FUNCTION>CLEAR>ERR.
Posted on Oct 21, 2009
My HP printer shows error code 21.1.03, what does it mean?
This error indicates problem with the service station which is on the right end of the plotter. Open the window and have a look, the most common cause I run into is a piece of torn paper preventing the head from parking properly.
Apr 11, 2015 | HP Designjet T1100ps Printer
Fix paper jam 2 on a Samsung CLX-3170 printer
paper jam 2 is a jam in the fuser/exit area.
did the paper jam come out in one piece? if not reassemble the torn paper to see how much is still inside.
sometimes there will be a small fingernail size piece of paper holding open the fuser/exit sensor flag.
sometimes the sensor flag itself is dislodged and needs reassembly.
attached is video in how to dissassemble the printer if required
Sep 24, 2014 | Samsung Office Equipment & Supplies
Flashing wrench 9 times
Lester - so many issues. Take it to a dealer.
9-Flashes means comm fault - check joystick wiring harness.
Nov 01, 2013 | Electric Mobility Invacare Pronto M41...
I have been using Canon IR 2018, it shows an error message "System error e007" while copying or printing though its good with scanning.....kindly suggest me some proper remedy to come over....
there is a one white patch sensor on the fixing film, if this patch sensonsor can't read by fixing unit. machines will show E007 error because of fixing film broken.
so you requie to replace fixing film.
May 10, 2011 | Canon iR 2016i Black and White Copier
HP Laserjet M2727 is printing black line down left side of page, whether I print or copy. The ink cartridge is HP & fairly new (18% used). Been using regularly & just statred happening today.
The easiest thing to do is put another cartridge into the machine and to see if the problem goes away. Even if you can get a empty cartridge that is still working. If the black line is still down the left side after changing the cartridge the fuserfilm in your fuserunit might have a tear in it in which case you'll have to send it to a repair centre.
Apr 14, 2011 | HP Laserjet M2727nf Multifunction Printer
Paper Jam in fuser on my CP2025. I have opened all drawers and doors and was able to find jam. but a small piece of the paper was torn and inside of the fuser assembly. Any way to open fuser assembly?
The steps to remove the fuser from the printer at quite lengthy and should be avoided if at all possible. Any way you can get to the paper as is? Also be careful when trying to get paper out of the fuser as it is easy to damage either the rubber pressure roller or the telfon coated hot roller. Sometimes small jams will come out if you can get the printer to print a page.
Mar 31, 2011 | HP Office Equipment & Supplies
My canon iR 2022 is displacing the world System Error E007. If you put a paper, it also jams. What to do please ?
Canon fuser technology is hp laser printer system.This copier has a fuser film or eleventh cover.Some times its torn or short then this machine say E007.Its an error code.When occurred this E007 you should defective film.
Feb 14, 2011 | Canon iR 2022 Printer
Canon IR2016J -Kod -E007
check the fixing assembly that error from that fixing unit maybe the fuser film is worn out replace a new fuserfilm to remove the error
Dec 11, 2010 | Canon ImageRunner 2016 Copier
Canon imageRUNNER 3300 All-In-One Laser Printer Logo
226 people viewed this question
old marine
old marine
