Question about Electronics - Others
Windows Vista cannot detect the driver software for Western Digital 1TB portable drive. Worked previously, but not anymore. Have looked on the western digital website, but can't find the driver software for this.
  • 3,153 Answers
It should not need drivers more so with XP and Vista
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
Posted on Oct 06, 2009
  • 832 Answers
Try it from other P.C. that is configured to read portable drives. This is to check if it is still readable. This was
readable before in your p.c. , now, no more. This must be infected by virus and could be damage.
Recovery discs won't install windows on new hard drive
sad to say but probably have to buy a new operating system disk .
May 13, 2015 | HP Computers & Internet
The driver software cant be installed
While you r opening the hard drive what error do u get ??
Nov 23, 2011 | Western Digital My Passport Essential SE...
My Android 2.1 won't work with 1T WD hard drive
Unfortunately, Androids can only recognize a certain amount of extra storage space and 1TB is actually an overkill of what it can detect depending on the phone the most i have seen detectable was 32gb.
Feb 10, 2011 | Western Digital My Passport Essential SE...
How can I install the driver for My Passport WD External HDD 500GB online?
It is a "plug-and-play" device, and Windows XP/Vista/7 are "plug-and-play-aware" systems.
So, just connect it, and Windows should recognize it.
Are you getting any error-messages?
What is happening?
What is not happening?
Nov 11, 2010 | Western Digital My Passport Essential SE...
WD my book essential not working on windows
pls i really appreciated if you help me to find a free driver for my wester digital external hard drive 500 gb pls send it to my email how do i get a free drive .... my email: deejhay17@yahoo.com
Jan 22, 2010 | Western Digital My Book Essential 1TB...
WD My Book 1TB Ethernet seems to hang my USB ports on my notebook
Update your firmware, i had the same problem, i updated the firmware and everything works fine now.
Jul 04, 2009 | Western Digital Computers & Internet
Problems with Western Digital My Book World Edition
I have the same drive. It works great with windows XP but with Windows vista has difficulty seeing this type of drive and keeping the connection once it is established. Take it back if you have windows vista and then search for which 1TB drives work well with windows vista. It really has problems with windows vista 64bit. I was able to finally see the drive when I was using photoshop file/browse/network... then I dragged the shortcut Icon to my desktop and access the drive that way from that point on. Mine stopped completely tonight... I think the power cord went bad or something.
Jan 04, 2009 | Western Digital My Book World Edition 1TB...
Electronics - Others Logo
499 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
