Question about 2wire 2700HG-B Router (2700HGB)
Im a new compaq presario cq60 owner- im trying to setup wireless network at home-att.is my only option in my area- have a 2wire 2701hg-b wireless router and cant get it to work internet,wireless only with ethernet cable
  • 2,260 Answers
You will need to check the wireless settings of the router.
You said that it works only with the ethernet connection but not with the wireless connection.
Check the IP address of the computer when it is connected with the cable to the router. note down the default gateway number.
Open the set up interface of your router with the Default gateway number.
once you are able to open the set up interface of your router, you will be able to change the wireless settings of the router.
after that you will need to conncet to the wireless network on your laptop.
Click Here for more Information
Posted on Oct 06, 2009
  • Prashant M
    Prashant M Dec 04, 2009
    Click Here for Easy Set up Guide for step by step instructions.
    It will guide you with simple steps to resolve the problem in your network.
How do i setup my 2 wire router with dsl modem to network iat home
Try this links:
2wire installation guide: http://support.2wire.com/?page=view&article=765
changing wireless settings: http://support.2wire.com/?page=view&article=60
wireless configuration guide for windows XP: http://support.2wire.com/?page=view&article=224
wireless quick reference guide: http://support.2wire.com/?page=view&article=47
note: 2wire is already a wireless router / modem need for other modem to have a good network at home
AT&T ' Yahoo! High speed Internet
Call +1 877 722 3755 (877-SBC-DSL5)
Aug 12, 2011 | 2wire (2701HG-B) Wireless Router
How to configure 2wire 2701?
Try this links:
if you are with At&T AT&T ' Yahoo! High speed Internet
Aug 11, 2011 | 2wire (2701HG-B) Wireless Router
What steps do I take to configure my 2wire 2701 hg-b to connect directly by ethernet cable to my Directv HD DVR and pick up the dsl signal being transmitted by my primary westell router? Both are wireless...
Connect the cable at both ends and do a red button (inside card door) reset of the DVR. To test the connection, do thus: Menu -> .....setup -> system setup -> network setup -> test connection. If it shows not connected then "reset defaults" and run "connect now"
As a basic security feature the ATT DSL 2Wire 2701HG-B router/gateway requires you to enter its pre-assigned WEP key to connect beyond the unit itself and then to the internet. Since the Direct TV DVR HD24D only does a basic connection without having a place to enter the 2701HG-B WEP key it never actually reaches the internet.
The 2Wire 2701HG-B has the ability for one attached unit to "pass through" its firewall and internal security settings using a so called "DMZplus" mode. I set the HR24D DVR to such a mode within the 2Wire unit and the DVR connected with the internet flawlessly.
Dec 30, 2010 | 2wire (2701HG-B) Wireless Router
Compaq 5450F does this computer have wireless? I cannot find any networks. I have wireless att wireless and just got this computer from a friend and loaded all the back up discs to the origional...
Compaq computers are wireless capable. requires a modem to acquire network signals from another device. also require a selection of predetermined netword like local area networks installable between two computers in the promimity. A wider area network is explained as several computers communitncating beyond the same computer owner. Wider or larger area web networks requires permtion from a provider setpup hosting the infrustructure. A web network would require devices that send and receiver signals over larger distances knownas modems. Acquiring a modem would require the permission of each person in the web setup. a more convenient arrangement is to acquire that modem from the host provider that has the oppotunity to network between several infructure device computers. A host would provide a password into several computers, rather than requiring a password to each new computer with networks established solely.
Dec 21, 2010 | HP Compaq Presario SR5450F Desktop PC
I have a Compaq Presario CQ60 and a Netgear WNR2000. They'll connect through an ethernet cable but not using wireless. The router is working fine with other devices.
check the connections for the wireless card and make sure they're both attached, you can see where to look here
http://www.insidemylaptop.com/remove-motherboard-from-compaq-presario-cq50-cq60-cq70-laptop/
if connected make sure not a firewall issue. Try removing all wireless profiles stored in your computer and re-connect to your home wireless network, make sure that you have the correct encryption needed if your wireless is secured.
Or... Click on Start select Control Panel. Select Network and Internet option and then click the Network and Sharing Center. In the tasks on the left click Manage Wireless Networks. Click your network name in the list, then right-click and select Remove Network. This will clear out the profile. Then go back to the Network and Sharing Center and click Connect to a network and reconnect to your network.
might actually be better to start with last one first but I have one too and wireless comes undone easy enough.
hope this helps
If this helps you resolve your problem, please
consider giving me a rating of 4.It will help me
as well. Thank you
Nov 19, 2010 | Compaq Presario Notebook
2wire 2701HG-B gateway can't connect locally
Have you got MS CLient loaded in the network settings. If not run network wizward on each machine and then try again. hope this helps Mark
Aug 18, 2009 | Computers & Internet
Can I use AT&T 2WIRE 2701HG-B DSL to ant ISP?
look if u wish to go for verizon service,,they will provide u with a wireless modem as well,,but if u tell them that u hav a modem then they might configure this modem only,,both ATT and verizon are DSL service providers with PPPoE connections.the only thing u need is the username and passwrd from verizon which u have to setup on the first page of the 2wire setup page,,both the connections are dhcp based.so no other connection settings change required.But when u talk with verizon make sure u tell them of the 2wire modem
Moreover verizon has wireless broadband service which is actually a express card tat u have to put into your computer and u can go online anywhere u go within ur country{it works like a mobile phone}
best of luck,,keep me posted
May 14, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
2wire 2701HG-B: how do I extend it's range?
I purchased Netgear's Wall-Plugged wireless bridge (WGX102 ). Worked very nicely.
Apr 04, 2009 | 2wire 2700HG-B Router (2700HGB)
Wireless internet connection
Try to update the wireless driver of your Laptop.
Mar 09, 2009 | Compaq Presario CQ60-220US PC Laptop
Home Network sharing issues using 2wire wireless modem
Did you manually assign the IP address to your shared devices? If so, the Linksys and the 2wire have different IP schemes.
2wire Gateway IP address:
192.168.1.254
255.255.255.0
Do an ipconfig /all on your computer and compare it to the ip scheme on your devices.
Feb 07, 2009 | 2wire 2700HG-B Router (2700HGB)
2wire 2700HG-B Router (2700HGB) Logo
162 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Bruce Silvernagle
Bruce Silvernagle
Level 1 Expert
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
