Question about Car Audio & Video
Mopar DVD player in Chrysler Voyager
I have a Chrysler Voyager that reads CDC error when a DVD is inserted.
Are these units region locked?
Where can i get a replacement dvd remote, for a chrysler voyager, without going to dealership?
Posted on Feb 03, 2011
Display reads locked
Hello
If the unit
is not functioning properly. Turn the unit off and on again by pressing
POWER twice or unplug the AC power cord from the wall outlet,
and then plug the unit back in. This will make the unit operate
normally if external electrical influences such as lightning or static
electricity have affected the operation of the unit.
Make sure both the player and the DVD is coded by region. If the regional codes don't
match, the disc cannot be played. This player is Region No. 1.
May 15, 2011 | RCA RC5210P DVD Player
It says unable to read disc when i put the game in.
Please Rate me!
What Is It? The Disc Read error is a simple one. It simply means that the Xbox is unable to read the disc that you have placed in the drive. In the majority of instances, this error has nothing to do with the functionality of the console, but, rather, hinges on the actual disc that has been inserted into the DVD tray.
Disc-Related Errors The most common reason for Disc Read errors are related to the disc itself. Numerous conditions can keep the laser from reading the information contained within the game, DVD or CD in the DVD drive.
  • The disc is scratched - Game discs, audio CDs and DVDs can become scratched very easily. Usually this is because they have not been kept in their cases, but left in the open. Simply resting two discs atop one another can scratch the bottom disc. If discs are sufficiently scratched, the data contained on them will be inaccessible to the drive.
  • The disc is dirty/dusty - Dirt and dust can build up on the faces of discs left exposed. When sufficient dirt or dust has built up, it can block the laser beam used to read the disc, resulting in a Disc Read error.
  • The disc is the incorrect region - DVDs come in formats called "regions." These regions match the region specified in the software of the DVD player. Some games also have these regions. If the region of the DVD and that of the player do not match, the disc will not play.
Can I Fix These Errors? Repairing disc-related issues may or may not be possible. If the cause is simply dirt and dust, you can certainly repair the disc. However, if the cause is due to extreme scratching, then replacing the disc is likely your only choice. If the disc is from the incorrect region or from another country, you will have to obtain the correct region. Returning the disc to the retailer for exchange may work.
Non-Disc Related Errors As mentioned, there can be some Disc Read errors that have nothing to do with the disc at all. In this case, it's time to troubleshoot the Xbox.
  • First, simply try to reboot the machine. Often, this will flush the cache or other error and allow the game to operate or the disc to play.
  • Second, try removing the hard drive and/or memory units. Once removed, reboot the console and attempt to load the disc with the hard drive and memory out of the unit. If this works, you can simply shutdown and reinstall the hard drive.
  • Attempt to play the disc in another type of player. For instance, attempt to play the DVD in another DVD player or the CD in a CD player. If the disc plays in these players, you may need to clean the Xbox DVD player.
  • Check to make sure that all air vents are open and are able to provide sufficient airflow. Overheating can cause Disc Read errors, as well. In addition, ensure that the power supply is unobstructed and uncovered. Much like the Xbox 360, the power supply can become quite hot and can cause errors if unventilated.
  • Check for disc tray errors. Depress the eject button and watch the tray extend. If the tray partially extends and then retracts immediately, you may have a problem with the DVD drive. If your Xbox is under warranty, this can be replaced at no charge. However, if you are out of warranty, you can install a new DVD drive on your own.
  • As a note, make sure that the new DVD drive comes with the same firmware as your original console, or you may experience additional error codes after the installation of the new DVD drive.
May 09, 2011 | Video Game Consoles & Games
Hi, I want to unlock my DVD player!! Can you help me ?
Hello
Find the unlock code for your Sony DVD player model. The DVD Demystifiziert and Video Help websites both provide unlock codes for Sony players that can be unlocked and made region-free. To view the code for your DVD player, click on the model of your DVD player in the Sony hack list on the website.
Perform the tasks included in the unlock code. For most Sony models that can be unlocked, the unlock code is not as simple as pressing a few buttons. You may need to open the tray on the player or power the unit on and off multiple times as part of the hack.
Turn the unit off and then on again after you have entered your unlock code, even if the code doesn't include this step. Once you power the unit back on, it should be region-free and should be able to read any DVD that you insert in the tray.
NOTE: Not all Sony players can be unlocked to be region-free. According to the DVD Demystifiziert page, no unlock codes are available for Sony models DVP-NC85H, DVX-11A, SLV-D980P and SLV-D500P.
Keep in mind that unlocking a Sony DVD player almost always voids the unit's warranty.
Oct 10, 2010 | Sony BDP-S300 Blu-Ray Disc Player
How do I set acer aspire dvd region to read all dvds?
Click Start
Click Settings
Click Control Panel
Click System
Click Hardware
Click Device Manager
Click the '+' to the left of 'DVD/CD' branch of the hardware tree.
Double-click your DVD device.
Change the region.
Note that you can "change region" only about 5 times, before the DVD will "lock" into a specific region.
Apr 18, 2010 | Acer Aspire 5720-6661 Notebook PC
My LG blue ray player is locked in region one. I used an unlock code but thought I had to insert the disc and change the region every time I wanted to watch a dvd from a different region. It has been...
have you tried resetting the unit
hold the power button for at least 5 seconds, this will force the unit to turn off.
turn it back on
unplug the power cord
wait at least 5 seconds
plu it back in
Aug 07, 2009 | LG LHT854 Theater System
After loading, disc error is displayed when dvd is inserted
hello i have had the same problem this maybe because of the region that your dvd is made to play.different dvd players play different.region dvd the regions should be on the dvd and the dvd cover.
Apr 25, 2009 | Televison & Video
WRONG Region error . Philips DVD65K
Each DVD player is designed only to read discs froma certian region of the globe, and they are labelled 1 through 6 (or ALL). Australian players are designed only to play Region 4 discs. United States discs are Region 1. It is illegal to change the Region code on a DVD player, so I can't tell you how to do it (ironically, it is the most frequently asked question about dvd players on Fixya.com - global world), but there are videos on YouTube that will show you how to do it - I would just enter "philips region code dvd" as your seacrh term. You won't find that exact model, but one of the codes in the video should work. Note that you will only be able to change the region code three times on a Philips - after that you will be locked out. So change it to Region 1 once, and never change it again.
-Tha Mp3 Doctor
Dec 21, 2008 | Philips PET710 Portable DVD Player
Pioneer dvd avh-p5950 problem
the problem is with your laser pick up unit. Its a reading error. take it to a repair shop or go to ebay and look up repair tech city. They fixed mine and it worked well after that.
Aug 28, 2008 | Pioneer AVH-P6500DVD Car DVD Player
Panasonic DMRES30V DVD Unlock code
Try This ..Turn On player with no disc inserted
While pressing Shift on the remote press Setup
Press Enter twice
Move the cursor to Other
Enter the appropriate four-digit region setting, beginning with 000
Press Enter
Press Return twice
Switch unit Off for at least 3 seconds
Found at http://www.dvdhacks.co.uk/hacksearch/hacksearch.asp?player=PANASONIC
Jul 21, 2008 | Panasonic DMRES30V DVD Recorder/VCR Combo
Error message when reading DVD
Try changing the region setting to region free.
1. Make sure there is no Disc in the tray.
2. Shut off the unit and unplug it from the AC outlet.
3. Press and Hold the "Play" and "Open/Close" keys,
simultaneously on the player and not the remote control.
4. While holding these keys, plug the AC cord back into the outlet. (TEST and CPU ver# will appear on the display)
5. Release the "Play" and "Open/Close" keys.
6. Press DVD Menu twice on the remote.
7. When the display reads s000 5858 use the up and down buttons to change the 000 to 02E.
8. Using the Left and Right arrow buttons, change the last four digits until they read 0000 for Region Free, 0101 for Region 1, 0202 for Region 2 or 0404 for Region 4.
9. Press Enter on the player.
10. Press Standby and wait 5 seconds.
11. Press Standby again. Your player is now set to the region you requested. If you find some titles do not play on the region 0 setting, you may have to hard select the appropriate region.
Good Luck. Let me know if it works
Jan 09, 2008 | JVC XV-S300 DVD Player
Car Audio & Video Logo
1,269 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
