Question about Fluke Networks Fluke 179 Electricians Digital Multimeter Kit, Voltage Tester
Dos not work in Volt meters. show 220v as ca 50 v.
Fluke 179 : Dos not work in Volt meters. Show 220v ac as ca 50 v.
    President:
  • 1,922 Answers
Your batteries are shot
Posted on Oct 06, 2009
No ohms on 179 fluke meter
check input protection (thermistor (black components - first in line at Voltage terminals should be around 1kOhm, next is 2W resistor = 1kOhm and then 3 varistors (blue) open or very high ohms).
Aug 09, 2013 | Fluke Networks Fluke 179 Electricians...
Fluke 179 not working on voltage
possible blown fusible resistor (check for open or very high resistance - should be about 1kOhm) - first big resistor in Voltgae terminal circuit
Mar 16, 2013 | Fluke Networks Fluke 179 Electricians...
Fluke 179 multimeter showing wrong reading in AC, DC voltage, rest every thing working ok
input protection circuit is blown , see if you can find fusible resistor and check for open circuit (should be 1kOhm) - big resistor on the right straight from the Volts input
Mar 15, 2013 | Fluke Networks Fluke 179 Electricians...
Cannot get my Fluke 36 clampmeter to read amps
1. make sure that all buttons can be pressed freely (not stuck)
2. make sure when measuring AC current that you press AC button and AC sigh is on LCD
3. make sure that jaws are closed completely
4. clamp meters use Hall effect and can only measure current flowing through ONE conductor (you cannot measure current around power cord (which has 2-3 or more conductors)
5. when in DC setting and you turn zero knob does value changes (it should)
Nov 21, 2011 | Fluke Networks Fluke 902 True Rms Hvac...
My fluke 179 shows batt in any function and it does not go out, with battery even new
send it back to Fluke for service if you are certain that battery is good and connector is not damaged (check Voltage on 2 pins that come to the board)
Feb 09, 2011 | Fluke Networks Fluke 179 Electricians...
My 23 will not work on ac setting
i dont know if this affects the reading on AC but in the back of the meter there are 2 fuses. remove the back cover and check these fuses.
Jan 12, 2010 | Fluke Networks Fluke Multimeter Combo Kit...
WHEN I TURN ON MY FLUKE 179 IT READS ERROR AND SHOWES CODE "EEPR" .
Hi, that is the error message indicating a EEPROM error and unfortunatlely, you can't do anything except have the meter serviced by either Fluke directly, or by an authorized Fluke test equipment dealer.
Since Fluke doesn't provide the specs and coding for their products, you wouldn't be able to repair the meter properly, even if you could burn and program your own chipset.
Here's a copy of the manual for your meter, so you can contact Fluke for servicing and see the other info relating to it (for your future reference)
http://assets.fluke.com/manuals/175_____umeng0100.pdf
Sorry to be the bearer of bad news, but Fluke products are typically quality test instruments and there might be a possibility that you're still covered under their warranty, so checking with them is the best avenue for getting it back to working condition.
I hope you find this Very Helpful and best regards!
Nov 01, 2009 | Fluke Networks Fluke 179 Electricians...
Fluke Networks Fluke 179 Electricians Digital Multimeter Kit, Voltage Tester Logo
348 people viewed this question
Top Fluke Networks Measuring Tools & Sensors Experts
Vuk B
Trevor Turner
joseph m fucci
joseph m fucci
Level 1 Expert
Are you a Fluke Networks Measuring Tool and Sensor Expert? Answer questions, earn points and help others
