Question about Samsung DVD-H1080 DVD Player
I have a Samsung DVD player model No H1080, what
I have a Samsung DVD player model No H1080, what isthe code to make it play all regions
AC/DC HIGH VOLTAGE ROCKING ROLL
Posted on Jan 10, 2010
Hi, I have a samsung dvd/vcr combo player model number v6800 which I hacked to be region free. It now plays dvds with region codes regardless from where they originate (ie; 1 or 4), however, some of my...
If the dvds which are "all regions" are recorded from a computer, your dvd player may not play them. I assume the dvds which have a region code have been professionally prepared. Sometimes, the cheap dvd players will play anything while the more sophisticated ones will give you trouble unless everything is just perfect.
Jul 26, 2011 | Samsung DVD-V90K Multisystem DVD/VCR
I want to unlock the regional code of my player which is samsung dvd-H1080 xtl
I found a reference to guide you how to unlock your samsung player for region coding. check this link here.
Jul 03, 2010 | Samsung DVD-H1080 DVD Player
I need the multi region code for a Samsung DVD H1080
Sorry, there isn't one. Your model is not hackable.
The usual Samsung hacks involve using the remote to enter the correct numbers but your model has no number keypad on the remote. Substituting a universal remote also does not work and I've been informed by Samsung that the region coding on this model is hardware encoded just like on many Sony and Panasonic models so you cannot even override the coding using a service centre remote control (I've tried). I discovered this when a friend purchased a large quantity of clearance overstock region 6 DVD H1080's and asked me to convert them for resale in the UK (region 2).
To hack your model requires internal hardware replacement and this is not economically viable.
Oct 14, 2009 | Samsung DVD-H1080 DVD Player
I have bought samsung dvd player h1080 and it seems that it is region 1 how can i make it region 2. thanks
After searching the best known region hack databases I have found one process for your make and model. I can not assure you that it will work 100% but it's the only known process.
Turn on the Player with no disc on the tray. The tv screen and the dvd lcd will display "No Disk"
2. Press the "Repeat" key on the Samsung remote control
3. Press the keys: "5 7 5 3 8" on the remote. Number 2 appears on the screen for a short time.
4. Press "9". Number 9 is displayed on the screen.
5. Press the "Open/close" button in the remote. The tray will open. Leave it open for a few seconds.
6. Just press the "On/off" button in the remote.
7. You now have a multi-region dvd player!!
I hope this works for you, thank you for choosing Fixya!
Aug 29, 2009 | Samsung DVD-H1080 DVD Player
Just got a samsung H1080 DVD player playing black and white only
The component connection should have one red, one green, and one blue connector that will connect to the back of your player and the back of your television. Then there should also be another red and a white connector that should run from the AUDIO L & R OUT of your player to the AUDIO L & R IN beside the Component IN connections on your TV. The yellow cord would normally be running from the VIDEO OUT on the back of your player to one of the VIDEO IN connections of your TV.
Aug 12, 2009 | Samsung DVD-H1080 DVD Player
How to unlock the samsung dvd h1080?
SAMSUNG DVD-H1080 This worked for me:
Turn on the DVD without disc in the tray
Press repeat (not repeat a-b)
Press fast forward (>> not >>l)
Press rewind (<< not l<< )
Press up
Press down
'0' appears in top right corner
turn off then back on.
Aug 03, 2009 | Samsung DVD-H1080 DVD Player
Region code 4 on Samsung DVD-VR355 player/recorder
I live in Australia and have two Samsung DVD/VCR player recorders, DVD-VR375 and DVD-VR355. I could only play Region 4 DVDs until I pressed DVD, with no DVD in the units, pressed Menu then 76884, then 9, inserted a Region 1 DVd and it played in both units.
Christina Weate
Jun 11, 2009 | Televison & Video
SAMSUNG HR733 DVD RECORDER WILL NOT PLAY ANY REGION DISCS AT ALL
On page 45 of the user manual it says this:
Both the HDD & DVD RECORDER and the discs are coded
by region. These regional codes must match in order for the
disc to play. If the codes do not match, the disc will not play.
The Region Number for this HDD & DVD RECORDER is
described on the rear panel of the HDD & DVD RECORDER
If you changed the region codes on your player it will not work. They should be set back to 1 or whatever your model says on the back of the unit.
If this unit was purchased outside the United States, it may not work in the United States.
Here is a copy of the manual if you need it:
http://downloadcenter.samsung.com/content/UM/200506/20050618115856781_HR720-00758C-XAC-Eng_0519.pdf
Dec 08, 2007 | Samsung DVD-HR720 DVD Recorder
Incorrect region codde
This is for DVP31XXX series i hope it works all on DVP31 series. It has been tested on DVP3146K /51 and it has been worked...
1. Make sure there is no disc in the player.
2. Turn power off and on again.
3. Open the tray.
4. On the remote, hit 9879 and then 0. This changes unit to Region 0, meaning it'll play all regions.
5. Hit OK on the remote.
Good Luck Guys!
Apr 27, 2007 | Philips DVD 622 DVD Player
Samsung DVD-H1080 DVD Player Logo
358 people viewed this question
Jerry Greenberg
Jerry Greenberg
