Question about Canon PIXMA MP470 All-in-One Printer
This happens to me too. it copys with the buttons but doesnt scan
When i get to the colour icons =scan screen it doesnt work!!!
Copy and Scanner not responding
Copier may require you use the scan feature to make copies either ise the feeder otr flatbed. Press start on machine for manual entry but still use scan to get things working.
Nov 15, 2013 | HP HEWLETT-PACKARD CN583A Officejet 6700...
When I press the black or colour copy button on the printer the page comes out blank. The printer works normally otherwise.
Check scan head movement while copying/scanning..if its not moving check scan head gear assm any breakage? replace it. If its moving properly and giving blank image scan head faulty(which is moving forward & revers wile scanning or copying) replace it..
Sep 07, 2011 | HP PSC 1215 All-In-One InkJet Printer
All works fine except the scanner on the lexmark x5470...It used to work fine but the menu has reduced to image capture only but even that wont work
All you need to do is put in your page you want to scan, upside down and the wrong way round and hit scan. Then there wil be two buttons underneath the buttons which say print, scan, fax and it says start above it then two buttons which say black and colour if you want your copy in colour press colour or black!!
Dec 20, 2009 | Lexmark X5470 All-In-One InkJet Printer
The start buttons are not working in scan mode. Press them and nothing happens. The other buttons work, such as the two buttons directly below the screen.
Scan from the scanner and camera wizard, the front scan button is useless. Go to My computer, open the scanner icon and scan from there, no need to use the button at all.
Nov 04, 2009 | Canon PIXMA MP600 all-In-One InkJet...
How does the scan function work on the canon pixma mp190
If you just want to make a copy then load the page to be copied and then press either the black or colour button on the printer.
To scan load the page to be scanned and then press the Scan button and the program called MP Navigator EX will start.
This was installed with the Printer install CD.
Please rate answer if worked if not then let us know
Thanks
Oct 14, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Hp1350 wont scan press scan button on/resume light blinks buzzing for a few seconds and nothing else.
Did you try print any document just to make sure that printer is connected properly to the computer. If it is printing than try to scan from computer , i mean there must be a icon in your computer "Hp Director", open that and click on scan document. if that doesnt work, than click on start, got to run and than type "stimon.exe" than hit enter from keyboard. Nothing will happen , just screen will flash for a second, than try to scan. if it doesnt work than you have to unistall and reinstall the software
Aug 07, 2009 | HP Office Equipment & Supplies
My HP PSC 2175 ALL IN ONE DOES NOT SCAN!PLEASE HELP!
I assume you have Vista and when the scan button is pressed on the product, nothing happens. The scan button does not work correctly. Workaround
Choose one of the following options to scan without using the scan button. Option one: Scan using Windows Fax and Scan
  1. Click the Windows icon (c01319360.gif), click Programs, and then click Windows Fax and Scan.
    NOTE: The Windows Fax and Scanoption is available in the Business, Ultimate, and Enterprise editionsof Windows Vista. If you have the Home Basic or Home Premium edition ofWindows Vista, skip to Option two: Scan using Paint.
  2. Click New scan.
  3. Click File, and then click Scan.
  1. Click the Windows icon (c01319360.gif), click Programs, and then click Accessories.
  2. Click Paint.
  3. Click File, and then click From Scanner or Camera.
  4. Click Scan.
Cause The drivers in the Windows Vista operating system do not support button press functionality on the product.
Apr 20, 2009 | HP PSC 2175 All-In-One InkJet Printer
Scaning
I have an X75 at home and I remember the computer has to be on to copy, so it's really just doing a scan and then an immediate print.
Make sure your computer is on. If it still doesn't copy, launch the Lexmark All-In-One Center software on the computer. You can do a copy from there... and it should put a little icon in your systray (lower right area of the screen)... that might re-enable the copy from the button.
Steve
Feb 22, 2009 | Lexmark X75 All-In-One InkJet Printer
Scanning
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00809848&lc=en&dlc=en&cc=us&lang=en&product=90792
Issue When the scan button is pressed on the product, nothing happens. The scan button does not work correctly. Workaround Choose one of the following options to scan without using the scan button. Option one: Scan using Windows Fax and Scan
  1. Click the Windows icon (c01319360.gif ), click Programs , and then click Windows Fax and Scan . NOTE: The Windows Fax and Scan option is available in the Business, Ultimate, and Enterprise editions of Windows Vista. If you have the Home Basic or Home Premium edition of Windows Vista, skip to Option two: Scan using Paint .
  2. Click New scan .
  3. Click File , and then click Scan .
  1. Click the Windows icon (c01319360.gif ), click Programs , and then click Accessories .
  2. Click Paint .
  3. Click File , and then click From Scanner or Camera .
  4. Click Scan .
Oct 04, 2008 | HP Officejet 4110 All-In-One InkJet...
HOW TO GET FROM 35mm COPYING TO REGULAR COPYING
Configure your scan buttons in the bottom right corner of your screen (when you click on the scan icon in taskbar). This will help you to go back where you want to be. You may find it easier to use XP's inbuilt scanning facility instead or scan via Photoshop.
Sep 17, 2007 | Visioneer OneTouch 8920 Flatbed Scanner
Canon PIXMA MP470 All-in-One Printer Logo
26 people viewed this question
old marine
old marine
