Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Drum makes loud noise as rotates clockwise
Hotpoint Aquarius WD460P 2 1/2 years old. Drum makes loud noise as rotates clockwise (doesn't do it when rotating anti-clockwise. Sounds like the plastic detergent ball clattering against drum, but it isn't as also does it on drying cycle when no ball in there.
  • 52 Answers
Put few clothes in it drum to switch on its ball in there
Posted on Oct 06, 2009
Hi, My Hotpoint TVM570 Aquarius is making a loud screeching noise occasionally. It isn't doing it every time my partner just used it for an hour with no issues. However I used it for 5 minutes this...
wonder if you are overloading the machine and the noise is the drive belt screeching. if it sounds similar to a loose fanbelt on a car, it could be drum bearings that are seizing up (check by manaually rotating the drum. if it spins freely its ok) or the drive belt is getting worn and needs replacing
May 09, 2014 | Washing Machines
Dear fixya, I have a hotpoint aquarius wma52 which sounds like it grinds when drum turns. I gather it may be the bearing but I don't see how to take off the back and check to replace.thankyou
HI,
First of all, is the noise only heard when the drum is rotating or when the pump is running? This really makes the difference. Sometimes an object can rub on the outer tub during rotation and cause the same noise, other times, I have found foreign object within the pump and caused the same problem. So when is the noise heard is very important to lead you in the correct direction.
I will be glad to assist you if you like
Jul 28, 2011 | Hotpoint Aquarius WMA52 Front Load Washer
I have a Hotpoint Aquarius WF541 that has started making ean extremely loud noise when on spin. The machine remains still, but sounds like a jet engine. The drum makes an awful noise when I turn it...
maybe it the pulley tensioner came lose.....open up the back of the machine and check if the belt is tight...if not get the spanner out retention the pulley arm and retighten.
Jul 20, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Hi my hotpoint washing machine is near 3 years old the last few weeks it is making a terrible noise when on spin only. \r\nthe noise is really loud but everything is washing and drying the same its just...
Sounds loike the main drum bearings have failed.
Spin the drum by hand from the front, and if it feels rough, or is rumbling or grating, then the main bearigs have failed.
Quite an expensive repair, unless it is covered by the Hotpoint 5 year parts guarantee, check with Hotpoint.
Jun 16, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
How do i fix on a drive belt to a washing machine?
There is a removeable cover at bottom rear of washer..
Undo this, and you will see the motor and belt.
It will be very tight to put on, but this is normal as it is a stretch belt, that is why there is no adjustment on motor.
Hope this helps you .
Please rate my solution.
Thankyou.
Jan 25, 2010 | Hotpoint Aquarius WF220 Front Load Washer
Loud noise as drum turns,gets louder as speed increases.
There is no doubt that the drum bearings have failed from your description.
The normal procedure is to replace the whole drum and tub assy as a complete unit, this makes it a fairly straight forward repair, though relatively expensive.
To strip it down and replace worn bearings, is a very involved repair, and not one I would recommenend.
If the washer is less than 5 years old, then you can get it done under the Hotpoint 5 year part guarantee, but you would have to contact Hotpoint about this.
Plz rate my solution.
Thankyou.
Jan 25, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint wd640 replacement motor brushes
machine has brushes but they usually last longer than 2 years (mine are still ok after 5 years.
if you get no drum rotation, then suspect the brushes and replace them if necessary
Jun 21, 2008 | Hotpoint Aquarius WD640 Front Load...
How to replace drum bearing for hotpoint aquarius+ wf740
My machine is just over 3 years old and although there is no play in the rear drum bearing it is very noisey on spin.
It gets progessively loud the faster the spin speed.
Jun 18, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint WMA42 - Noise!!
appliance sounds like it has bearing failure.common on this machine.advise looking for a new machine.sorry
Dec 30, 2007 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Aquarius 1100 - Grinding Noise From Drum
This sounds like the min bearings have gone, open the door and see if there is any play up and down on the drum. if so its the bearing if not it could be something that has fallen from a pocket and got stuck between the metal clothes drum and the oute drum casing. a take apart job i am afraid for both issues.
Oct 29, 2006 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
349 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
