Question about Linksys VOIP VONAGE PHONE ADPTR 2-PORT PAP2 Router
How to save configuration - Linksys VOIP VONAGE PHONE ADPTR 2-PORT PAP2 Router
    Problem Solver:
  • 5 Answers
Well unfortanetly you are unable to get into the web configuration because vonage locks there device's you might have a chance to get into it if you speak with vonage and ask them for the username and the password
Posted on Oct 07, 2009
How to clean up configuration Huawei switch ? I use the switch Huawei S9306 in my network. [Y/N]:y reboot Warning: All the configuration will be saved to the configuration file for the n ext startup:,...
Maybe you should ask the manufacturer, they will give you the details configuration. And if you want to learn more about the Huawei switch configuration, please visit:
c:\docume~1\admini~1\locals~1\temp\%w@gj$acof(tydyecokvdyb.pnghttp://huaweis5700.over-blog.com
Apr 03, 2014 | Computers & Internet
What is the default password for cisco
There are two main methods to return a Cisco router to its original factory defaults. These two methods are described below.
Method 1
1. uses the config-register 0x2102 command in global configuration mode.
2. Check the configuration register on the router by issuing the show version command.
3. The configuration register setting is displayed in the last line of the show version command output and should be set to 0x2102. If this is not the case, enter the config-register 0x2102 command once in global configuration mode.
router#configure terminal
router(config)#config-register 0x2102
router(config)#end
router#
4. If the show version command is issued again, the same line in the command output will have '(will be 0x2102 at next reload)' appended to the current register setting.
5. Erase the current start-up configuration on the router with the write erase command.
Reload the router with the reload command. When prompted to save the configuration, DO NOT save.
router#reload
System configuration has been modified. Save? [yes/no]: n
Proceed with reload? [confirm]
Once the router reloads, the System Configuration Dialog appears.
--- System Configuration Dialog ---
Would you like to enter the initial configuration dialog? [yes/no]:
The router is now reset to the original factory defaults.
Method 2
1. uses the config-register 0x2142 command in global configuration mode.
2. Enter the config-register 0x2142 command in global configuration mode.
router(config)#config-register 0x2142
This causes the router to ignore the start-up configuration on the next reload. If a show version is issued, the last line in the command output will have '(will be 0x2142 at next reload)' appended to the current configuration register setting.
3. Reload the router using the reload command in enable mode. It is not necessary to save when prompted to save the system configuration.
router#reload
After the router has reloaded, the System Configuration Dialog appears.
4. Enter no to the question "Would you like to enter initial configuration dialog?"
5. Change the configuration register setting to 0x2102 by entering the config-register 0x2102 command once in global configuration mode.
6. Issue the write memory command in enable mode to overwrite the existing start-up configuration with the current running configuration.
7. Reload the router with the reload command in enable mode.
Once the router reloads, the System configuration Dialog appears.
Note: The configurations below are stored in ROMMON, and cannot be reset to Factory Default Settings by the write erase or config-register 0x2142 commands.
warm-reboot
memory-size iomem <not default>
Jun 18, 2013 | Computers & Internet
Dont save configuration
Some routers when saving the configuration require you to stay on the page after clicking save, if you close or go to another page to quickly it stop the configuration save, stay on the same page after clicking save until the page refreshes.
Also make sure you are hardwired into the router not wireless, most newer routers do not allow access to the configuration using wireless and some allow you to see but not change the configuration wirelessly.
Jan 30, 2013 | 3Com WL ROUTER 3COM|3CRWER100-75 54M RTL...
How to save configuration settings to my 2600 phone?
Hi when you get a configuration message from your server then press option button and click on save option by doing this you get saved your configuration settings
May 27, 2010 | Nokia 2600
I set the printer settings, save. When the printers power is turned off, the saved setting are lost- why?
Check in the Configuration Menu for your "Power on" configuration set. It is most likely set to "Factory Default" Change to your custom set (1,2,3 etc) and save. Make sure you save your set again after you set this (you just changed the config so save it)
Mar 02, 2010 | IBM Infoprint 6500 Matrix Printer
When I going to save an web configuration I can not save it. the phone shows that the memory is full though there is no saved configuration..plz Help
1st delete some data from phone memory and delete some access points from web confrigration settings and then you can save it.
Oct 22, 2009 | Nokia 3110 Cellular Phone
Restoring former router settings
Is there any way you could possibly delete these save files?
Try restarting it by pressing and holding the button on the back of the router for 30 seconds/
Mar 22, 2008 | Siemens Efficient Networks SpeedStream...
Save/load the configuration
Step 1 Open a web browser and type the IP address of the wireless router in the address bar (default is 192.168.0.1). Press Enter. Step 2 The default username is admin (all lower case) and the default password is blank (nothing). Click OK. Step 3 Click the Tools tab and then click System to the left. Step 4 To save the configuration settings of your wireless router, click the Save button next to Save Settings To Local Hard Drive. To load a previously saved configuration file, click the Browse... button next to Load Settings From Local Hard Drive. Once you have located the file (config.bin) on your hard drive, click the OK button and then click Load.
Feb 16, 2006 | D-Link Express EtherNetwork DI-604 Router
Linksys VOIP VONAGE PHONE ADPTR 2-PORT PAP2 Router Logo
60 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
