Question about Casio Exilim EX-S600 Digital Camera
Auto shut down
When powering up camera lens comes all the way out then makes loud clicking sound before lense retracts and powers down... Have you any suggestion on solving issue... thanks
  • 8 more comments
  • bigd123 Dec 30, 2007
    I'm having the same problem. It powers up, the lens extends, makes clicking sounds, then shuts down.
  • Anonymous Dec 30, 2007
    I have same problem.
    When the power turn on about 2 seconds, with the beeps sound and 3 buzzing sounds, then the lens retract itself, power also shutoff. I replace new battery, new SD card. I can view the pictures from playing mode. after I disable viewing from the menu, by mistake, now I can not view the pictures any more. I can see the pictures on my PC only.
    Can anyone help? Thank you.
  • fadedgene Jan 06, 2008
    I have the same problem. Despite a full charge and a downloaded memory disc, upon powering on the camera lens extends for 1-2 seconds makes some clicking sounds an dthen powers off. The memory disc has also been been
  • cmclean Jan 29, 2008
    I have the same problem. The camera powers on, the lense extends, clicks and makes a whirring sound, then the lense retracts and the camera powers off. The menu also won't display. I've tried resetting by removing the battery then waiting a few minutes. The first couple of times, this seemed to make it work again. Now this no longer works.
  • Bizzaro Feb 07, 2008
    I have the same problem. When I turn it on, the lens extends, then there are clicking and whirring sounds, and then it turns itself off. I can't use it at all. A repair shop said it would cost $135 to repair, so I said no. It's not even 2 years old! I tried the one solution suggested, of holding down the on button while holding the shutter release until it takes a picture. It didn't work.
  • mtanu May 03, 2008
    That's exactly the same problem I have. It seems to be a common problem with this camera from the looks of the many posts here.
  • Piccoloist May 06, 2008
    Yes, I too have the same problem, which I just noticed when I went to take a picture. At least I am not alone and now have a name for the situation. I also tried to take the battery/memory card out and tried pressing the menu button and on button at the same time, but that didn't work either. My camera was purchased in 2006 and I think I have a 5 year warranty so I guess I will have to send it in.
  • Anonymous May 07, 2008
    i have the same problem, don't know what to do
  • emarat Aug 28, 2008
    Have same problem with casio exilimex-z60, anyone has any suggestions?
  • Yasoon Hawk
    Yasoon Hawk Dec 09, 2008
    I had the same problem.
    Used the advice of turning upside down and hitting on my palm a few times, now it works. I also had the flashing light when charging problem and using the 9V battery fixed worked for that.
    Seems you get what you pay for with this camera.
    Hope it lasts through the holidays.
    Good Luck!
So I had to send the camera back to have it fixed. It was the only solution I could think of. I actually had an extended warranty plan so I sent it to Mack Camera and Video Service in NJ. The repair order was placed on 7/8/08 and I received the camera back on 8/18/08. It did take awhile, but they did fix the problem. They first let me know they had to order the parts then they ended up having to send the camera back to the manufacturer for repair. They ended up replacing the circuit boards, updated firmware, and cleaned and checked all functions. So, though it took awhile, it is fixed and working fine.
Posted on Sep 12, 2008
How to fix Powershot Elph 530S so that the lens retract all the way when powering off
From the way you describe the problem it appears that the retraction mechanism has become out of line. I think that as you can hear a clicking sound the mechanism is working but not engaging with the lens. Try gently applying slight pressure on the front of the lens this may help to re-engage. You may need to consider a trip to the repair shop.
Jul 11, 2014 | Canon PowerShot Cameras
The Lense will not go back in
Remove the batteries from the Camera. Then press and hold the power button down for 45 to 60 seconds. Replace the batteries with new ones and install them in the camera. Then turn it on and wait until it finishes its normal warm up, then press the power button to turn it off. This should make the lense retract back to normal position. If the lens does not retract, contact the manufacturer for assistance with repair work.
Jul 07, 2011 | Canon PowerShot SD1000 Digital Camera
Camera doesnt allow me to take photos, lense keeps going in/out
this is most likley one of two things. If you are using a rechargeble battery - it is not keeping a charge. When the camera detects low power it will usually shut itself down drawing in the lens for protection and shutting down. If the battery is gone passed it's time it will not take a proper charge. You will need to replace the battery.
Alternatively you may have a dodgy mechanism - some dirt or even internal component may be broken - in your zoom lens. If the lens cannot extend correctly the camera will automatically retract and power down so as not to cause further damage - for example you camera gets accidentally switched on whilst in the case, and the lens cannot come out.... bring it in for repair.
I know not a solution but hope it helps.
Jul 24, 2009 | Olympus FE-340 Digital Camera
DSC_W110 model problem
You definitely have some dirt on the outside of your lense. You need to keep it clean by holding cloth on the outside of the lense. Turn the camera off. If the lense does not retract fully, while turning it off, press on the lense (up and down motion with the lense motion) very softly for a few times. The lense should retract 100% inn. If not %100 retreacted, but almost 100% retracted push the lense a little harder in until it retracts all the way in exactly the normal position. That should take care of your problem. Good luck
Jun 09, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Dimage Z3 lens does not retract
Check your batteries. Are they working? Try taking them out and replacing them. If you left the camera on when you put it away and the batteries drained, you won't be able to retract the lense until fresh batteries are inserted and the camera is powered up again.
Feb 02, 2009 | Konica Minolta DiMAGE Z3 Digital Camera
Lens won't in on camera and makes clicking sound.
When you dropped your camera, some dirt got on the outside of the lense or some mechanical part of the lense broke or dislocated. If some of the mechnical part of the lense is damaged, you need to open up the lense from the camera and inspect the parts. Look for loose parts, then clean it and put it back.
I had the same problem with my sony Cyber-shop, but it was not dropped. somehow one or more small piece of dirt got on the outside of the lense. Here is what I did and the problem was fixed for good.
While turning the camera off, I pressed on the lense (up and down motion) softly. After a few times, the lense retracted 95% of the normal retracted position. I then, pressed the lense a little harder in untill it was fully retracted. It has been working okay since then.
You should always keep the outside of the lense clean and do not drop it.
Good luck
Oct 11, 2008 | Sony Cyber-Shot DSC-P32 Digital Camera
Camera beeps loud 3 times and shuts right off!!
sounds like a lens error, does the lens extend or retract? You probably have to get the lens back on track, use gentle pressure wiht the camera face down on a towel covered table and turn on to see if the camera tries to retract the lens. I really dislike these types of cameras that extend the lens everytime, if it turns on in your pocket, your doomed!
May 27, 2008 | Samsung Digimax S500 Digital Camera
Dropped camera lightly, lens wont retract
my acm dropped and i messed up the lsenes it wont go in please help me how can i fix it my self?
Nov 03, 2007 | Canon PowerShot A540 Digital Camera
Zoom error message
Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
Aug 07, 2007 | Olympus SP-350 Digital Camera
Casio Exilim EX-S600 Digital Camera Logo
60 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
