Failure to record on left channel
I have an Akai 1720L tape recorde which does not record on the left channel. A microphone input to the left channel will produce something, but it is not efficient. I am seeking a repair.
  • 71 Answers
Al capacitors need changing due to age this will help but all the switches need cleaning if you live in england take it to audio gold crouch end they love these
Posted on Oct 10, 2009
Testimonial: "Thanks. Good information. Regret, live too far away from Crouch End. Still usefull anyway."
AKAI REEL TO REAL MODEL 1700 OPERATOR'S MANUAL
Here you are Andrew. That is a blast from the past!!
Service Manual and Owner's Manual!
Akai 1700 Manual Stereo Tape Recorder HiFi Engine
Jan 23, 2016 | Computers & Internet
Reel to reel wont record with microphone
When I put a tape in and press play, the spools will not turn. There is power, but it won't play the tape. It's like the turning spools are stuck .
Feb 28, 2014 | Audio Players & Recorders
B2 Pro left stereo channel is Mute
This is not a stereo microphone. There is no left channel. If you are recording into a stereo input, you need to split the input into two mono inputs, and record each channel as a mono track.
Feb 02, 2013 | Behringer B-2 Pro Professional Microphone
How do i record from both speakers?, my vocals are only coming out from the left side.
The G-Track is a mono-microphone, but your computer recognizes it as a 2 channel device because of the input connector on the side. You need to go into your computer's sound control panel, locate the G-Track microphone and change it to a 1 channel device. Alternatively, you can use advanced recording software to take the left channel input and manipulate it however you want.
Sep 02, 2009 | Samson G-TRACK USB RECORDING MICROPHONE...
Samson G Track USB Mic
To get sound in both channels in Garageband for a podcast using the G-Track Microphone:    select a voice track to record into    make sure the Track Info window is open (blue i button in lower right region of screen)    at the bottom of the Track Info window you will find Input Source:    Change the default setting of Stereo to Mono 1 (USB Audio CODEC)
This assumes you have gone to Garageband preferences and changed the Audio/Midi settings for audio input to USB Audio CODEC which appears when you plug in the G-Track Mike
Apr 08, 2009 | Samson G-TRACK USB RECORDING MICROPHONE...
Connections for a Grundig reel to reel tape recorder
Grundig TK23
Inputs at rear of machine. From Left to right.
Circle with line underneath. (Micro socket) - microphone, mixer (Grundig 607), telephone adapter.
Square with line on top - Radio input/Output. Record/playback radio. Record records if player is connected to radio for playback via a 3-pole amplifier unit. Re-recording to a second tape recorder. Connection to a Grundig Stereo-Mixer 608.
Reversed Q - Phono Input. Connection to a record player or a second tape recorder. (for re-recording records or tapes)
Squiggly lines - Outputs. - Connection to external speakers. Grundig Stereo Box. Connection to an additional amplifier (Grundig 229) for synchronous recording.
Square with line at right. - Earphones.
Loudspeaker switch - (At bottom) - In the "0" position, the internal speakers are shut off.
Dec 30, 2008 | Audio Players & Recorders
No Sound When Records are recorded to Computer via the Microphone
use tape1 record out to the Line in jack on your computer. you should then be able to record to .wav, .mp3s etc. with an audio program like Nero.
Dec 22, 2008 | Technics SUV500 2-Channel Amplifier
Akai recording problem
You might have a bad cable to the recorder (try swapping the right and left connections and see if the problem moves to the other channel), dirty tape heads (use a cotton swab and head cleaner or isopropyl alcohol to clean them), or a circuit problem inside the recorder. Hope this gets you started!
Nov 19, 2008 | Audio Players & Recorders
Troubleshoot
The mic is on the left side. That's how it's supposed to work. You should set your recording software to only record the left channel on one track and the right channel on another track.
The level controls are the knobs on the front.
Apr 07, 2008 | Samson G-TRACK USB RECORDING MICROPHONE...
Samson G-track
It's supposed to only record on the left side. When it's in "INST/MIC" mode the left channel has your mic on it and the right channel has your instrument, so you can mix them separately. Just configure your recording software to put the left channel on one track and the right channel on another track.
Jan 10, 2008 | Samson G-TRACK USB RECORDING MICROPHONE...
97 people viewed this question
 Grubhead
Grubhead
