Getting a E2 error on Kyocera FS-1700+. Any ideas?
The following error is freezing my Kyocera FS-1700+: ''Call Service Person E2:0021387. How best to resolve this issue?
  • 330 Answers
This service code belongs to Laser scanner unit (Polygon motor) error
check the connection between scanner unit and engine board .....
Posted on Oct 06, 2009
Error code E2 0012223
Laser scanner motor error. The polygon motor does not deliver a synchronous output (L) within the predetermined period of time. The scanner unit may need cleaning. be careful as there is a laser working in this area turn all power off before attemting. The laser unit sits under the top cover.
May 06, 2011 | Kyocera Mita FS 1700 Laser Printer
Error occurred. Call servoce person. C7980
Waste toner reservoir overflow problem (when the total number of copies is less than 100 thousand sheets) You need a new pcu
Jun 05, 2009 | Kyocera FS-1118MFP Laser Printer
Showing 'error occured call service person c6400'
Defective power supply board. or Defective engine board
May 31, 2009 | Kyocera FS-1118MFP Laser Printer
Call service 7410:0100539 on a Kyocera fs2000d
I have heard that 7410 is a standard code meaning the drum is out of position. Seat the drum correctly and away you go.
David
www.copycare.net
Jan 21, 2009 | Kyocera FS-2000D Laser Printer
My Kyocera fs-3900dn has the message: call service 0150:0040557. What does it mean?
0150 - Engine PWB EEPROM error. Detecting engine PWB EEPROM communication error.
Solutions:
1. Switch the printer OFF; unplug the power cable; wait 20 seconds; plug in the power cable; switch the power ON, If the error comes back follow the next solutions:
2. Update / Burn the latest firmware version. You may need to call a Kyocera Service Provider because you need a CF card (compact flash memory card) and the FIRMWARE.
3. Replace the Engine PWB (a board) - again you have to call a Kyocera Service Provider.
Dec 30, 2008 | Kyocera FS-3900DN Laser Printer
Error Code explanation for Kyocera FS1700+
l e d are villings countineve one by one up to down
May 26, 2008 | Kyocera Mita FS 1000+N Laser Printer
Kyocera Mita FS1800 E3:e3:0060332
i looked up the manual and saw that the E3 indicated a mechanical error...the laser was bad; the other number indicates the number of copies. the machine must be repaired by an authorized dealer or replaced.
Mar 10, 2008 | Computers & Internet
Kyocera Printer error - Help!
The code is for a defective cyan motor. So its either the cyan toner motor or a lump of toner inside the cyan toner container.
Feb 29, 2008 | Kyocera FS-C5030N Led Printer
Message problem
Your error indicates that you have a problem somewhere between your engine board and your laser scanner unit. This is usually either the board, the unit or the wiring harness between the two. If you are comfortable with pulling your machine apart and using a multimeter on some points on the logic boards then you can find out which. If not then you will need to take it to a qualified technician. Sorry I don't have better news.
P.S just to explain the error to you the person is part of "call service person" the E2 Means Laser Scanner Unit (Polygon motor) error and the remaining numbers are simplye the page count of the machine.
Good Luck.
Please rate my advice, good or bad.
Feb 07, 2008 | Kyocera Mita FS-1800N Laser Printer
1,471 people viewed this question
k24674
jasbo
jasbo
