The usb port dosnot work - Office Equipment & Supplies
USB PORTS NOT WORKING
try to update or download the usb cord of your laptop
Nov 27, 2013 | Toshiba Satellite C655-s5090
Usb port not working
Printers are particular about which usb port they are plugged into, a virtual printer port is assigned to USB1 in the computer, when you select the printer port for it to use. You may need to plug the printer into each USB port, until you fine the USB port 1 which it works in, remember to always connect it to this same usb port, otherwise it will not work. There is only one USB port number 1.
Apr 10, 2013 | Brother MFC-7340 All-In-One Laser Printer
My netgear wireless-n150 USB adapter wna1100 can't detect adapter.
First determine that the USB port isn't dead. Do other things work in that USB port? If the answer is yes we know it's not the port. Have you tried another USP port? If it doesn't work in another port (or on another computer's USB port) then it's the adapter itself.
Adapters can go bad. USB ports usually work and don't go out. The exception is that many laptops that come with several USB ports sometimes have one (or more) that never did work.
Try it on another computer. This is one last step to determine if the adapter itself is dead and that it isn't something on/with your computer.
It also could be that the computer has the old USB 1 port and the adapter needs USB 2. (USB 1 was slower).
Apr 08, 2011 | Computers & Internet
Cer runs hot newrelay&temp fan dosnot seem to
If the relay and temp fan are new, and the old ones did work but not very well. Try putting on the old ones again and see if they will even choke. If they do, then it could be your new product. The only other solution i can come up with besides that, is an electrical issue, which i know from exp. can lead to a $1500 bill... good luck
Jun 06, 2010 | 1995 Oldsmobile Cutlass Supreme
I have a WD passport 320gb, at first it worked one of my usb. then all of sudden, it stop recognizing my WD Passport with one usd port, so i plug it in another usb then it works. and after a couple of days...
Are you using an external power supply for the disk? If not, you might be overloading the USB port. It should not happen, but USB ports are limited in the amount of power they can output. Especially laptops might face such problems.
Do other USB devices still work on those USB ports? If so then the port is at least not broken.
Sometimes you can uninstall and reinstall the USB hubs and controller devices in the Device Manager to fix USB problems.
For other ideas on troubleshooting external hard disk issues, you can check: www.devicedriverfinder.com/blog/device-errors/external-hard-drive-troubleshooting
Jun 13, 2009 | Western Digital Passport WDXML800UE...
Keyboard, mouse, front USBs,DVD recorder not working
It sound like your USB Ports is the problem. Go to the Hardware manager delete the USB Ports and then shutdown and power back up.
The system then should reinstall the USB Ports and associated drivers. If not the USB Ports were probably fried by the power outage.
Mar 30, 2009 | HP TouchSmart IQ770 PC Desktop
I hav compac 301tu laptop the prob is usb dosnot work
Make sure you properly install all drivers, like your processor, chipset, graphics, sound, modem, and ethernet drivers from the manufacturer's web site
Mar 13, 2009 | Compaq Computers & Internet
USB ports work at 1.1; s/b 2.0
Your computer is functioning correctly.
The USB ports on your laptop are USB1 ports its pard of the hardware.
Your PCMCIA USB 2 card runs at USB 2 speed and therefore when you connect a USB 2 device to this port you will not get this USB message.
Jan 18, 2009 | Lenovo ThinkPad R51e Notebook
44 people viewed this question
k24674
jasbo
jasbo
