Question about HP Compaq Evo W6000 PC Desktop
I get two green power lights
My w6000 won't boot ,if i turn it on i see two green led lights burning(not red)
    Sergeant:
  • 195 Answers
Checking conection inside you PC, check if all cables are connected respectivley prior to HARD drive must be connected and powered up
Posted on Oct 06, 2009
I have a compaq evo w6000, my problem is that on starting it it oly blinks red and no activity at all but when the power supply is checked all the red green blue yellow black cables are live with...
ffsffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffff
Mar 23, 2011 | HP Compaq Evo W6000 PC Desktop
Cannot open the disk and cannot read the disk as well. The green light at the center of the ring always blinking
Hello
If you only get a flashing green light on the center while you turn on the console. You should get a green light going in a circle around the center light, (the 4 other lights, that can turn red as well (famous Red Ring of death))
if you don't get any red or green lights around the flashing center ring, then the console is not able to turn on / boot up properly and is in need of repairs, check the powersupply led, what color is it? it should be green when you power on and orange when not in use.
Jun 08, 2010 | Microsoft Xbox 360 Console
The last led light blinks green and sometimes it turns solid red
red light is stands for hardware boot and the green one is stands for system boot and disc boot. when red light remains solid it means your system is in 0% cpu usage and nothing doing, stop working
May 09, 2010 | Intel SC5299BRP
Motherboard red light stay on and computer won't turn on. Any ideas on what the promblem might be?
First try shutting down you're system. Than turn the PS off at the rocker switch (Back of PS). Ground you're self by touching the the PS. Remove you're memory and re-seat it. Than boot the system.
Check the standby LED. See if it lights green.
Pull the cmos battery and check its voltage. Anything under 2.4 volts replace the battery. Normally the MB LED displays green. (Standby power).
This means the MB is maintaining / charging the cmos battery. If the battery can no longer maintain charge this will cause the MB LED to turn Red. Built into the mother board is a small switch. When the system is shut down the MB maintains power to the cmos. If the standby switch fails to function correctly the LED will turn Red. Lets hope the problem is the cmos battery. The internal switch can not be repaired.
Cheers'
Mike
Feb 02, 2010 | AOpen S651M (918EM10S50) Motherboard
Power light on& status light on
The power red led indicates that your device is "power on" , but the status led still red and turn to green if the device ( video input )received video signal ( from DVD player, Laptop etc. ) .
Apr 29, 2009 | Computers & Internet
PC will not boot, power button flashes red
YOUR POWER SUPPLY HAS MORE THEN LIKELY GONE
remove your power supply and take it to a pc repair store they should test it for you on the spot at no cost most of them do.
To replace depending on what you need there about 40.00
Jan 24, 2009 | HP Compaq Evo W6000 PC Desktop
No Picture & No sound. Red LED, Green LED, Red LED.
If the power supply outputs are good! Then I would say the back light inverter is bad! If the screen stays black and does not come on.
Jan 14, 2009 | Akai LCT2660 26 in. HD-Ready LCD...
GREEN LED WILL NOT LIGHT
the ps2 connectors are shorted so the mobo out highly recommend replacing mobo
Nov 26, 2007 | EliteGroup P4M800PRO-M Motherboard
Laptop crashes shortly after boot, power light rapidly blinks red.
Its late, so just to make sure I'm not brain-dead basically your laptop runs fine as long as its powered by the AC adaptor but dies fairly quickly while running via battery. This is very typical of a battery that will no longer hold a charge, not normally a user repairable item. It could also be that the charging electronics (in the laptop) isn't charging the battery, again not a typical user repair job. About your only option short of taking it to the repair shop is buying or borrowing a battery as a test.
Dec 12, 2006 | Medion (40010998)
HP Compaq Evo W6000 PC Desktop Logo
80 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
