Question about Zebra Symbol Technologies MC909X-G Series Barcode Scanner
One of our MC9090-GJ0JBEGA2WR devices is not switching on now. Before that situation it was without battery about an hour. What can be a reason of it? (When it is in cradle the LED of the device is shining)
  • 47 Answers
Try a forced cold boot -- hold down thepower button for about 30 seconds. If it doesn't work, you have lost your application. You will probably have to reload the software. The intenal battery (it's actualy a capacitor) will only hold internal memory for about 15 minutes without the battery in the device -- after that anything in RAM memory is gone. Contact your hardware vendor
Posted on Nov 04, 2009
Hi my MC9090-G wont power on.
On an MC9090, with the battery removed, hold both power and trigger down, then insert the battery, and keep holding both buttons down. Wait for the onscreen display.
Feb 28, 2013 | Symbol MC9090-G RFID Handheld Barcode...
When I press the keys on my MC9090 they give the wrong output.
The Motorola MC9090 can have different keypads attached. If you do change the keypad for any reason for example go from a 53 key to 43 key layout the terminals must be cold booted.
To cold boot an MC9090 running Windows Mobile 5. Partially remove the battery, hold down the On/Off button, the trigger and reinsert the battery. When the orange light on the keyboard flashes release the on/off button and the trigger.
If the on/off button or trigger is held down longer than required this occasionally causes the terminal to get caught in a warm boot cycle
If the device is still not giving the correct key output it may have a faulty keypad.
If you need any more help then please do not hesitate to contact us:-
helpdesk@biastechnology.com or TEL +44(0)1202 620955
http://www.biastechnology.com/
Jul 11, 2012 | Zebra MC9090-G Barcode Scanner
How do I get Symbol / Motorola MC9090 wireless settings to be
This is an old post but I'll give my solution anyway!
I anticipate that you're not exporting the connections:
Open the Wireless Menu icon on the task bar (Close "Manage Profiles" if it is open, select "options".
Select from the drop down "Regulatory" and select your country of operation (e.g USA), de-select "Enable 802.11 d", click Save.
Select from the drop down "Export", click "Export Options", click OK top right, click "Export All Profiles", click OK top right.
Now if a cold boot is performed the device will retain the added network profiles.
Cheers!
Apr 27, 2012 | Zebra Symbol Technologies Mc9090 Moble...
Have an MC9090 that times out after 3mins. I know how to change the timeout in Cntrl panel but the settings go back to original if the scanner is rebooted? Any help would be appreciated. Thanks
Hello george parce. You're details are perfect and I can help you here. The reason your settings aren't returning after a reboot is due to the backup battery. I'll spare you the technical details (but if you'd like them, just send me a message or email and I'll happily provide) and get straight to solutions. The backup battery gets it's power from the main battery and also charges thusly. Realize that it usually takes a whopping 15 hours to fully charge this backup battery. I recommend to all my clients having this problem that they leave the unit in it's cradle with the main battery in overnight or a little longer. This will at least get a good charge in the backup battery, if not charge it fully. If the problem persists, I recommend you contact Motorola/Symbol or the vendor you purchased it from about warranty/repair for the backup battery. I hope this helps and at the very least have helped you isolate the issue. Good luck!
Jan 06, 2010 | Symbol MC9090 Barcode Scanner
How do I change the sleep timer settings on a Motorola MC9090
A - From the Windows Mobile user interface:
1. Tap Start (the Windows Logo), then Settings.
2. Tap the System tab.
3. Tap the Power icon.
4. Tap the Advanced tab.
You can change the number of minutes before power is turned off when on battery and when on external power from there. You can also uncheck the "Turn off device if not used for" check box to disable the timeout entirely.
B - From the registry (useful for deploying the setting as a .reg file to the device, in case you have many MC9090 guns you are supporting or you are wanting to set it to a value the user interface does not support):
[HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Power\Timeouts]
"BattSuspendTimeout"=dword:00000000
"ACSuspendTimeout"=dword:00000000
The above values are in hex and represent the number of seconds before timing out when on battery or AC power. For example, to set the BattSuspendTimeout to 180 seconds, you would set it to dword:000000B4. To disable it entirely (the equivalent of unchecking the checkbox in the user interface), set the value to 0.
Thanks,
Brad Radaker
Radicomm, Inc.
(makers of QuickTalk - push-to-talk over WLAN for MC9090)
www.radicomm.com
May 12, 2009 | Zebra Symbol Technologies MC909X-G Series...
Wifi switching off automatically in mc9090
plug a car charger or mains charger into it and get power back to it before the battery gets low :D
Apr 18, 2009 | Zebra Symbol Technologies MC909X-G Series...
Not ABLE to switch on MC9090. tried replacing the battery . Held the power button for 2 mins . nothing is working. Is there any key combination to start the reader ? please help.
I know it may be a little late now since you're question was a couple months ago, but I have had this problem with some 9090's before too where a warm boot (holding the power button down) will not bring them up, but a cold boot always does (unless of course it truly is defective - that's not usually the case though).
To do a cold boot, pop the battery out part of the way until it "catches" (you'll know what I mean if you have an MC9090 and try it). Then hold down the trigger and the power button simultaneously while pushing in the battery all the way. Once the battery has been pushed in, release the power button and the trigger.
This should cause the MC9090 to boot up fine. Make sure you release the trigger after doing the steps above. Sometimes people don't do that, and this causes the MC9090 to go into an infinite warm boot where it just continuously reboots over and over. The only way to get out of it is to cold boot again, but this time release the trigger in time.
Thanks,
Brad Radaker
Radicomm (makers of QuickTalk - push-to-talk over WLAN for the MC9090)
www.radicomm.com
Mar 02, 2009 | Zebra Symbol Technologies MC909X-G Series...
Zebra Symbol Technologies MC909X-G Series Barcode Scanner Logo
213 people viewed this question
Top Zebra Computers & Internet Experts
pkwc
Mike
Are you a Zebra Computer and Internet Expert? Answer questions, earn points and help others
