Question about HP Compaq Presario F560US Notebook
Starts sometimes. butotherwise justpowerlight, charging light and wireless, then two grunts from the hard disk.
    President:
  • 987 Answers
ITseems that your hard disk is developing bad sector ..its the time to replace it ..
Posted on Oct 06, 2009
Healthrider 15.5 won't run,motor makes alittle grunt,turns alittle but won't run,incline motor works
hi Geoff,
if it is contain belts please check.and try to move running belt it must run freely.sometimes it must stuck because of long idle time.
in electronic circuit the large smoothing capacitors can be damage because of long idling time too.
let us know the status,
regards.
nuwan
Jan 10, 2014 | Exercise & Fitness
Sander disk stops spinning on contact.
It sounds like a gear is worn out inside the sander.
Many of these have a gear or a splined shaft on the end of the motor armature, and the shaft or gear meshes with another to make the disc turn.
One of your gears or shafts has likely worn out.
Sometimes these can be fixed ( I've done a few) , but sometimes the repair parts are either unavailable, or too expensive to make it worthwhile.
Be blessed.
Mar 10, 2013 | Tools & Hardware - Others
My laptop is not starting when I plug in adopter the charging light shows but when I press start button light goes off and it does not start. Is this a battery problem. I always use the charger/adopter to...
Try removing the battery and then starting the computer with the power cord. Sometimes the battery is bad and prevents the computer from working properly.
Aug 02, 2017 | Acer Ferrari 3200 Notebook
Engine won't start
Hello get in turn key do not crank or start just until dash lights come on while haveing your head turned towards passenger seat.The sound you are listening for is a fuel pump"GRUNT"GRRRR sound last for a second if you do not hear this chances are your fuel pump is not working.You migt have to repeat those steps a couple of times to be sure you do not hear the fuel pump grunt.
Dec 27, 2009 | 2004 Mercury Mountaineer
Light on left side blinking constantly
what is the symbol next to that light?
If it is the Hard disk light that is considered mnormal when the PC is on - especially if you are running VISTA
Nov 10, 2009 | Toshiba Satellite L15-S104 Notebook
I have had problems with truck starting
When it wont crank, tap on the starter with a hammer, wrench ect. if it starts then, most likely need the starter replaced. If it grunts, its getting power. Make sure the battery is good. to check, take a voltage reading should be 12.7 volts on a fully charged battery, take a reading when starting, should not go below 10volts.
Sep 18, 2009 | 1995 Nissan King Cab
WD My book flashing light
I think you have burn your power supply coord! Sometime powercoord have the same plug but the voltage are not the same laptop run sometime at 18v when hd is at 12v. On your HD look arround the power coord hole, you should be able to find wich voltage you need to operate it!
Jul 04, 2009 | Western Digital My Book Essential Edition...
Cd does not spin
the motor will need to be replaced
Apr 15, 2009 | Fisher SLIM-1500 CD Shelf System
93 intrepid wont start
turn key to on position do not crank engine when gas gauge moves up and all lights up in dash you should her a grunt sound from back seat area to deterimne if fuel pump is working no grunt no fuel pump!!
Nov 30, 2008 | 1993 Dodge Intrepid
HP Compaq Presario F560US Notebook Logo
55 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
