Question about Hotpoint RLA30 Compact Refrigerator
THE FRIDGE IS FREZING UP AT THE BACK THE DIAL IS SET TO NUMBER 1
    Sergeant:
  • 236 Answers
PLEASE fix your dial at 6-7, then you will be able to solution.
Posted on Oct 06, 2009
I have a small daewood refrigerator with icebox. If I want to lower the temperature do I increase or decrease the number?
Good question :>) You should always have a small thermometer in the fridge and freezer.
Most refrigerator temperature settings are controlled with a dial or slider. They are sometimes labeled 1 through 5 or 1 through 9. If you are not sure what to set it to, then set it somewhere in the middle. If the dial is numbered 1 to 5 set it on 3, if the dial is numbered 1 to 9, then set at 4. USUALLY the higher the number on the temp control dial, the colder the temperature your refrigerator will get. If your drinks and food are not as cold as you like, set the temperature dial up one number higher. If it is at 3 and you want your food colder, set it to 4 and test 12-24 hours later to see if your food is at the temperature you need.
Refrigerator Temperature Control Dial What Do The Numbers Relate To Cold...
Mar 22, 2018 | Refrigerators
Top of fridge freezing with temperature on lowest setting
You need a new thermostat but there are some things you can check in the link. 1 is the warmest setting.
Most refrigerator temperature settings are controlled with a dial or slider. They are sometimes labeled 1 through 5 or 1 through 9. If you are not sure what to set it to, then set it somewhere in the middle. If the dial is numbered 1 to 5 set it on 3, if the dial is numbered 1 to 9, then set at 4. USUALLY the higher the number on the temp control dial, the colder the temperature your refrigerator will get. If your drinks and food are not as cold as you like, set the temperature dial up one number higher. If it is at 3 and you want your food colder, set it to 4 and test 12-24 hours later to see if your food is at the temperature you want.
Why Is My Refrigerator Too Cold
Dec 18, 2016 | Refrigerators
My upright Candy fridge freezer is 14 years old. The fridge is 5 the freezer is -27.9 how can i adjust it?
turn the dial to a lower number . wait a couple hours and check temps if not low enough set even lower number on dial till it gets where you want it .
May 12, 2015 | Candy Refrigerators
My mrf335 fridge is too cold even in stand 1.
I can't find your model listed anywhere, could you confirm the model number?
Either way, you'll want to check your temperature settings on the fridge. If there's a dial in the fridge, make sure it's not set too low.
Nov 26, 2014 | Refrigerators
My fridge keeps frezing up
There's a little dial or knob to set the temperature of your fridge, just wind it down to about 4 if it has a number setting and that should keep from the contents freezing up.
May 06, 2011 | Hotpoint HSS25GFP Side by Side...
How do I set the temperature?
Hello Elise, The Dial should be set to the middle number three (3) to start with and allow for 24 hours of running before you make any adjustments, either up or down.
The higher the number the colder the fridge temperature will be. Just remember that it takes almost a full day for the fridge compensate for any changes to the thermostat. Also, only make adjustments in the temperature setting by only 1 increment at a time (either up or down) and again, allow 24 hours before making further changes.
If your fridge has the red button in the center of the temperature dial, that is the manual defrost button. So if you've got a build up of ice on the freezer section, just push it and it will defrost the unit for up 2-4 hours.
Hope you find this Very Helpful and best regards!
Merry Christmas!
Dec 14, 2009 | Magic Chef MCBR440 Compact Refrigerator
My freezer is working fine but refrigerator is not as much cold as it is suppose to be. Is there is a trip button somewhere I can check.
Could be a couple things. Turn freezer dial control to suggested setting---usually 5. turn fridge dial up. if you set the freezer dial to a higher number it will divert more air to freezer, turning down will divert more to fridge.
Clean coils in back or under fridge.
Is ice building up in freezer?
Are your door gaskets sealing?
Oct 21, 2009 | Kenmore 50522 / 50524 Side by Side...
I don't know how to set the temperature setting on my Hotpoint RLAV21 fridge. The dial goes from 0 to 4. For fridges I have had in the past the higher the number the colder the fridge but I've got my...
You should have 2 dials one is the thermostat when you set it all the way one direction it will shut you refrigerator off. Turn it back to about the middle if there are no numbers. The other dial is the air damper between the freezer and the refrigerator. The fan circulates the air through refrigerator by this damper. If you open this open to much your food in the refrigeration section will freeze. Close it back to about 2 that will give you a colder freezer and should be about right for the refrigeration section.
May 17, 2008 | Hotpoint Refrigerators
Hotpoint RLA30 Compact Refrigerator Logo
258 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
