Question about Kenmore 64702 Top Freezer Refrigerator
Freezer in bottom of amana is freezing up
The freezer was iced up the fan was still working Defrosted the bottom in 4hours without using hair dryer.. left the bottom drawer open and removed all inside frozen food . after turning dial to off. Cleaned the bottom of freezer floor minimal bits.next step turned it on low and replaced 3 frozen fish bags.3 hours later it was frosting slightly . during the afternoon while in kitchen heard low growl noise.I have called amyslist fridge repairperson because I am a 79 year old widow My husband fellfrom a uw hospital bed and was in a 9 month vegetative state until death lost the wrongful death legal action HE was a magnificent mand and a great auto mechinic, electrician and handyman beside s being a excellent health care administrator sorry miss him Donna H
  • 4,924 Answers
Ok ..what exactly seam to be the problem ??
I understood that you defrost it with success...and cleaned...after that all you have to do is power it up again ...and set the temp that you wish ..and let it work .....if it about the loud noise..and irregular... this is cause you moved it slightly ...and the position isnt the perfect horizontal parallel with he ground...try to push it easy from each side ..when the motor is working ...and see when the noise is lower ..that is the side that needs lift with a few mm or so ...also if you try to move it a bit the noise might attenuate...
let me know if you wanted to ask something in particular and forget ...
Posted on Oct 06, 2009
GB2SHDXPS01 FAN RUNS CONSTANT, FREEZER ICES UP
Buy a used fridge on ebay, they are very cheap.
Dec 21, 2013 | Whirlpool GB2SHDXP Bottom Freezer...
The coils in the. Back of the freezer keep freezing up! I use a hair dryer to thaw...freezes up again...what is wrong
The problem could be in the draining of defrosted ice. The drain may be clogged thus allowing water to back up. Next I would check the fan and make sure it is running. The last thing if that doesn't help is get a refrig specialist to check out evaporator and compressor. Now consider this, if it is much older than 10-12 years old , you may want to replace it. His sometimes is the beginning of the end.
Feb 03, 2013 | Amana ABD2533DES Stainless Steel Bottom...
Kenmore refrigerator(model 10653606202) freezer is cooling, can hear the circulation fan' noise, also see defrosted water in the bottom collection pan. but the refrege is not cooling.
If the freezers is freezing everything and you can hear the circulation fan, maybe it is a defrost problem. Sometime ice will build up behind the rear panel in the freezer section that blocks either the chilling tubes to the refrigerator section.
You will need to remove the food from the freezer, then remove the shelves and inside back panel of the freezer. If you see a lot of ice, that is probably your problem. DON'T use water to defrost, either unplug and let it set with the door open or hurry it up with a hair dryer.
It also means your defrost assembly has stopped working and will need replaced, but the unit will work without it for several weeks before the ice build up redevelops.
Jun 07, 2011 | Refrigerators
Amana fridge. french door ice maker now seems to freeze overflow of water so i'm using hair dryer frequently to remove the clog. why is this starting
Your defrost assembly has probably stopped working, which means that you are probably also building up ice in between the panels.
Jun 06, 2011 | Amana AFI2538A Bottom Freezer French Door...
The freezer part of the refrigerator is not freezing well. and the top part of the refrigerator is running at approx 63 degrees
Pull the unit away from the wall and unplug it. Remove the front floor plate and rear panels and then vacuum dust and pet hair away. Look for frost on inner walls of the freezer. If you find any ice, try to remove the inside panel and let the ice melt. I used a air dryer to melt the ice quick with an Amana bottom freezer. vacuum the dust and pet hair at least twice a year.
Jun 13, 2010 | Samsung RB2155 Bottom Freezer Refrigerator
Frost is building up in bottom freezer. Amana ABB2224DEW
I have this problem as well, only nobody is leaving anything open. The defroster is defective of these things and the duct between the fridge and freezer gets frozen over and the cold air can't get in the fridge, so the freezer keeps working until it's blue in the face.
Apr 19, 2010 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Amana model SXD25QA3W. Not cooling. Compressor runs.
Low on refrigerant which is R 12. EPA has stopped the manufacture of it and it is priced out of sight.
You have a leak and will need it fixed. Compressor is about $300-400 list. You don't want to go there.
Good luck but likely 15-17 years old....... New one ???
Aug 17, 2009 | Amana SXD524VW Side by Side Refrigerator
SERVIS MO262S FROST FREE FRIDGE/FREEZER, FRIDGE NOT WORKING
servis frostfree fridge freezer not working after 2weeks holiday returned it had completely defrosted fridge & freezer power supply still connected. warning light on. done all the trouble shooting in the srvice manual still want go cold or freeze. light on in the fridge, no water in the rear tray & cleaned the overflow pipe??. Model No M0330-ALU 5yrs old. think it has 2 seperate thermostats, surely they wont both have gone at the same time???????
Mar 30, 2009 | Amana ATB1832AR Top Freezer Refrigerator
Refridge not cooling
freezer side is working good but cooling side is not cool
Sep 24, 2008 | Amana ARB8057CSR Bottom Freezer...
Refrigerator
It sounds like you found it. Change the defrost timer.
Jan 16, 2008 | Amana DLE330RAW Electric Dryer
Kenmore 64702 Top Freezer Refrigerator Logo
27 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
