Question about Pentax K100D Super Digital SLR Camera
Pentax k100d super, battery problems, New batteries last only a few seconds and then register as flat.
  • Obertelli
    Obertelli May 11, 2010
    Exactly which batteries are you using? (4 xAA or 2 x CRV3?) It's also vital to know whether they are lithium, alkaline or rechargeable NimH. Note that alkalines will register as flat on your camera even when they have plenty of power left due to different internal resistance and output voltage characteristics. You should ideally stick to lithium or NimH rechargeables. Note that there are loads of super cheap no-name and counterfeit batteries around, especially "lithium" CRV3 units where genuine ones are never cheap.
5 Suggested Answers
SOURCE: pentax K100d super
I fixed the problem. It was caused by an extra little pimple on the sirius lens slipping into the auto focus indent indent on the camera body.
It is possible to get up to a ten thou engineers feeler gauge into the gap between lens and camera body although the one that did it for me was a three thou gauge.
I needed to cut the feeler gauge square at the tip and then, even though it was only three thou, I hit the tip by resting on a vice and tapping with the ball end of a small ball pein hammer. This caused the tip to form with a small curve. I then used a tool makers file to smooth the end down to almost nothing.
Turn the camera AF MF switch to AF to raise the screw. Fiddle the feeler gauge into the slot between body and lens just near the AF MF button and very gently probe the gauge. You are trying to get the little curve you made on the feeler gauge to slip over the pimple on the lens.
Its a very nice feeling when the gauge slips right in and the lens comes free.
The next proceedure, if you want to use the lens, is to unscrew the aluminium mount at the end and remove the offending pimple on the lens.
Posted on Jun 02, 2008
mail541
  • 58 Answers
SOURCE: Pentax K100D will not power up
First make sure you are using fresh lithium batteries. These cameras indicate low batteries quite early on. Rechargeables even when freshly charged are marginal.
If the problem persists remove the batteries. Set the camera switch to the off position. Set the focus switch to manual. Wait at least a minute. Then replace the batteries and switch on again.
Operating with low batteries can confuse the firmware and it may be stuck in a low-battery loop. If this is the case this should reset the camera by allowing the electronics to power-down completely.
If this does not work you wiil have to contact pentax support.
Posted on Jan 21, 2009
  • 11967 Answers
SOURCE: won't turn on even with new batteries
Clean the battery contacts inside the camera with a cotton swab lightly dampened with rubbing alcohol.
Posted on Dec 17, 2009
SOURCE: New Pentax K100D Super, shutter does not work. Av
I suspect dirty contacts on either lens or body. Clean contacts. Should alleviate problem. This happened to my K100d.
Posted on Dec 25, 2010
I have Pentax 100D and using Ni-MH battery. But battery is going empty very quickly after few photos
Sounds like, due to age, the batteries aren't able to hold their charge well anymore. I'd suggest picking up a new set of Ni-MH batteries.
May 10, 2011 | Pentax K100D Digital Camera
New Pentax K100D Super, shutter does not work. Av -- flashing 688 under battery sign. Replaced new batteries did not resolve problem
Dec 11, 2010 | Pentax K100D Super Digital SLR Camera
Won't turn on even with new batteries
Dec 17, 2009 | Pentax K100D Digital Camera
New batteries fitted but low battery flashing and wont switch on in K100D
Try cleaning the battery contacts in the camera with a cotton swab lightly moistened with rubbing alcohol.
Nov 17, 2009 | Pentax K100D Digital Camera
Pentax K100 Super D clicks, but no pictures.
Hate to say it, but it's dead. My Pentax K100 D Super did the same thing. Took it to the local camera shop. They scratched their heads and sent the body to Pentax. The reply that came back was that the circuit board was completely fried and it would cost more to fix than it would to buy a new body.
I was out of luck because the warranty was out (had it a year and a half), but with yours being less than a year, you should be able to get a new body without having to shell out $$$.
Jun 11, 2009 | Pentax K100D Digital Camera
Bad USB conection?
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Feb 11, 2009 | Pentax K100D Digital Camera
Dec 31, 2008 | Pentax K100D Digital Camera
Pentax K100D super lens problem
Read the K100D manual. Go to the Setup menu and allow for lenses with manual aperture settings.
Aug 04, 2008 | Pentax 100-300mm f/4.5-5.6 SMCP-FA Zoom...
Power drain?
try to replace new rechargeable battery, recharge it in specified of numbers of hours.
Dec 25, 2007 | Pentax K100D Digital Camera
Pentax K100D Super Digital SLR Camera Logo
491 people viewed this question
Top Pentax Cameras Experts
mohamed salim shaikh
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
