Question about HP PSC 1315 All-In-One InkJet Printer
While inserting blaci ctridge shown an error on
While inserting black catridge after refill shown an error message like this
- catridge not ready / error
  • 330 Answers
Use new and origenal catridge and try......
Posted on Oct 06, 2009
I refilled the catridge and inserted its showings a message check color ink
Press and hold the Stop/Reset button until the message disappears. You will have to do this every time you insert a "new" refilled cartridge.
Sep 15, 2012 | Canon Pixma Mx340 All-in-one Inkjet...
Hp4355 print catridge error
Each cartridge having printing life, as long as cartridge health condition is good it won't gives any trouble. Subjected series printer having mono & colour cartridges,1. Remove both cartridge from the printer 2. Switch on & wait till message appears for insert the cartridges..3. Insert mono(Black) cartridge, close the door & wait till message appears on screen. If message appears same as cartridge error mean that mono cartridge is faulty replace it, if message appears like insert another cartridge, it's confirmed that colour cartridge faulty.. Replace it..
Apr 28, 2012 | HP Officejet 4355 All-In-One InkJet...
Service error 6500 ix4000
The Canon website indicates that is a hardware problem, there's nothing i can do. You call a technician or the canon help support. This is the description of the code:
Other hardware error [6500] - Logic board ***'y (QM2-3393 / QM3-1654)
Mar 02, 2011 | Canon PIXMA iX4000 InkJet Photo Printer
After refilling the catridge printer shows a error "insert catridge card "
hi
in order to have a succes refilling you need
to insert a new sim card that is always with
the new toner
in case you have n't got it with the refill bottle
you can check on net for aftermarket cards
that cost about 10 $ each
Jan 10, 2011 | Xerox Phaser 3200MFP All-In-One Laser...
Ink catridge error after replacing my ink catrigdes
you need hp 22 and not hp 57
you can still refill the old one
check here how
Jul 14, 2010 | HP Officejet 5610 All-In-One InkJet...
I changed my black ink and now i get the message left cartridge incorrect..how do i fix it?
HP PSC 2210 InkJet Printer. The following has to be done for checking the Blank Ink Catridge working : 01. Remove the existing Black catridge and Color Catridges from the Printer carefully. 02. Clean the location with a soft cloth with cleaning liquid to make the place dust free. 03. Put the correct black and colour cartridges recommended by HP and that too genuine one. 04. Do not use any refilled or reinked local catridges that will spoil the HP PSC 2210 printer. 05. Re-install the catridges both Black and Colour properly. 06. Take a test print out - both black and colour print outs. 07. Check the Printer status and there is no warning of Cartridges wrongly inserted. Have a Good day.
Jul 14, 2009 | HP PSC 2210 All-In-One InkJet Printer
Cartridge error
In this case make sure that the catridges are inserted in the right slot...... The Colour Catridge should go in the right side and the black Catridges should go on the left side.... Make sure the catridge which u are using on this printer is the right one.......... It should not be a refilled cartridge if it is it will not work because Lexmark printers are not designed to work with Refilled catridges it may damage ur Printer......... If everything here is fine just take out both the catridges...... Take a Dry Paper Towel........ Clean the copper contacts on the printer as well as the Catridges....... Unplug the Power Supply from the Printer............ Replug it in and if still it says catridge is missing then may be a problem with the catridges.............. Hope it Works..... Good Luck........
Jan 17, 2009 | Lexmark X4270 All-In-One InkJet Printer
Supply Memory - Error on Black
A supply memory error is the smart chip on the cartridge. It can also be a physically damaged or locked / froze catridge. In this case the machine is identifying the black cartridge. The first thing to do is replace the cartridge (black).
If it's missing or has a corrupted smart chip lots of weird errors can result but they will usually still direct you to the specific cartridge to replace. If it's a refilled or remanufactured cartridge I would HIGHLY suspect that is the issue.
To locate the smart chip to see if it has come loose, see the picture below:
It's the green little computer board in the picture. Make sure it hasn't come loose. Below is a close-up of the chip. If it is a remanufacture or refill it should look slightly different than shown in the picture as the picture shows an original HP chip. If it's the exact same and a refill, return the cartridge to your supplier.
Hope this helps you. If so hit it with a FIXYA. If not, try to get the printer to print a configuration page or error report and let me know the last couple errors shown by numbers. (Full numbers, like 10.10.1000 or 13.02.05.)
Cheers
Aug 20, 2008 | HP Color LaserJet 2600n Printer
Printing problems
U have faulty print cartridges. {rint cartridges are not like oner cartridges, after they run out, they are not going to give u the quality printing , especially if the cartridge isnt refilled by a professional.
Nov 17, 2006 | HP PSC 1350 All-In-One Thermal Printer
HP PSC 1315 All-In-One InkJet Printer Logo
98 people viewed this question
Seeker5211
Seeker5211
