Question about Epson Stylus Pro 7800 InkJet Printer
It says Service Call Error 00000101 What to do???
  • Epson Master
  • 19,396 Answers
00000101
00000101 means Ink Tubes worn out.
This error is returned when the motor exceed a number of service hours, to prevent the risk that ink tubes connected to the motor risk to break, leaking ink and compromising more parts.
The printer must be serviced by Epson.
To temporarily use the printer you can try the reset below:
  1. Turn off the printer
  2. Hold down the three leftmost arrow buttons [left-arrow] [down-arrow] [up-arrow]
  3. Turn on the printer
  4. Release the buttons
  5. A new menu will appear
  6. Press the up/down arrows to get to the "Clear Counters" menu
  7. Press RIGHT
  8. Press the up/down arrows to get the desired reset and reset all counters.
You can see the procedure explained at page 50 of the Service manual.
Posted on Nov 09, 2009
Gwl 11 wont rinse or spin
(00000101) Phase 1 - Communications Fault
The Display Module has had difficulty communicating with the Motor Controller.
Primary Source: Display Module.
Action: Turn off at the wall and on again after 5 seconds and try again.
1. Undo 2 screws at the back
Check connections of the 12 way harness for bad contacts,
corrosion etc.
2. Check for moisture in the console area. Dry out if necessary
2. If still faulty, replace the Display Module
3. If still faulty, replace the Motor Controller. If the new Motor
Controller corrects the fault, then refit the original Motor Controller.
Oct 11, 2014 | Fisher and Paykel Washing Machines
What i can do for this probleme 00000101
Looks like you need a new carriage return motor or a new printer. I found to code under Service call online.
00000101 - CR Motor reached end of life - Replace carriage return motor
May 21, 2014 | Epson 4880 Stylus Pro InkJet Printer
Service call error 00010040
Common Error Codes
00000101 The CR Motor reached it's end of life. 00010000 PF Encoder Check Error. 00010005 CR Motor is out of step. 00010014 Pressurising failure. 00010027 Pressure pump micro air-leak error. 00010040 Printing position error. 0001002D The cleaning unit reached it's end of life. 0001003F The Pressure Motor reached it's end of life.
Servicing Levels
Three levels of servicing are available and detailed below:
  1. Basic 0040 or 0001002D maintenance procedure: This will return your printer from either the 0040 or 0001002D error to a working state by replacing only the relevant maintenance items.
  2. Advanced 0040 / 0001002D maintenance procedure: As well as replacing the parts relating to the maintenance error additional adjustments such as bidirectional/unidirectional alignment, 980mm feed adjustment, firmware updating and a general clean will be performed.
  3. Overhaul: All maintenance items as well as the PF, CR motor and belt, cutter cap, pressure assembly and cutter solenoid will be replaced. A check for any design defects such as a defective cutter cap and a defective pressure lever will be performed and any parts will be replaced if necessary. All head and feed alignments will be performed as well as any required software updates and sensor verifications. A thorough clean will also be performed on the carriage area and the print head. When the procedures are complete a survey will be performed to better understand your requirements and any recommendations will be brought forward.
info.gifIt is recommended that if you have recently come into ownership of a second user Epson Stylus Pro 9800 then you should assume that the counter values or service life levels are incorrect and choose the most thorough procedure detailed above. The reason for this is an increasing number of printers being "reset" without the actual parts being replaced or inexperienced owners trying to repair or replace parts incorrectly. In one such case a part was removed and replaced incorrectly causing a serious ink leak which was luckily caught early due to the undertaking of an thorough maintenance procedure, but unfortunately extensive damage had already been caused to the chassis and maintenance tank area.
I copied the error code and put it in the search bar in a web browser and came up with the answer. In the future just google the codes and see what comes up. Also you can download a Field Repair Guide PDF and a Manual PDF from Epson's website too.
Jan 25, 2013 | Epson Stylus Pro 9800 InkJet Printer
Error call service 4000:00433933
The codes on this model are the same as on the Kyocera Mita copiers.
ie: 4-digit codes
Call service 0150 engine pcb EEPROM error
Call service 0420 option paper feeder communication error
Call service 1010 lift motor lock error
Call service 1140 lift motor going up error
Call service 1150 lift motor going down error
Call service 2000 main motor error
Call service 2200 drum motor error
Call service 4000 laser scanner unit (polygon motor) error
Call service 4200 laser scanner unit (pin photo sensor) error
Call service 5100 short-circuited main charger output
Call service 6000 broken fuser heater lamp M wire
Call service 6020 abnormally high fuser thermistor M temperature
Call service 6030 broken fuser thermistor M wire
Call service 6400 zero-crossing signal problem
Call service 7000 toner motor lock error
Call service 7410 drum unit non-installing error
Call service F000 communication error between the main controller board and operation panel board
Call service F010 main board (system DIMM board) checksum error
Call service F020 main or expanded memory error
Call service F030 general failure
Call service F040 communication problem between main board and engine board
Call service F226 main pcb video data control error
May 18, 2011 | Kyocera FS-3900DN Laser Printer
What should I do, I get on the monitor 'service 00000101.
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error hope this helps
don
Mar 03, 2011 | Computers & Internet
I get a message service required 00000101
Hi heres is the xplanation of your error code and future error codes you will get on that printer try to visit:http://www.inkjetcolorsystems.com/download/Epson4000FieldRepairGuide.pdf
thanks
Jan 02, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Computer shows no display
did you try installing newest drivers from intel/gigabyte website? what you described looks to me as a overheating problem. try running the game with case open. are you running on the integrated GMA graphics or PCI-E graphics card(like geforce, radeon)?
Jul 02, 2009 | Gigabyte Computers & Internet
I need cheat codes for spectrobes:Beyond The Portal
  1. 0_folder_icon_nds.gifAll Minerals
    d5000000 63636363
    c0000000 00000010
    d6000000 023db698
    d2000000 00000000
  2. 0_folder_icon_nds.gifAll Weapons and Armour
    023db850 01010101
    123db854 00000101
    223db856 00000001
    023db844 ffffffff
    123db848 0000ffff
  3. 1_folder_icon_nds.gifFossil Codes:
    Press Select to Activate
  4. 0_folder_icon_nds.gifAll Fossils with Crown Status
    94000130 fffb0000
    d5000000 00000001
    c0000000 00000038
    d8000000 023db440
    d4000000 00000001
    dc000000 00000005
    d2000000 00000000
    94000130 fffb0000
    c0000000 00000038
    223db443 00000063
    223db444 00000005
    dc000000 00000006
    d2000000 00000000
Mar 07, 2009 | Nintendo DS Lite Console
Epson Pro 7600 Service required error
You need to be able to clear the counters in the printer that tell the printer to stop working.
In order to do that you must
1. Turn printer off
2. you must hold down the "Paper Source, Paper Feed, Select Feed, Cut/Eject" buttons all at the sime time while you turn the printer back on.
3. From there navigate through the menues to clear the counter that pertains to you or all.
(Error 00000101 is pertains to the print head motor)
Word of warning -
Those counters can be a pain as they cause the printer to stop working however you do need to get your printer serviced by a tech as soon as you can because the error is a warning, reset the counters lets you finsih a job, but if it goes unserviced too long it will actually break down all togther.
So even after you rest the counters you absolutly must get your printer serviced soon.
Apr 17, 2008 | Epson Stylus Pro 7600 InkJet Printer
Epson Stylus Pro 7800 InkJet Printer Logo
2,515 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
