My pc has suddenly developed a strange fault. After about 5 hours of normal use, the screen scrambles and the machine crashes or the screen goes blue then dies. Sometimes it will restart with a disk scan. sometimes it takes a few tries before it will reboot only to crash again after a few minutes. I have blown out all the dust from both the CPU and Grpghis chip coolers but the problem persists. I have Norton Anti-virus installed and is updated. No new software has been installed for over a month. I have bluetooth keyboard and mouse.
  • 329 Answers
First check monitor with other system after making it sure that its not faulty then check for RAM module
Posted on Oct 06, 2009
What is wrong with my Sanyo TV?
T'Con board fault. Check and replace it. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD screen are similar, irrespective of its brand and screen size.
Mar 03, 2016 | Sanyo Televison & Video
Solid blue screen
Too many possibilities for a blue screen.
If the computer attempts to boot and only goes to a blue screen, i'd check re-seating your memory module. If your blue screen is from a computer crash, it could be fixed the same way but more likely else. A) Make sure your computer is not overheating.
B) Make sure that the the computer has been de-fragged, this is a normal maintenance that should be done monthly at least.
C) Next option is the program your using installed correct.
D) Has the computer been crashing to a blue screen may need to be re-installed...
Good Luck
Feb 11, 2013 | Dell Latitude D630 Notebook
Mitsubibishi wd series 73"..Mitsubishi ws series 73" dlp. Works fine but after several hours of viewing screen scrambles then goes blue and sound goes off. I can switch to another input and watch ama
A couple of suggestions, if only on cable and using a box disconnect the set and box from power and after several minutes repower and see if a reboot helps.
The two models listed here both should also have a soft reset done with the original remote and the set on---Menu,1,2,3, enter.
Dec 20, 2012 | Mitsubishi WD-52525 52" Rear Projection...
Television suddenly turns black
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Aug 16, 2017 | Westinghouse SK-26H520S 26 in. LCD HDTV
Acermini purchased 5 days back, developed cracks on screen all of a sudden.please show reason AND what to do to get it replaced
LCD screens just don't develop cracks how ever hitting, punching, dropping, drop kicking and or taking a hammer to the screen normally results in this.
Good Luck,
with your return / replacement you'll need it
Nov 28, 2010 | Acer Computers & Internet
My 2001 Mitsubishi Medallion recently stopped recieveing HD channel from my FIOS HDTV Box. When switching from standard channels(they work) to an HD channel, the screen shows scrambled mutltiple images and...
If the TV works in the "Other" modes than I would suspect, that the FIOS HDTV box has developed some fault. When a TV goes to a "Blue Screen" this means that it cannot interpret a proper signal, maybe you need to reset the FIOS, anyway check that out, the TV itself, I do NOT think is faulty, check connections, antenna and to TV as well. Unplug ALL from wall wait 5 mins, and power back up, this often fixes a lot or problems.
R - Restore: Restore default settings E - Environment: Change your environment, remove from media cabinet, try different media, try different equipment (TV, router, hotspot, etc.). P - Power Cycle: Power cycle by unplugging your networking equipment from wall for 2 minutes to reset. A - Access this Knowledge Center for useful articles to resolve issues. I - Install the latest System Software Update. R - Resolved: In most cases these steps can resolve your issue.
Apr 01, 2010 | Televison & Video
I was playing online games on my sony vaio. Suddenly I got blue lines on the screen and the laptop stopped responding. So I tried restarting the laptop but I get blue thin vertical lines before the laptop...
Blue thin lines before it boots will rule out an operating system or driver fault. So it would appear something in the machine has failed.
Do you have a VGA monitor you can connect to it and see whether it shows the fault? This will show that if the fault also shows on the external monitor, it is likely an electronic fault on the main board, whereas if it works on the external monitor but not on the built-in monitor, my guess would be the cable that goes from the main board up through the hinge of the screen into it, or a connector, or an actual fault with the LCD display.
Windows booting normally once the display drivers were disabled indicates to me that Windows is no longer detecting the faulty display and therefore boots normally - possibly pointing to failed electronics in some way. It could even be corrupt BIOS that controls the video or something along these lines, though that's unlikely.
Good luck, either way it sounds like it's off to a computer repair shop. Is it under warranty?
Apr 27, 2009 | Sony VAIO VGN-SZ460N/C Notebook
Bios crshes
Try re-seating the video card first.
Nov 26, 2007 | Asrock ALiveNF6G-VSTA (MB-ALVNF6G)...
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
