Question about Datamax Prodigy Plus Thermal Printer
Got 2 datamax prodigy plus label printers which i would like to print tags with but have no idea what software to use to run it. I would like to print it as direct thermal, got the direct thermal tags but not sure if it can be done. If not then i can use ribbons, but where would i buy them from? Can it print barcodes? Please help Duy
    Champion:
  • 254 Answers
To print you need a driver and software
try www.seagullscientic.com
Posted on Feb 04, 2010
How can i send an ascii file to a network shared Datamax Prodigy Plus printer? It is not printing via send file, windows driver send command to printer works. Thanks for any help!
copy file.txt lpt1 is the command to copy the txt file to the printer, but it must be correctly formatted for the Datamax. I don't know Datamax's programming language, but at first glance that file looks like ZPL to me. If it is ZPL the Datamax can't print it.
Jun 15, 2015 | Datamax Prodigy Plus Thermal Printer
Datamax I-4208 has different position than i-4308 or prodigy max
On the I-4208s, press Menu button on front of printer. Go to Print Control. Go to Custom Adjustments. Go to Row Adjust. Change Row setting as needed. Ok to go negative.
Feb 17, 2012 | Datamax I-4208 Thermal Label Printer
We removed a stuck on label, now the printer won't print half the thermal label
I haven't seen one of these for years. However I really need more detail. In what direction is the print missing? across or down the label?
If across it most likely a dirty printhead
If down the label it could be a portion of label still stuck to the sensor.
Can you describe where the label stuck?
Aug 19, 2011 | Datamax Prodigy Plus Thermal Printer
When printing large quantities the printer skips
Itello: This happened in this cases:
label sensor is dirty or uncalibrated
label or tag is out of position
Execute a label quick calibration pressing and hold FEED button by 5 - 7 seconds and release. Also clean the label sensor.
Roberto Martinez
padrino99@prodigy.net.mx
Jul 29, 2011 | Datamax I-4208 Thermal Label Printer
I'm trying to figure out how to connect my Datamax Prodigy Plus Thermal printer to my PC. I have a 25 pin connector on the Printer labeled J2. Also a round plug-in labeled J4. My computer has the same...
If the cable works on the Zebra it should work on the Datamax. It must be a RS232 serial null modem cable.Check the serial port settings and make sure the printer setting match the PC serial port settings. Baud Rate=________? Data Bits=________? Parity=_______?Stop Bits=________? Handshaking=____________?
The typical settings are Baud 9600,8,n,1 Xon/Xoff.
Also make sure of the comm port being used. com1,com2......etc
Jun 09, 2011 | Datamax Prodigy Plus Thermal Printer
Can I print labels using DPL to a networked Datamax I-4208 using C#.NET?
greg babcok: You can do printing via tcp/ip packets or using Windows spooler. I have some example in vb.net
Roberto Martinez
Apr 27, 2011 | Datamax I-4208 Thermal Label Printer
My datamax printer keeps spitting out 8 labels everytime i hit the feed button or print something
It is the media sensor. Try adjusting and check for stuck labels in it blocking the sensor.
Jul 21, 2010 | Datamax Prodigy Plus Thermal Printer
Ido not have any problem if I print label using Zebra. I wrote codes on Visual Basic 6 to print label using Datamax printer conneccted parallel port with command L to start. The printer printed the text...
Do you have Zebra emulation firmware installed? If not, your printer will not understand the command language that you are sending to it. Datamax has its own language and you will need a branch in your code to support that if the printer does not work with ZPL.
Jan 14, 2010 | Datamax Prodigy Plus Thermal Printer
HOW TO PRINT LABELS IN DATAMAX PRODIGY PLUS PRINTER USING VB.NET
Tu necesitas utilizar comandos DPL. Pero si vas a utilizar graficos o windows true type fonts, tu necesitas un cartucho de memoria ram o flash. You need to use DPL commands. But if you use graphics or windows true type fonts, you need a RAM or flash cartridge.
Apr 06, 2009 | Datamax Prodigy Plus Thermal Printer
My datamax prodigy plus wont print out a word doucment
You need to download the Windows Drivers from Datamax Website, you can then use the printer with all Windows based applications
Apr 13, 2008 | Datamax Prodigy Plus Thermal Printer
Datamax Prodigy Plus Thermal Printer Logo
140 people viewed this question
Top Datamax Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
pkwc
Kevin Brown
Level 1 Expert
Are you a Datamax Office Equipment and Supply Expert? Answer questions, earn points and help others
