Question about Sony Cyber-Shot DSC-P5 Digital Camera
ERROR c:13:01 I purchased a Sandisk Memory Stick Pro Adapter with a 512 MB Memory Stick Pro Duo to use with my Sony Cybershot DSC-P5 and I am getting "ERROR C:13:01; please help.
SOURCE: Sony Cybershot DSC S650 Memory stick not formatting
Well I have the same camera.
And mine won't turn on.
Suggestion dont trust this camera.
Or maybe it just can't hold that much memory.
Posted on Mar 21, 2008
SOURCE: Memory Stick error c:13:01
The problem is compatibility - or lack thereof. The older Sony cameras such as DSC-S50 (I have one), which used the original version of the Sony Memory Stick, can't read the new Memory Stick Pro - even with the "Duo" adapter.
I don't know all the specifics but it has to do with how the memory chip interfaces w/ the camera, how the data is transferred -- newer models of chips/cameras use a different, faster method for data transfer which the older cameras/devices can't do. Similar to "serial" vs. "USB" vs. "USB-2" issues with older computers.
So, sorry to say, but if you have a DSC-S50 camera like I do or similar older model, you're stuck w/ the standard Memory Sticks - which I have just discovered are very hard to find any more. I just finished a sweep of all major electronic stores/outlets in my area (silicon valley - where there's plenty of them), plus many web sites. And all you can find new, now, are the Pro/Duo chips, 1GB & up.
Anyway I hope this helps!
Posted on Jun 07, 2008
SOURCE: DSC F707 Error C:13:01
If you really have a F707, it won't work with anything over 128MB according to this chart.
http://esupport.sony.com/perl/support-info.pl?&info_id=12&mdl=DSCF707#m1
Posted on Aug 11, 2008
quang123
  • 107 Answers
Is your new 2GB memory stick is original from Sony or after market? some of them will not detect in CAM because the contact on MS were not touched iside the slot of CAM
Reinsert your 512 MB MS if it work fine then change your 2MB MS
Good luck
Posted on Nov 30, 2008
  • 586 Answers
SOURCE: Error C 13 01 when insert Memory Stick Pro Duo with adapter -- which does fit.
    This error code is for Memory Stick. the Countermeasure are :
Format the “Memory Stick” or internal
memory.
CAUSE :
“Memory Stick” or internal memory is
unformatted.
Thanks for using fixya.
Posted on May 24, 2009
Sandisc 4 GB memory stick PRO Duo not working
According to the users manual, the camera does not support above 512 MB cards, however I noticed that there is a firmware update which might address the issue. Go to www.sony.com and support, electronics. Put your model number in the selection box and you'll be taken to the drivers download page.
Feb 14, 2010 | Sony Cyber-Shot DSC-T1 Digital Camera
Have Sony CyberShot DSC-F707 Sony Memory Stick Duo Adaptor and Sony Memory Stick Pro Duo 4gb When installed get C:1301 error
In DSCT1 Camera, the C:13:01 error message indicates a Self diagnostic message. Each of these codes indicates the symptoms and resolutions of the Camera. In C:13:01, the issue is with the Memory Stick being used in the Camera.
The Symptoms are:
Memory Stick Pro Duo 4GB is not compatible with the DSCF707 Camera. Maximum capacity supported by the Camera is up to 128MB. Please try using a MS with 128 MB and check if it works. A dedicated adapter (MSAC-M2) must be attached to use Memory Stick Duo or MagicGate Memory Stick Duo media.
Thanks.
KenSolutions
FixYa
Dec 24, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Memory Stick error
Hello!
Following types of memory sticks are compatible with the Camera model DSC-V1:
Memory stick: 32/64/128 MB
Memory stick Pro: 256 MB/512 MB/1 GB/2 GB.
Mark 2 Memory stick Pro: 1/2 GB.
However, in order to use Memory Stick Duo or MagicGate Memory Stick Duo media with the Camera, a dedicated adapter (MSAC-M2) must be attached.
Follow the steps given below to troubleshoot the Camera that is not recognizing any compatible memory sticks:
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C186797
Furthermore, you may try resetting the Camera to the original factory settings by pressing and holding the Reset button for 30 seconds.
If the issue persists even after performing all the above mentioned steps then the Camera is required to be diagnosed and serviced.
Aug 22, 2009 | Sony Cameras
Memory sticks "MEMORY STICK ERROR" for SONY DSC-S30/S50
this camera doesnt take mem stick pro. has to be the original lavender sticks.msh-ms128 is the model # only goes up to 128 mb. only stick that will work with that cam.
Jun 01, 2009 | Sony Cyber-Shot DSC-S30 Digital Camera
memory.
CAUSE :
unformatted.
May 24, 2009 | Sony Cyber-Shot DSC-S70 Digital Camera
Maximum Memory Stick size I can put into my Sony DSC-N1
Unfortunately, there is no way to change the internal card reader in the camera to accept higher density memory cards. You can find the memory stick compatibility list here: https://esupport.sony.com/perl/support-info.pl?&info_id=12 . Scroll down to the Cybershot N Series camera list. The maximum capacity memory stick is 4 GB memory stick pro or M2 Memory stick Pro. For the Memory Stick Duo, it looks like those have a maximum capacity of 2 GB.
I hope this helps.
Apr 14, 2017 | Sony Cyber-shot DSC-N1 Digital Camera
CAN I UPLOAD PICS FROM MY SONY CYBERSHOT W55 USING A SANDISK??
what do you mean nothing happens???
the memory stick pro duo should fit right into the sony cybershot....
if your struggling to load your photos onto your computer buy a universal memory card reader!
you should try and use a memory stick in a camera that needs an sd though!
Oct 16, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Mar 15, 2008 | Sony Cybershot S650 Digital Camera
P71
Does your camera works fine with the previous memory card?
Sep 03, 2007 | Sony Cyber-Shot DSC-P71 Digital Camera
Sony Cyber-Shot DSC-P5 Digital Camera Logo
126 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
