Question about Sharp SF 2020 Copier
My sharp sf2530 is showing H5 at startup how do i clear this fault
  • Sharp Expert
  • 257 Answers
Clean optics and the AE sensor.
Posted on Nov 20, 2009
    Guru:
  • 389 Answers
H1 Heater thermal fuse H2 Thermistor H3 High Temperature H4 Low Temperature H5 Lower thermofuse H6 Lower thermistor H7 High temperature in lower roller H8 Low temperature in lower roller
Is Not corrected fuse, you do not throw the sodas of the mistake until avoid the fault. Apply to service
Posted on Oct 08, 2009
How to clear code H5 in all sharp copiers
here's a video i made for clearing h5-01 codes, hope this helps! it's literally the top result in google when you search h5-01! :)
Jun 30, 2014 | Sharp Office Equipment & Supplies
Sharp MX 3100n showing code H5-01 , what is it,how do I fix
when your copier paper jam in fuser unit area. than show H5-01 error code.
if you fix it self,open right door and relese the jam paper carefully.
Feb 19, 2010 | Sharp MX-3501N All-In-One Printer
My black and white sharp photocopier mdel sf 2530 is showing h5 what is the meaning of this fault and how do i clear this fault
Hello sir; To reset H5 ,you have turn power on then open front door, press and hold exposure key while you closing front door.
Oct 06, 2009 | Sharp Office Equipment & Supplies
Error code H5-01
HI.H5-01
it shows there is some problem in exit sensor .it is in fuser unit.may be its lever is broken .
sensor is dirty clean it
check lever home position and its movemment
check its cable
reset this code
press ,p,*,clear,*
screen will go dead press 14 ,start code will bi reset
never forget to rate the solution.MIAN AKHLAQ
May 07, 2009 | Sharp AR-M350U Copier
Service Mode On Sharp SF2530
A little rusty on this machine, but try this.
This code means you have had to many paper jams in the fuser without removal. Make sure all is clear in the fuser and exit sections.
Then on the control panel you will press a series of buttons as follows.
Press the Clear, Press interrupt, Press Zero, Press interrupt, Enter # 14, Press start, That should reset the machine...
Hope that helps...
Lbcoaster
Jul 02, 2008 | Sharp SF 2020 Copier
CODE H5-01
how to clear the problem, it shows:
call for service. code: H5-01
Apr 22, 2008 | Sharp Office Equipment & Supplies
WHAT DOES THE CODE BELOW MEAN
H5-01 means the machine has had a jam in the same place 5 times in a row.
Mar 13, 2008 | Sharp AR-M350N Copier
Sharp AR 250 with error code H5-01
SHARP AR250 H5-01 Papersensordefective in the fusing unit
Normally you can clean the build up of toner off the sensor, and it'll sort itself out. It also could happen by having 5 paperjams in a row.
You might need to run a service mode to reset the machine:
P * C * 14 (start) then 1 for Yes and follow on screen directions, code should clear out.
Feb 25, 2008 | Sharp AL-1641CS Laser Digital Copier
209 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
