Question about Combi Centre DX - Mango
Our combi-camp kitchen unit has been damaged on the left side with the drawers It has distorted the whole of the drawer unit has bent the side panel and pushed the kitchen unit up against the main body of the trailer-tent on the left hand side. The trailer ran back into a stone wall on a steep hill. Is it possible to buy the kitchen unit without the fridge, cooker etc., or maybe just the side panel,drawer unit and the drop-down front?
We have bought a new kitchen unit as this is the simplest, maybe not the cheapest, solution.
Posted on Oct 07, 2009
How can I pry open an unlocked but Jammed file cabinet drawer?
The issue is probably a worn out drawer interlock - that is to prevent you from opening more than one drawer at a time so the unit will not tip over on you.
Remove one drawer and check the mechanism (worn out or bent).
JOAT
May 09, 2014 | Office Equipment & Supplies
How to open cd drawer
Oh my God, the answers I\'ve found on the net on how to get the CD drawer on a Crosley CR247 open are all nuts. Mine wouldn\'t open yesterday and I dismantled the whole damn thing to get the tray open, but that isn\'t necessary.
First of all my unit was making noise when I hit the eject button but the drawer wouldn\'t open. I knew there was no CD in the tray. Powering down and all the other foolish answers I found didn\'t work. There is no small round hole in the front to do a manual eject. Trying to pry the door open won\'t work and you\'ll just damage the unit. Here\'s what you need to do. And do it all GENTLY. There is no need to force anything!
Take a small, pointed steak knife out of your kitchen silverware drawer. This is all you\'ll need to get the drawer open. First let\'s identify where we\'re going to put that knife blade. The CD drawer says "CD RECORDER" and there are 3 lines on each side of that label. Where you\'re going to put that knife is below the 3 lines on the left, to the left area of those lines (see picture). This is the location of the drawer lock.
If you still hear noise when you push the eject simply push in the knife gently as you push the eject button. The drawer will open if you got the right spot.
If you hear no noise, or your unit is dead and you want the CD out, or if you\'re just afraid to stick the knife in the unit, unplug the unit. Gently push in on that spot until the drawer pops out a little bit. Now you can gently open the drawer by hand.
You can see the drive belt and pulleys (see pic). Mine was still intact but needs replaced. Here is also the info I got off of the back of the CD (see pic). Might not be able to find a replacement belt but at least you can get the thing open. Good luck.
jim Maarrttiin@msn.com
Mar 04, 2014 | Crosley CR247 Shelf System
Kitchen Aid KUDD03DT top drawer won't stay closed
The lock lever on the unit --- that is shaped like a U --- if you have it ---may be bent a little. You can move it to the correct position - usually down a little --and your door will stay closed
Mar 04, 2014 | KitchenAid 24" Double-Drawer Dishwasher...
Stuck slide drawer on ge spectra
Check to see if the glide rail has been bent of if something is actually pinned under the stove it self sometime tile or and rug will get caugh in the drawer. after that's all clear the only other issue I can see is if cleaners of some sort have drained down unto the drawer slide, or the drawer slide is bent or off track some how.
Jun 09, 2013 | GE Profile Spectra JGBP90 Gas Kitchen...
Where is the serial number located on the unit? The control panel is not working and the factory wants the serial number.
Hi and welcome to FixYa, I am Kelly
See this picture:
http://www.applianceaid.com/newpics/range-model2.JPG
Usually it is on the lower left side of the oven face or inside the lower drawer on the left side.
Thanks for choosing FixYa,
Kelly
Jul 13, 2011 | Jenn-Air JES9800A Electric Kitchen Range
DD603 was showing F1 error and motor was whirring away, put off an electrical burning smell then popped circuit breaker for kitchen. Now when turned on bottom drawer lights up, no life from top drawer then...
Hi mate - usually F1 codes on the dish drawers are leak related - its possible you had a leak and some components burnt as a result..
Control boards are located inside the door panels, the rotor in the mid of the washer are removed from the inside, I forgotten how to remove the cabinet drawer, only ever done 1 some 10yrs back - under the drawers are your heater elements and the motor stator (windings).
Its possible the motor have piked due to leaks - really have to dismantle it first before you can decide which way to go.
Sorry cannot offer more for now, copyright laws prevent me from showing you a cross section of the unit.
I will keep an eye on your progress...
Jun 24, 2011 | Fisher and Paykel 23 in. DD-603 Built-in...
No power to the unit. come with the house we bought. I know it went unused for about a year. Work fine for 6 months and then oven would go on and off, now cook top will not work....where is the...
The model unit is on the bottom drawer of the appliance. If you pull on the drawer it will be on the left hand side as soon as you open it. Good luck.
Feb 01, 2011 | GE Spectra JBP78 Electric Kitchen Range
My Canon 5050 bottom drawer came out, an arm inside has popped up and we now can't close the drawer. We've can't gently put the arm back down. How can we get the arm down again?
Prior to the issue you facing basically ,you check whether u can reattach the arm or you can try to compare with another drawer to figure it out .See anything that broken or crack pieces.Kindly post pic to me ,I'll might help u.Thanks ,pls rate me!!!!
Sep 20, 2009 | Canon Office Equipment & Supplies
Maytag Oven model MES5752BAW when using the bottom drawer it works hard to close and goes off track and one side is higher than the other. Please help on how to fix this problem this oven was bought Aug....
remove drawer entirely. and one side at a time try reinstalling the rear wheel over he fixed (mounted wheel on unit. one side at atime with drawer empty, always easier.its gonna take some fiddling but it'll go. if it falls off track regularly then its possible that the lower frame of unit has bent and might need a little "persuasion" to line up correctly
Mar 08, 2008 | Kitchen Ranges
OVen Drawer
Insert w/thin ketchin knife upper side of the drawer push knife left and right swing gently after you feel free fron obstruction inside grab the handle outward gently/. then ok.
Jan 05, 2008 | Jenn-Air JGS8750 Gas Kitchen Range
Combi Centre DX - Mango Logo
130 people viewed this question
Top Combi Baby Gear Experts
Paul Carew
ray gallant
Are you a Combi Baby Gear Expert? Answer questions, earn points and help others
