Water doesn't come out from showerhead once the button is pressed - can hear the water pump going, the top of machine is warm so boiler is functioning.
Does water flow without the portafilter in place, if yes then check grind, if no then remove screw,filter and diffuser and press brew button, if water flows clean filter, if no water then the micro jet in the group head is blocked or the solenoid is clogged.
Was this helpful?
Yes
No
2 people thought this was helpful
Asker's Testimonial
I'll test the solution given
" - boonyap
Popular Solutions for Rancilio Epoca ST-1 Espresso
Have a Krups Orchestrto auto cappuccino coffee machine. do not like the milk frother. can it be...
(More)
Have a Krups Orchestrto auto cappuccino coffee machine. do not like the milk frother. can it be changed to the mannual model milk frother.
I have a DCM485 Series coffee maker. It brewed coffee two days ago, but would not brew yesterday...
(More)
I have a DCM485 Series coffee maker. It brewed coffee two days ago, but would not brew yesterday (12/25). The clock was working so I know it had power.
Valve on water pump leaking and leak on steam wand for a Rancilio Epoca ST-11 is leaking. The valve...
(More)
Valve on water pump leaking and leak on steam wand for a Rancilio Epoca ST-11 is leaking. The valve is acorn shaped with a spring loaded screw in it.
