Question about Kyocera FS2000DN Laser Printer
Kyocera FS2000D. Paper jam reported occassionally
Kyocera FS2000D. Paper jam reported every now and again, if you shut the lid and re-print all OK. Reseated all components and still the same.
  • gspritchard Oct 06, 2009
    Is it a problem with faulty sensors or just dirty ones do you know? Are they replaceable parts?
  • 330 Answers
This is problem with sensor you have to check all the sensors like
registration sensor
duplex jam sensor
paper exit sensor
face down tray paper full sensor........
easy way to solve this problem is remove Durmunit and toner box and rear unit then clean it useing a blower and refix all the componet and try...........
Posted on Oct 06, 2009
  • ananta Jena
    ananta Jena Oct 06, 2009
    you can clean the sensor's its will work...if its not work menas u can go for a service
    if u want service manual send me your email ID i can send you the service manual my ID is anantakumarjena0@gmail.com
Tray 2 wont print kyocera fs2000d
you have to go into the print driver settings and tell the driver that tray 2 is installed. kyocera support website can help with instructions for print drivers
Jun 28, 2013 | Kyocera FS2000DN Laser Printer
Carriage jam message...........comes on no matter what.........reset several times
Solution one: Turn the All-in-One off and on again Turning the product off and then on again might resolve the issue. Step one: Turn the All-in-One off and on again
  1. Press the Power button (c01602202.gif ) to turn off the product.
  2. Wait 60 seconds.
  3. Press the Power button (c01602202.gif ) to turn on the product
Step two: Print a self-test report
  1. Load plain white paper into the input tray.
  2. Press the Setup button (c01461502.gif ). The Setup menu opens.
  3. Press the arrow button to select Tools , and then press OK .
  4. Press the arrow button to select Self-Test Report , and then press OK . The self-test report prints.
  • If these steps resolved the issue , and the self-test report prints , there is no need to continue troubleshooting.
  • If the issue persists , continue with the next solution.
  • If the self-test report does not print , continue with the next solution.
Solution two: Clear any jammed paper Jammed paper can cause the carriage to stall. Follow these steps to clear any jammed paper. Step one: Remove any loose paper Remove any loose sheets of paper from the input tray and the output tray. CAUTION: Do not remove jammed paper at this stage. Trying to clear jammed paper from the front of the product can damage the print mechanism. Step two: Clear the paper jam from the rear of the All-in-One Use the following steps to check for and remove jammed paper from the rear of the HP product.
  2. Disconnect the USB cable from the rear of the product.
  3. Disconnect the power cord from the rear of the product.
  4. Squeeze the tab on the rear access door to release it, and then pull the door outward to remove it from the product Figure 1: Open the rear access door
  5. Gently remove any jammed paper from the rollers inside the product. CAUTION: If the paper tears while removing it from the rollers, check the rollers for torn pieces of paper that might remain inside the product. If any torn pieces of paper remain inside the product, more paper jams are likely to occur.
  6. Reattach the rear access door. Gently push the door forward until it snaps into place.
Jun 21, 2011 | HP Photosmart C5280 Printer
Says there is a paper jam and to open top cover but I do not see a paper jam there. I took out the toner cassette but do not see the paper jam.
When your reports paper jam for any reason, whether there is paper jam or not, most times you need to go thruogh paper jam clearing procedure to have your printer printing again. So please follow the procedure below:-
Clearing paper jam in a printer is simple almost seven step procedure depending on the printer. Paper jam is the term used to refer to the scenario where your paper fails to come out of the printer during the print process. When you send a document to the printer, normally the printer prints out the document on a paper; then you can pick up your printed copy. When the paper gets stuck in the printer, it is said that paper has jammed in the printer "paper jam".
Even if you are not a technical person, you can conveniently clear paper jams. All you need is to follow the set of procedures outlined below.
Put off the printer and unplug it from its power source.
Open all the covers/shutters on the printer (usually you will find one in the front or top and one at the back of the printer).
(If the printer is a DeskJet, otherwise ignore this step) Now pull out the cartridge carefully and place it on safe surface. (Be careful not to place it where it may slide and fall. This could damage the cartridge)
Site the paper that has jammed and pull it out in the opposite direction of its movement. Do not pull in the direction it was coming out. (Pulling the paper in the opposite direction is important for the printer's mechanism. Printer must be off). Never pull out paper from a printer when the printer is powered on.
(If the printer is a DeskJet, otherwise ignore this step) Return the cartridge gently and press it firmly inside so that you here it snap inside.
Close all covers at the top, front or back.
Power on your printer and you should be able to print again.
Good luck and God bless!
Mar 04, 2011 | Kyocera FS-2000D Laser Printer
Paper jam clear jam and then press ok
Use the following steps to print a self-test report. Load plain, white paper into the input tray.
Press Setup on the product control panel.
Press 2 to select the Print Report menu.
Press 6 , and then press OK to print a self-test report
Solution one: Clear the paper jam
CAUTION: Never pull jammed paper from the front of the product. If you can pull it from the rear of the product or the tray, always try the rear first. Pulling paper from inside the front cover can cause mechanical damage to the product.
There are too many steps so please follow up from
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00441807&cc=us&lc=en&dlc=en&product=441125&tmp_track_link=ot_search
Dec 01, 2010 | HP Officejet 5610 All-In-One InkJet...
My printer comes up with a clear paper jam and press checked key. I have cleared all paper from machine and yet the light flashes and will not allow me to print and the same error code comes up. What...
Solution one: Turn the All-in-One off and on again Follow these steps to turn the product on, and then off again, to reset the print mechanism.
  2. Wait 15 seconds.
  3. Press the Power button (c01602202.gif ) to turn the product on again.
    NOTE: The product might go through a warm-up period of up to two minutes. The product lights might flash and the carriage might move. Wait until the warm-up period is complete before proceeding.
  4. Try to print a self-test report. See the steps on how to print a self-test report at the top of this document.
  • If these steps resolved the issue , and the self-test report prints , there is no need to continue troubleshooting. Reconnect the USB cable, and then try to print again.
Solution two: Clear any paper jam Jammed paper can cause the carriage to stall. Follow these steps to clear any jammed paper. Step one: Remove any loose paper Remove any loose paper from the input tray and output tray. CAUTION: Do not remove jammed paper at this stage. Trying to clear a paper jam from the front of the product can damage the print mechanism. Step two: Clear the paper jam from the back of the All-in-One Use the following steps to check for and remove jammed paper from the back of the product.
  2. Disconnect the USB or Ethernet cable from the back of the product.
  3. Disconnect the power cord from the back of the product.
  4. Remove the rear door. Push the door latches toward each other, and then pull the door away from the product. Figure 1: Remove the rear door c00244379.gif Illustration of removing the rear door
  5. Gently pull the paper out of the rollers. CAUTION: If the paper tears when removing it from the rollers, check the rollers for torn pieces of paper that might remain inside the product. If any torn pieces of paper remain inside the product, more paper jams are likely to occur.
  6. If you are printing labels, see if any are missing from the label sheet. If any labels are missing, find them inside the product, and then remove them carefully.
  7. Reattach the rear door. Gently push the door forward until it snaps into place.
Step three: Clear the paper jam from the front of the product Follow these steps to remove the paper jam from the front of the product.
  1. Open the cartridge access door. Figure 2: Open the cartridge access door c01913998.gif Illustration of opening the cartridge access door
  2. If you find paper jammed in the product that cannot be removed through the rear door, gently remove the paper through the front of the product.
    NOTE: Remove paper from the front of the product as carefully as possible. If any torn pieces of paper remain inside the product, more paper jams are likely to occur, and this could damage the print mechanism.
  3. Close the cartridge access door. Figure 3: Close the cartridge access door c01913999.gif Illustration of closing the cartridge access door
  4. Reconnect the power cord to the back of the product.
  5. Press the Power button (c01602202.gif ) to turn on the product.
  6. Try to print a self-test report. See the steps on how to print a self-test report at the top of this document.
Keep in this LINK.
Oct 26, 2010 | Dell 948 All-In-One InkJet Printer
Kyocera FS 4000 DN printer stops printing for no reason.
Try the feed tires in the tray first. More than likely the paper is not being picked up and causing jam message. The separation roller also has a hub on it to prevent a second sheet from feeding. Sometimes these start to lock up ,a little oil on the hub sometimes relieves some of the tension.
Jun 03, 2010 | Kyocera FS- 4000DTN Laser Printer
Paper Jam message on every print job.
I have the same printer without the doc feeder. Check the paper trail thru the printer for the paper sensor lever hanging up. It gets pushed up by the paper and can stick, making the printer think it still has paper in it. Pulling the cart unsticks it till you print again.
Jul 03, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Kycocera fs2000d
Sounds as if the fuser unit has a damaged gear.You will need to call out a technician.
May 01, 2009 | Kyocera FS-2000D Laser Printer
Black line on prints from Kyocera fs2000d
remove the drum by opening the LHS of the printer & removing the toner waste bottle, then depress the grey button on the drum assembly & firmly pull the assembly out. Best done in a darkish room as the drum is light sensitive.
The black line couldn't be fixed as it is caused by a scratch less that 2mm long on the drum. Ether a new drun at £299 or a new printer ar £245..
Dec 03, 2008 | Kyocera FS-2000D Laser Printer
Looking for the part number of a Kyocera TK312 FS2000D printer. Any ideas on what that part number is ?
Dear,
This is (TK312) Black Toner Cartridge ,which is used in Kyocera FS2000D Printer.
Be Happy Always
Regards
Dec 03, 2008 | Kyocera Office Equipment & Supplies
Kyocera FS2000DN Laser Printer Logo
918 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
