Question about HP Officejet Pro L7780 All-In-One InkJet Printer
Printer not printing, printer looks ok but on computer it says printer error
  • 330 Answers
Check printer connections to PC .....reinstall printer driver and check
Posted on Oct 06, 2009
No computer connection
Check to make sure you don't have the printer installed more than once. If you do, it confuses the computer and confuses you. Click Start/Control Panel or Start/Settings/Control Panel and look for Printers. Open the printer and check to see if you have the same printer listed more than once. If so only one printer can be active or online and your might be printing to the one that is not active or online. Right Click on the duplicate printer and select delete.
Also look at the bottom right near the time and see if you see the printer icon. If so, open it and delete or cancel all the print jobs that are in the queue waiting to print.
May 30, 2012 | HP Officejet J5780 All-In-One InkJet...
The machine prints about 12 labels and then prints about 25 empty ones, prints 12 and the pattern repeats. Restarted the computer three times and restarted the printer five times, nothing helped.
Hold in the Feed button for 4-5 seconds, which causes the printer to attempt to "Auto-calibrate." If that doesn't solve it, then slide out the Media Sensor (green plastic bar that sticks out over the labels) about 1 inch from all the way in ("in" = left if looking from front). Then press Feed to clear errors. If still get same error, then look for piece of label or ribbon stuck in that error - ok to blow out with canned air. Then try holding in Feed again for 4-5 seconds to Auto-calibrate again.
Feb 18, 2011 | Datamax DMX-I-4208 Label Printer
I have an Epson Workforce 610. It used to send faxes just fine with only minimal errors. Now, I only get error 5303 for the last two months. I am using it wirelessly from my computer, and it prints...
Try this : Look for Setup on your printer and press OK button. Go to Fax Settings, press OK, then go to Communication and press OK. Turn off ECM and V.34. Try re-sending your faxes.
Dec 10, 2010 | Epson WorkForce 600 All-In-One InkJet...
Error 0xb9000003
* Where exactly you are receiving this error, on the printer display or on in computer?
* When exactly you are receiving this error?
* Does the unit print a self test page? Steps are given below:
1. Load the paper tray with unused plain white paper.
2. Press Setup until Print Report appears on the display, then press OK.
3. Press OK again. The self-test report prints.
:) Dr Tony
Apr 17, 2010 | HP PSC 1610 All-In-One InkJet Printer
My printer is used as a network printer, but won't print from my Dell Optiplex 755 (Win7). Two other Win7 systems on my home network print just fine. The IP address pings OK, but when I print something,...
Its seems a different Printer Port is assigned in your computer.
Open Printer Properties and click on "Ports" Tab. Look at there for TCP/IP port is Selected.
For Example :
If your Printer is on 192.168.1.40 then in your Computer Printer Port must be selected to TCP 192.168.1.40. ( Mean to say not to LPT , USB etc)
Refer to Link it shoud be like this
Mar 28, 2010 | Samsung ML-2851ND Laser Printer
Error code 6A00 what is it how do you fix it? this is what is displayed on the printer. I had a paperjam last night. I removed the paper and it worked ok. This morning it displayed this error message and...
6A00 is AP position error.
First, make sure there is no paper jam anywhere in the machine.. look inside, rear, where the paper tray (output) is, etc to see if you find any shreds or torn paper that may have gotten stuck and you didn't see.Look carefully in the zone of Purge unit, using flashlight in the right side on printer.If this not help your printer need service.
Oct 28, 2009 | Canon PIXMA MP830 All-In-One InkJet...
"fatal print spooler error" error message
Completely uninstall the printer driver and install again. If this does not work, there is a corruption in the windows registry or in the print spooler cache files.
For a temporary workaround, disable print spooling. But, if you do, you will need to remember to never close an application you print from until printing is actually finished.
Jun 28, 2009 | Konica Minolta magicolor 5430 DL Laser...
Paper jam when trying to print envelopes.
You need to make sure that your print sriver setting match the setting on the printer itself.
If setting are changed on the printer itself to envelopes then when you go to print click preferences button on print screen and look for a place to change paper type (usually defaulted to letter size.) Change paper type to envelpoes and click ok. Click ok again on print screen and it should print correctly.
Paper types must be configured the same on the device as well as the print driver installed on the computer.
Hope this helps
TankMurdock
Mar 09, 2009 | HP Photosmart D7260 Printer
Printing pictures on Kodak Printer dock G610 from Kodak Easy Share on the computer
keeps giving me message "printing error" (prints ok from camera) i have probably messed up every setting by now
Oct 20, 2008 | Kodak EASYSHARE G610 Thermal Printer
Printer won't print in some softwares but will print in others.
Hai
pls reinstall the os and try it will work otherwise there is problem in printer port pls check the setting it will work
Oct 25, 2007 | Computers & Internet
HP Officejet Pro L7780 All-In-One InkJet Printer Logo
48 people viewed this question
Seeker5211
Seeker5211
