Question about Ovens
Need manual for smeg oven sa708x - Ovens
5 Suggested Answers
Buffalo12980
  • 625 Answers
SOURCE: SMEG SA708X Oven Heater problem
thermostat must be getting a blast of cold air from the door being opened.
Posted on Sep 06, 2007
TaPuna
  • 70 Answers
SOURCE: smeg oven model SA708X--Clock faulty
hi, if you have a faulty clock it is likely the relay in the clock is stuffed you could try to repair it but i think you are better off just buying a new clock, clocks are expensive thou, so bypassing is a good choice
Posted on Sep 09, 2008
  • 86 Answers
SOURCE: NEED USER MANUAL FOR SMEG SE375MFX5
SMEG SE-375MFX5 Owner Manual
Posted on Feb 09, 2009
SOURCE: SMEG SA708X oven's symbols have rubbed off, wioul
Here's a picture of the panel... BTW does anyone know the wiring / have a wiring diagram for the door switch as mine was swapped around by an oven guy just to get it running but now I have a new switch and can't remember how it all goes!!
Posted on Jun 01, 2010
Help! I have a Smeg oven Model Number: SA410X-5. All of the symbols have come off. I have just moved in to a new place with this oven and have no idea what the symbols are meant to be! Im urgent need of...
here is the manual
Smeg Multi Function Built In Oven Operation Manual
specs
Description
Smeg 60cm Stainless Steel Single Oven. Model: SA410X-5
  • RRP: $1,490. The RRP is supplied by the manufacturer and is based on a brand new item, not used. It is accurate as at 1st April 2010
  • Dimensions: 595mmh x 596mmw x 567mmd
  • Smeg thermosealed, fan forced, six function, 60 minute timer
  • Capacity 66.4 litre gross, 56.1 litre net
  • Installation underbench or wall (column), fascia: flush or proud mount
  • Thermostat variable 0 -250 Celsius
  • Multifunction five cooking functions plus defrost, timer 60 minute max, variable count down timer
  • Part number: 9842 (SN:SA410X-5) (145924-2)
Spares and schematic
SMEG SA410X 5 Parts List BigWarehouse Spares
New Fascia Stickers for 15.00GBP
Smeg SA410X facia stickers for worn fronts
Apr 03, 2018 | Smeg Ovens
Fixed fan element, but can't remember how to put it back together again
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Jun 22, 2012 | Smeg Ovens
SMEG SA708X oven's symbols have rubbed off, wioul appreciate a photo of the left hand (have only managed to find the dial template for teh right side dial)
Feb 26, 2010 | Smeg S1100MFX5 Electric Single Oven
Need a copy of manual
try smeg.com/manual
It came up for me ,see if your item is on there.
Feb 05, 2009 | Smeg DO81CSS Electric Double Oven
Smeg oven model SA708X--Clock faulty
Sep 08, 2008 | Ovens
REQUIRE AN INSTRUCTION MANUAL FOR A SMEGG SE378 MFX5 OVEN
You can get instruction manuals for all smeg products by following this link http://www.smegtech.com/site/smeg/myapp/libretti/index.php?lang=EN
Dec 06, 2007 | Smeg Ovens
Sep 06, 2007 | Ovens
Ovens Logo
148 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
