Question about Ricoh Office Equipment & Supplies
Hi, I have a Ricoh 1224c, color copies come out with a blurred or waterfall effect on about the first half inch of the leading edge of the copy, but the black copies are ok. The next 1 1/2 inches roughly of the color copy is slightly discolored and the rest is ok. There is some streaking from the first half inch that goes all the way up the color copy.
    Guru:
  • 389 Answers
The Colour toner more small and he does not disappear the blade a peelings, you it is necessary to check the magnetic hand on colour cartridge. If hand unevenly covers the magnetic gross to adjust the дозирующее blade. Clean the gross, insert the sheet of paper between dose and gross and release the bolts an dose blades, press the blade to paper aside gross magnetic, afterwards bolt the bolt. Extract the sheet. Clean all from the remainder of the toner. Check the blade a peelings drum if evaporation during stop main by breaker exists on drum, change rakel. The Period of rakel's work is measured by period of the work photo drum, beside 10 thousand sheets. Such effect more often exists from wear-out of rakel. Remind, black toner has grain more so he leaves the rakel. The Colour toner small and its clear requires new rakel.Udachi. fault has not an electronic reason. This mechanics.
Posted on Oct 10, 2009
Black smudge when printing color
Imaging unit is the problem. It's made for 100k but often there is a problem very soon after replacing. There is a belt in this unit and he has a lenght enough for two pages A4. Thats why you have problem on every second page. Try to reassembled it and see what is wrong inside ot imaging unit.
If you ask me...buy new mashine. This one have a hundreds of problems by default.
Pifonski
Nov 23, 2015 | Ricoh Aficio 3232c 3214c 1232c 1224c Oil...
Copies and prints are always approximately 7 millimeters too much in the left side on the paper
you need to adjust the lead edge trim
press yellow C and 107 and press and hold red C button
then go to copy SP
select 2 drum
then look for trim adjust
and then select front
then change values up and down until you get the correct registration. you can do a test copy while on SP mode by pressing copy window.
Sep 19, 2014 | Ricoh Aficio 1232C Color Copier
How to decode Ricoh (Aficio) 1224c with code sc 670 from my color copy mactine....
In the service mode (clear modes 107 hold down clear/stop key) then punch in 7807 on the number pad then execute to reset the sc 670, if it doesn't clear you may have a bad controller board or HDD. Hope this helps
Aug 03, 2011 | Office Equipment & Supplies
Hi Ricoh 1232 copier and printer. Both copies and prints are produced as if the paper feed was slightly delayed and the print moves over about an inch: effect is you have a large margin on the left side...
Is the paper in the tray landscape-oriented or portrait-oriented? If it's landscape-oriented (short edge is fed first) then you might just need to realign the paper fences. There is a screw holding down the gear in between them -- if you remove that screw you can move the fences so that they're both lined up correctly. (Push them both in all the way or out all the way, then reinsert the gear and screw it back down.)
If the paper is portrait-oriented, it may be an adjustment that will have to be made by a Ricoh service technician. It is a simple adjustment to make, and should only take a minute or two if you can have a tech look at it.
Apr 11, 2011 | Ricoh Aficio 1232C Color Copier
Ricoh 1224c prints on left side only - Blank on right side
well if its just on the black then it might be the black drum see if it does the same on the color from copying and printing. If it does the same in color then its not the drums it may be the developers, but you wont know untill you test the color if it only happens in black and white its definitely a problem with the drum.
Mar 25, 2010 | Ricoh Aficio 1232C Color Copier
I have some ricoh aficio 1224c with errors c481
SC481
Transfer belt mark detection error
• The main motor is operating; and
the lock signal is detected. → The
belt mark sensor signal does not
change for 120 milliseconds.
• Defective main motor
• Image transfer belt out of position
• Belt mark blurred or absent
I would remove the pcu unit (3 screws)and check the transfer assy belt mark and clean the sensor that reads the belt mark. Worst case senerio is replaceing the entire pcu unit.
Mar 07, 2010 | Ricoh Aficio 450 Copier
How to reset pass admin RICOH aficio 1224c?
The user ID is blank. The password is the word password.
If that doesn't work, let me know.
Mar 14, 2009 | Office Equipment & Supplies
Pcq on full colour mode
Make sure your rollers are clean. It could be something dirty in the fuser section as well.
Jan 30, 2009 | Ricoh Aficio 2015 Copier
How to get glowing effect in coreldraw
To create a glow: make a copy of your image you want to glow. paste to the side or original. select original. Convert to Bitmap, then use Gaussian blur, select pixel width of blur, preview it, then apply it when it look good. Put your copied image on top of the blurred image, bringing the copied image TO FRONT. voila NOTE change color of image to be bit-mapped BEFORE you convert to bitmap for a COLORED Glow
Dec 19, 2008 | Computers & Internet
175 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
